peter_dk25
- Drives: Blue GT
chisyelamos1
- Drives: 6c 1.4tdi
Hello ciclo.
I Will install globebox ligth but i want to know what light bulb i need? Festoon 31mm? Or 36mm?
It is for buy led bulb while come the order
Enviado desde mi LG-H815 mediante Tapatalk
Hello chisyelamos1,chisyelamos1 wrote:Hello ciclo.
36mm
iichel wrote:K-Line time!!
Well, as you know this morning I went to my VW dealer to check for updates in the following units; engine control unit, BCM-Gateway, ABS unit, and Instrument cluster.peter_dk25 wrote:X fingers
All units were checked with ODIS program and just the engine control unit was updated.
Address 01: Engine (J623-CBZC) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 2686
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
ROD: EV_ECM12TFS02103F906070FJ.rod
VCID: 6A0F8AD4DFA86FC442-803E
Readiness: 0110 0101
To:
Component: SIMOS10.22AH10 5466
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
VCID: 6A7F1A442F38FFB4F2-803E
But without getting the CCD (GRA_High) activation after checking the possible adaptations (ECU = no adaptation, Instrument cluster = no available like in vcds).
Although it was not possible to get the cruise control display function I want thank the full cooperation of my VW dealer to try to get it. (excellent)
The K-line (which I have spoken in previous posts) had no remarkable effect.
On the short drive from the VW dealer to my house I could see that my R-line is faster and spends less with the new ECU sotfware. Just kidding
At least you tried
peter_dk25
- Drives: Blue GT
No more possibilities and ways to try
It is certainly a shame, maybe someday some genius achieves to run this function in a POLO 6R 2012-2014 (not WRC).Adam87 wrote:
[emoji53] shame
I appreciate all your help on this issue through email, I'm not used to getting so much help.
By the way, I'm ready for anything you need, e.g the wiring adaptation BCM Max for your T5.2, etc...
Ask me, the universe force will do the rest.
Yes, it's the important.iichel wrote:At least you tried
Install an ECU with a compatible software for your 6R engine and gearbox from other models (vw, skoda...) with this feature factory.peter_dk25 wrote:No more possibilities and ways to try
SO, next step done.
Used
Window regulator motors:
6R0959801BD Z0D
6R0959802BF Z03
And coding
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF
Component: J387__TSG_BT 003 8612
Coding: 1000AB
And have question ;D
How can I code windows regulator motors to at the opening of the pilot car mirrors is unfold? Currently decompose when I turn the key. Can it be changed? :>
Used
6R0959801BD Z0D
6R0959802BF Z03
And coding
Coding: 0200A3
Coding: 1000AB
You are most welcome, would be nice for someone to solve one of your mysteries for all the help you give out [emoji6] we shall keep trying [emoji23]ciclo wrote:
And I very much appreciate your help for my T5 [emoji106]
Good job favi.
Still unknown if it is possible such coding, anyway I think that is better how they are unfolded in the standard way to avoid they may be unfolded whenever you unlock/open the car. For example, if you open the car only to catch something from the glove box
If you need the mirrors before you turn the ignition key to ACC position you can use the knob mirrors switch.
I have had a new idea about the CCD that I overlooked because of how stupid it is... but I will try it.Adam87 wrote: You are most welcome, would be nice for someone to solve one of your mysteries for all the help you give out [emoji6] we shall keep trying [emoji23]
More info the next week...if I have success.
UnderstandAdam87 wrote:You are most welcome, would be nice for someone to solve one of your mysteries for all the help you give out [emoji6] we shall keep trying [emoji23]ciclo wrote:
So, mission complete. And now? Instrument cluster high version and BCM max
you will retrofit a DSG?ciclo wrote: because of how stupid it is... but I will try it.
