Page 19 of 41
Posted: Mon Feb 05, 2018 3:13 pm
by BARBUDO
I was ready to buy the lever and start the retrofit, but the vcds seller told me that since 2016, most of the modules are activated online and an incorrect coding could block even the vehicle (abs) and should i go to a dealership to Fix it $$$, once blocked it will not let me put the previous code. I was going to buy a Chinese VCDS clone, and now I do not know what to do. In fact I have seen that the Chinese VCDS do not work well, also told me that LONG CODING HELPER probably would not work because the vehicle is very new and due to the online coding there is no information about the modules, the same thing would be with a original vcds. The seller left me quite scared, here an original vcds cost around 1000 usd, and the stalk about 300usd. Too much money to screw up. And Ciclo, that function you mentioned about is the first speed level of the wiper, in fact the picture you posted is exact the same as my lever.
Posted: Mon Feb 05, 2018 4:09 pm
by iichel
Original vcds starts at $199 + taxes
https://store.ross-tech.com/shop/vchv2_ent/
If you're a bit handy, maybe you'll get away with replacing just the left stalk from a used one, i.e. here from Europe
Posted: Mon Feb 05, 2018 6:42 pm
by ciclo
BARBUDO wrote: Mon Feb 05, 2018 3:13 pm
Buy the VCDS cable, buy the stalks, your CCS will work perfectly with my help.
So that position is for sweep intervals, is it correct?
Posted: Tue Feb 06, 2018 12:04 am
by BARBUDO
ciclo that's right, it's for sweep intervals. Mine does not have the small switch that looks like a potentiometer, i'm looking at elsawin trying to understand the wiring diagram. Is there any difference? another relay, wire etc ??
Posted: Tue Feb 06, 2018 5:08 am
by ciclo
There are no differences related to the wiring diagrams, the difference is in the stalk only. (electronic internal parts)
Your current stalk has the sweep interval adjusted to a fixed time and the new stalk you want to install can vary the sweep interval time depending on the small toggle/lever position. (4 positions)
In case of having the rain sensor installed, these 4 positions will indicate to the rain sensor its rain sensitivity via BCM, shortening or lengthening the sweep interval
automatically.
Therefore, it is not necessary to add any additional wire in your Saveiro Cross for this reason. Everything is OK in your factory wiring.
Posted: Tue Feb 06, 2018 10:34 pm
by BARBUDO
Ciclo first at all, thanks for all the support you are giving to me. The VCDS is coming, and also the crimper and the terminals N 907 647 01 (for BCM t73 conector, and the t41 conector). In my next posts i'll update whit the autoscan. I have practically understood the whole process of what I have to do, but I have some doubts. First what's the difference between BFM and BCM? The elsawin's diagrams do reference to three connectors t73 (t73a, t73b and t73c) and my BCM (089) only has two connectors A and B, but only mentions t73a in the diagrams when it refers to BFM, and only for vehicles with BFM. In vehicles with BCM says t73b and t73c, which i suppose is t73b is conector A in my BCM, and t73c is conector B in my BCM, becouse in that case the diagrams of POLO are exact the same as mine, thing that is 99% probably. The only difference is that in my case there is not a Diode.
Another doubt i have is what terminal i have to buy for the ECU wire . The ECU is Continental for CNXA engine, article 04E906032, t121 connector. Again, thanks for all the support
Posted: Tue Feb 06, 2018 10:38 pm
by BARBUDO
Posted: Wed Feb 07, 2018 6:06 am
by ciclo
BARBUDO wrote: Tue Feb 06, 2018 10:34 pm
BFM
http://images.tcdn.com.br/img/img_prod/ ... 100511.jpg
BCM
http://images.tcdn.com.br/img/img_prod/ ... 103231.jpg
Different Electrical Switchboards (09 Cent Elect) that fulfill similar mission in PQ25 platform.
The BFM is a lower level to understand us, but it is very useful when it is necessary to outsource the management of some equipments for its compatibility. Door modules, for example.
It's a good VW solution.
100%
BFM = 1 connector T73a in diagrams
BCM = 2 connectors T73b , T73c in diagrams, being in this case T73b 'A' black connector and T73c 'B' white connector. So simple as that.
It is the logical way of naming the connectors when two different electrical switchboards are used for the same VW model.
With the new software in BCM/BFM and electrical installations (201X?-->) such diode is not necessary. No problem regarding this.
Another doubt i have is what terminal i have to buy for the ECU wire (pin 69). The ECU is Continental for CNXA engine, article 04E906032, t121 connector. Again, thanks for all the support
T81 connector
So,
000 979 018
Posted: Sat Feb 17, 2018 6:11 pm
by BARBUDO
Autoscan... some modules don't appear in autoscan i don't know why, 09 CENTRAL ELEC allow long coding helper whit all the information for each bit. 01 ENGINE do not show the information of each bit in long coding helper.
Saturday,17,February,2018,13:23:33:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: 9BWJL45U2HP073846 License Plate:
Chassis Type: 5U-VW23 (5U - VW Gol/Voyage/Saveiro (2009 > 2013))
Scan: 01 02 03 07 15 25 29 39 46 56 76
Address 01: Engine (J623-CWSA) Labels: None
Part No SW: 04E 906 032 B HW: 04E 907 425
Component: 1.6l R4 MPI H07 2203
Revision: --H07---
Coding: 00110012020480000000
Shop #: WSC 01530 935 00200
ASAM Dataset: EV_ECM16MPI02104E906032B 001005
ROD: EV_ECM16MPI02104E906032B_001.rod
VCID: 1F4CDBE006BDDDBE93-804A
2 Faults Found:
20294 - Indicator Lamp for Winter Driving Program
P163D 00 [032] - Electrical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
15124 - EVAP Emission Control Sys
P0441 00 [096] - Incorrect Flow
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 8970 km
Date: 2013.14.18
Time: 17:44:20
Engine speed: 2444.00 /min
Normed load value: 53.3 %
Vehicle speed: 87 km/h
Coolant temperature: 85 °C
Intake air temperature: 39 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.886 V
Unlearning counter according OBD: 25
Fuel high pressure: actual value-Actual fuel rail pressure: 4998.93 hPa
Sensor control factor: output value-Lambda control value: bank 1: 2.267 %
Charging_activated charcoal filter system_moving_averag val-ACF: load: 0.00000
Target position of EVAP canister valve: 0.0 %
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5U0 907 379 C HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0004
Serial number: --------------
Coding: D1DC8888212A0CC38B1C116D845730408900
ASAM Dataset: EV_Brake1ESP90iBOSCH 004034
ROD: EV_Brake1ESP90iBOSCH_004.rod
VCID: 408E789CDB83C246CA-8014
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 34D 959 655 HW: 34D 959 655
Component: AirbagVW20 005 0366
Serial number: 003K5M0W4AS
Coding: 8800C0000000000040000000000000000065
ASAM Dataset: EV_AirbaVW20SMEVW253 001110
ROD: EV_AirbaVW20SMEVW253_VW23.rod
VCID: 72EAE254A5AF20D68C-8026
Part No SW: 5U0 920 865 B HW: 5U0 920 865 B
Component: IMMO H06 0007
Serial number:
Shop #: WSC 00000 000 00000
VCID: 3A7A0A74BD5F989684-806E
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 C HW: 6RF 035 187 C
Component: Radio 556 5514
Revision: -------- Serial number: VWZ7Z2T5128871
Coding: 0E00041002000E
VCID: 499865B8E0B9030E1D-801C
Address 76: Park Assist (J446) Labels:| 5U0-919-475.clb
Part No SW: 5U0 919 475 B HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0007
Revision: -------- Serial number: 18081616400307
Coding: 10000C
ASAM Dataset: EV_EPHVA14VW23X0000 001004
ROD: EV_EPHVA14VW23X0000_VW23.rod
VCID: 3F8C7B60A67DBDBEB3-806A
End-------------------------(Elapsed Time: 02:50)--------------------------
Posted: Sat Feb 17, 2018 9:35 pm
by ciclo
It seems that you have selected an Old model that your current one to make the autoscan ...
But it's better to select the auto-detect (CAN only) and click en
Start button....
and you will get all the installed units.
Forget the Long coding helper, it's not necessary.
Posted: Sat Feb 17, 2018 10:31 pm
by BARBUDO
haha I was so excited for my first time using vag-com, i didn't realize the model year. Here is the good one !
Saturday,17,February,2018,18:14:20:00001
www.Ross-Tech.com
Chassis Type: 5U-VW23 (5U - VW Novo Gol/Voyage/Saveiro (2013 >))
Scan: 01 02 03 09 10 15 17 25 30 56
VIN: 9BWJL45U2HP073846 Mileage: 10520km-6536miles
Revision: --H07---
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 8970 km
Date: 2013.14.18
Time: 17:44:20
Part No SW: 7E0 937 089 HW: 7E0 937 089
Component: BCM PQ25 MMI4 H80 0736
Revision: BB080001 Serial number: 17007161160981
Coding: 3A8889284C3BC600102A06C06C48B880B00062BC60842000240580020000
VCID: 70EEE85CA3A312C67A-8024
Subsystem 1 - Part No SW: 5U0 959 800 D HW: 5U0 959 800 D
Component: ZFH_2T H06 0029
Serial number: 3982FL00001610180138
Coding: 00EB33
Subsystem 2 - Part No SW: 5U0 959 800 D HW: 5U0 959 800 D
Coding: 00EB33
Subsystem 3 - Part No: 5Z0 947 105 E
Component: DWA-Sensor 00 003 0008
Subsystem 4 - Part No SW: 18D 959 442 HW: 18D 959 442
Component: E221__MFL-YLG H01 0110
Serial number: 000000000A0483260516
Coding: 200000
2 Faults Found:
03301 - Response Closing Status of Drivers Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 47
Mileage: 7366 km
Time Indication: 0
Date: 2012.14.19
Time: 16:22:07
03302 - Response Closing Status of Passenger's Door
Fault Priority: 2
Fault Frequency: 2
Reset counter: 47
Mileage: 7366 km
Time Indication: 0
Date: 2012.14.19
Time: 16:22:07
Address 10: Park/Steer Assist (J446) Labels:| 5U0-919-475.clb
Coding: 10000C
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Component: KOMBI H06 0007
Coding: 870A02
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04726
ROD: EV_Kombi_UDS_VDD_RM09_VW23.rod
Serial number:
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
Fault Status: 00110100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 35
Mileage: 10522 km
Time Indication: 0
Date: 2014.14.19
Time: 14:17:18
End-------------------------(Elapsed Time: 02:58)--------------------------
Posted: Sun Feb 18, 2018 7:07 am
by ciclo
When making an VCDS autoscan, the first thing you always have to do before clicking on the Start button is Clear all DTC's to avoid writing sporadic and intermittent faults. In this way only permanent faults will be present. (in your case, all faults should disappear)
So:
- Click on the Gateway Installation List. You'll get the units with their status (OK, malfunction, can't be reached).
- Click on Clear all DTCs in case of any malfunction. (Twice if necessary)
- With Auto-detect (CAN only) selected click on Start to scan all the units.
- Save.
There are still missing units
have you selected Auto-detect?
Posted: Sun Feb 18, 2018 5:22 pm
by BARBUDO
Autoscan with auto-detect and DTCs codes cleared. Now i'm very enthusiastic, yesterday i could code the 56 - Radio module. Two months ago i purchased an original VW radio (rcd340) from another car, and everytime i put reverse, the radio said the camera is not installed, because the radio was installed originally in a VW whit rear view camera. I unchecked whit VCDS the bit, and now the message dissapeared. Now CCS i go for you.
Sunday,18,February,2018,12:44:13:00001
www.Ross-Tech.com
Mileage: 10520km-6536mi Repair Order:
Chassis Type: 5U-VW23 (7E0)
Scan: 01 03 04 09 10 15 17 19 25 56 0B
56-Radio -- Status: OK 0000
Revision: --H07---
Readiness: 1110 0001
Coding: 00EB33
Coding: 00EB33
Coding: 200000
Coding: 10000C
Coding: 870A02
Part No SW: 7E0 909 901 HW: 7E0 937 089
Revision: BB080001
Coding: 002000
VCID: 68DE803C9B73DA0622-803C
Serial number:
End-------------------------(Elapsed Time: 02:41)--------------------------
Posted: Sun Feb 18, 2018 6:23 pm
by ciclo
Let's go for it!
You must be very precise with the CCS wiring manufacture and installation, the crimp of the MQS and ECU terminals must be perfect so that they can be inserted with total precision into the connectors. 70% of the success in this installation depends on it.
You can take
these images as a reference.
Keep us informed.
Posted: Sun Mar 04, 2018 7:37 pm
by BARBUDO
I'm still awaiting for delivery. Stalk is coming too.
