Page 171 of 333
Posted: Tue Sep 20, 2016 8:28 pm
by ciclo
JapFan wrote:Hello guys,
It’s been a while it’s me with the Roomster again :roll: I completed the install of the RLS and BT. It’s all working great. However I cannot get automatic windows close by rain feature to work. But that is not such a big problem for me. Also the light sensor works I can see on the navigation switching to night mode. Maybe if someone could double check my coding but I think it should be OK.
Have a question regarding the AUTO lights I managed to get a new BCM almost for free it is 7H0 937 090B do you think it would be any good to make the upgrade to it???
Rain closing is still an unsolved mystery. I think it is related with coding in central locking (BCM, door units)
The BCM 7H0 is a good choice. I can help you to understand the diagrams for you to do the wirings (if you need), but I can not do the wirings for your Skoda Roomster. Neither for BCM adaptation, nor Automatic lights. It's impossible because the wiring measures are differents that for Polo 6R. Only for Polo 6R Europe and only for Automatic lights.
BCM coding is right. (except you have CH/LH enabled :wink: :lol: )
Posted: Tue Sep 20, 2016 8:38 pm
by ciclo
peresurin wrote:hello ciclo,
first of all i am very impressed of your skills and technical knowledge. I read all this subject from start to end. I have some questions. you stated that you used below LEDs;
viewtopic.php?f=56&t=58703&start=285#p479470
But i can not find them anymore (actually i found one but I just want to be sure), is it possible to use below products for this fog-lamp mod;
1) https://www.aliexpress.com/item/A-Pair- ... c6236caef3
2) https://www.aliexpress.com/item/Night-L ... c6236caef3
or this one>
3) https://www.aliexpress.com/item/1set-60 ... f826051b1b
The third one is your product i think? I kindly ask you to advise which one fits well w/o error.
Thank you in advance for your reply.
Welcome,
I have to study this issue carefully because your Polo is a 6C model. Be patient... I will check...
Most important is the lamp connection. For 6R it is H8.
Posted: Tue Sep 20, 2016 8:44 pm
by ciclo
firegrafik wrote:Russian Volkswagen representatives from the factory in Kaluga. Released the Promo video concerning sales start the New Polo Sedan GT 1,4TSI CZCA 125HP
I like the videos, Thanks!
Have you solved the issue with parking lights? :wink:
Posted: Wed Sep 21, 2016 3:21 am
by govindsharma
Dear Ciclo auto rain closing is working very well in my polo 6R
Anyway you changed the coding of the sensor:
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 311215 03 37 0059
Coding: 036800 It is factory coding and in this auto rain closing is not working.I had changed it to following
Coding: 0714DD Here it is working very well in my polo.I had changed J386 and J387 coding to 350000 and 040000.Auto rain closing also working in this code but i want factory coding that's why i am approaching you.
Please make a test with the two codings, and tell us which one it is right for rain closing in your 6R after you solved your coding problems in door units.
Thank you.
Posted: Wed Sep 21, 2016 4:57 am
by firegrafik
ciclo wrote: ....
Nope.
Now I am searching the appropriate way to get the right BCM's EEPROM.
Posted: Wed Sep 21, 2016 7:14 am
by Adam87
What is the issue with parking lights? Do you have a security access login code for the PQ25 BCM's as this makes it slot easier to read EEPROM, or do you do it directly?
Posted: Wed Sep 21, 2016 7:54 am
by ciclo
or this one>
Welcome,
Foglights Polo 6C Lounge ---> N10529501 = H8
Examples that you should not buy because the beam pattern is not correct:
http://www.aliexpress.com/item/2Pcs-Lot ... c23227fdc5
http://www.aliexpress.com/item/Universa ... bcb01e8731
They must be similar to those that I have installed. Also search on other websites because these lamps are constantly evolving.
Lumens: 2400-3200 ---> white.
Posted: Wed Sep 21, 2016 7:58 am
by ciclo
govindsharma wrote:Dear Ciclo auto rain closing is working very well in my polo 6R
Ok, thanks for the info.
Posted: Wed Sep 21, 2016 9:11 am
by govindsharma
Ciclo Sir what about my polo folding side mirror.
Posted: Wed Sep 21, 2016 9:18 am
by ciclo
firegrafik wrote:
ciclo wrote: ....
Nope.
Parking lights 6R: (if Automatic lights)
Signal from T10/3 (light switch connector) -----> to T73a/45
Make a test:
Install a new wire directly from T10/3 to T73a/45. Do not use original wires from factory for Parking lights signal.
Byte18: change the BCM coding if you need. As you know.
In this way should work correctly.
Posted: Wed Sep 21, 2016 9:19 am
by ciclo
govindsharma wrote:Ciclo Sir what about my polo folding side mirror.
viewtopic.php?f=56&t=58703&start=2535#p513554
Posted: Wed Sep 21, 2016 10:07 am
by govindsharma
DeAR when i am changing code of j387 to 000002 it there is massage that code rejected out of range and when In my car j386 and j387 only first two character are changing like 100000 220000 any digit but front two or said byte 0 only.
Posted: Wed Sep 21, 2016 1:28 pm
by firegrafik
Adam87 wrote:What is the issue with parking lights?....
I installed Polo 6C LED headlights on my Polo 6R sedan. But my BCM's full number 7E0937090ZHH it has EEPROM preset for Russian Polo 6R sedan with RLS and bixenon.
So in DRL mode the LED-DRL has full brightness (as it should be). But in parking-lights mode it should be dimmed but it gets off at all. I need to find the EEPROM from the T6 BCM first of all.
ciclo wrote: Parking lights 6R: (if Automatic lights)
Make a test:
Fernando, wiring is OK for sure.
Everything worked correctly with halogen H7 headlights and halogen DRLs
Posted: Wed Sep 21, 2016 1:40 pm
by Adam87
If anyone can help with a PQ25 BCM security access login I can get one (seems no one knows it)
Posted: Wed Sep 21, 2016 2:18 pm
by iichel
31347 is not working?
