Skoda Fabia VRS 2012. Auto lights retrofit OEM
Forum to discuss the Skoda Fabia
VASILEIOS1972
Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Re: Skoda Fabia VRS 2012. Auto lights retrofit OEM
Post by VASILEIOS1972 »
ciclo wrote: Thu Oct 10, 2019 11:50 am Good morning,
Hello Fernando
1st image biiiiiip (ok)
2nd image (10,76)
can lines 13-14 value in (-1) biiiiiiiiiiiip
after those , in which pins in T18 may start making tests ?
Best regards
Vasilis
In all of them, also the two fuses, and also verifies that there is no continuity (short circuits) between the wires that reach the T18 connector.
Pay special attention to CAN lines due to discontinuity in the splices.
Move the wires when you are checking their continuity from connector T18 (J745) to connector T41 (G85) to rule out a false/bad contact.
Why should you check the continuity of the CAN lines on the T41 connector?
- They are the CAN lines belonging to the powertrain and if the test is correct, problems in the splices can be ruled out.
Just to clarify:
CAN lines T18 <---> T41
High line with High line... continuity.
Low line with Low line... continuity.
Low line no continuity with High line.
The slots on the connectors must be the corrects, according to erWin. (L 13--2, H 14--3)
VASILEIOS1972
Hello Fernando ,
i made the tests and was the same as in past.
But I have all ready bought a new (used in immaculate condition) t18 connector with pins included.
I am going to prepare a new t18 wiring with extended wires to make peripherals connections and do new tests
Because it is not make sense to not work this project ....................
Best regards
Vasilis
8) I'll watch your progress. :wink:
You should also buy a T2 connector for the old IC CAN lines <---> J745 CAN lines. MQS terminals, male, female.
:arrow: viewtopic.php?f=10&t=42713&p=466570#p466570
https://www.a4-freunde.com/showwiki.php ... uebersicht
Well, it's been two months since you asked me by pm/email to do your AFS wiring.
After receiving by email the lengths that I recently requested from you ...
... these are the materials and lengths that I have used:
3D0035131 18-p connector. Replaced by = 5Q0972718A
4E0972575 + 4B0971832 2-p connectors. CAN Lines
CAN lines, AFS - IC : 180 cm twisted pair. black High, yellow Low
+15, afs - fusebox sb12 : 190 cm blue/black
56x signal, AFS - to facilitate inst connector: 320 cm yellow
Ground, AFS - dimmer : 290 cm brown/black
G signal, AFS - dimmer : 290 cm red/black
G signal, AFS - R headlight : 250 cm red/black
G signal, AFS - L headlight : 450 cm red/black
LIN, afs - R headlight : 250 cm yellow/black
LIN, afs - L headlight : 450 cm yellow/black
+15, fusebox sb14 - R headlight : 350 cm yellow
+15, fusebox sb14- L headlight : 270 cm yellow
Ground 1.5mm2 T10/10 R headlight : 100 cm black
Ground 1.5mm2 T10/10 L headlight : 100 cm Black
Fuse 5A sb12, Fuse 10A sb14
MQS x4 (original CAN lines)
Eye terminal x2
Cloth tape
Plastic ties x15
and this is your HQ AFS wiring.
Verified with multimeter, everything is OK to be installed.
Installation guide
I hope it's to your liking.
Notes:
- That this wiring is well installed does not imply that the cornering lights work.
- It is mandatory that you post a current autoscan for me to correct the BCM coding. (here o by email)
- Technical support here or by email. (it just depends on your desire to share with other users)
Price: 100€ + 11€ shipping cost = 111€ (packaging, paypal fees, etc. included)
Payment by Paypal.
VASILEIOS1972
Hello my friend Fernando , thank you for another time for the support that you giving me .
Of course i will share autoscan and opinions about this project us usual .
Best regards
Vasilis
Hi Vasilis. Payment received, thank you.
Tomorrow I send you the tracking number to your email.
The same address as the other time?
VASILEIOS1972
ciclo wrote: Sun Jan 26, 2020 7:37 pm Hi Vasilis. Payment received, thank you.
My friend check the address that I have send in your email please
I think the address now is different
regards
Vasilis
Ok, new address received. Perfect!👍
VASILEIOS1972
Hello my friend Fernando afs project has complete success because of you!!!
Results
1) light dimmer , OK
2) light height regulator , OK
3) AFS low , OK
autoscan above
Friday,07,February,2020,21:51:08:38567
VCDS Version: 19.6.2.0
Data version: 20190930 DS308.0
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: TMBEP25J2C3XXXXXX License Plate:
Mileage: 67030km-41650mi Repair Order: afs low OK
Chassis Type: 5J-SK25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 55 56
VIN: TMBEP25J2C3XXXXXX Mileage: 67030km-41650miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 CE HW: 03C 906 027 CE
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 53850 001 1048576
ASAM Dataset: EV_ECM14TSI01103C906027CE 001013
ROD: EV_ECM14TSI01103C906027CE.rod
VCID: 66C3ED1499F16A7F3D-8032
Readiness: 0000 0000
Part No SW: 0AM 300 060 A HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6563
Revision: 00043014 Serial number: TFK01108310139
Coding: 0000020
VCID: 285FA32C9B65BC0FCF-807C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AL HW: 6R0 907 379 AF
Revision: --------
Coding: 410148DB437300B3822712E9C2D200411700
Shop #: WSC 13765 790 00049
VCID: 081FC3ACBFA59C0FEF-805C
Serial number: 25021504650800
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF3A574E161D2BFD5-802A
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 C HW: 5J0 907 044 C
Component: Climatronic H08 0103
Revision: K0000000
VCID: 2A5B592445698E1FD9-807E
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 7A980B3848010000013806B03EEB9BC052C0621F60002041200400020000
Shop #: WSC 12345 123 12345
VCID: 2B555C204A93971722-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 230714 05 54 0403
Coding: 0230AD
Subsystem 2 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3211
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
Subsystem 4 - Part No SW: 3T0 959 537 E HW: 3T0 959 537 E
Component: E221__MFL-URO H07 0012
Serial number: 2164426
Coding: 810000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3211
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3211
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 35811406000186
Coding: 108101
VCID: 3B756C60B2F30797B2-806E
Component: VW10AirbagT20 H09 0020
Revision: -------- Serial number: 003GX00UUUCP
Coding: 003230
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9B39A4ED29AE1F39-801E
Serial number: 3495RRB40590NHDIJH62
Serial number: 3505RRB40590NHDIAOG2
Part No SW: 5J0 920 841 F HW: 5J0 920 841 F
Component: KOMBI H04 0305
Coding: 120C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 2D5152387C8799273C-8078
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 032204
VCID: 68DFE32C9BE57C0F0F-803C
Component: IMMO H04 0305
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB99248DE94E1F19-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 5JA 035 193 E HW: 5JA 035 193 E
Component: RNS315-EU H85 0501
Serial number: SKZAZ2R0659899
Coding: 040000110400000000000000
Shop #: WSC 44700 231 72242
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3A7B6964BDC93E9FA9-806E
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V11 0073
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 13765
VCID: 2F6D4830EA8BEB370E-807A
Address 55: Headlight Range Labels: 5J0-907-357.lbl
Part No: 5J0 907 357 B
Component: Low AFS H01 0004
Revision: 00000001 Serial number:
Coding: 0000002
Shop #: WSC 13765 790 00050
VCID: 306F4B4CA7B5F4CF17-8064
End-------------------------(Elapsed Time: 03:04)--------------------------
tell me my friend do I need new coding for my BCM max ?
Best regards
Vasilis
Opa! Yeaaah! 8) ... Image I love me :lol:
Good job!👌 (it would be great if you take a video of your cornering lights working)
I sent you an email requesting an Autoscan, please forget my email, I will answer you here.
Please wait for me to check your Autoscan ... thanks!
VASILEIOS1972
ciclo wrote: Sat Feb 08, 2020 4:35 am Opa! Yeaaah! 8) ... Image I love me :lol:
Good morning my friend again
I have send you what you ask .
Best regards
Vasilis
Good morning Vasilis
New BCM coding
7A980BB848010000013806B07EEB9BC052C0621F60042041200400020000
To check:
- That the DCLs rotate when you put the turn signals.
- That the DCLs rotate when the steering wheel is turned.
- That no faults in Autoscan or warning lights in Instrument Cluster.
I await your comments.
VASILEIOS1972
Hello Fernando , I have those 2 faults above
Saturday,08,February,2020,11:01:22:38567
www.Ross-Tech.com
Address 09: Cent. Elect. Labels: 7E0-937-BCM-V1.clb
Control Module Part Number: 7E0 937 090 C HW: 7E0 937 090 C
Component and/or Version: BCM PQ25 Max4 H82 0752
Software Coding: 7A980BB848010000013806B07EEB9BC052C0621F60042041200400020000
Work Shop Code: WSC 12345 123 12345
VCID: 2B555C205A93971722-807E
2 Faults Found:
03428 - Activation of Left Adaptive Light
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 248
Mileage: 67030km
Time Indication: 0
Date: 2029.14.31
Time: 13:21:52
03429 - Activation of Right Adaptive Light
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 248
Mileage: 67030km
Time Indication: 0
Date: 2029.14.31
Time: 13:21:52
and dash light
VASILEIOS1972
address 55 performs out put tests with success
