Skoda Fabia VRS 2012. Auto lights retrofit OEM
Re: Skoda Fabia VRS 2012. Auto lights retrofit OEM
You must tell me if the dynamic cornering lights work or not and under what conditions.
7A980BB848010000013806B03EEB9BC052C0623F60042041200400020000
VASILEIOS1972
- Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
my friend in two cases with old or new bcm coding,ciclo wrote: Sat Feb 08, 2020 9:32 am You must tell me if the dynamic cornering lights work or not and under what conditions.
address 55 performs out put tests with success
the problem is the 2 bcm errors with new coding that provide me recently
VASILEIOS1972
no errors , but no functions
Therefore, with the old BCM coding, the projectors rotate whether you turn the steering wheel or if you put the turn signals... is it correct?VASILEIOS1972 wrote: Sat Feb 08, 2020 9:48 ammy friend in two cases with old or new bcm coding,ciclo wrote: Sat Feb 08, 2020 9:32 am You must tell me if the dynamic cornering lights work or not and under what conditions.
VASILEIOS1972
in neither of the two cases
only when I am doing with vag com out put tests
VASILEIOS1972
Well, the bytes involved in the cornering lights are Byte12 (activation), Byte19 (diagnosis) and Byte21 (when put the turn signals).
Because of what you have said previously, it seems that none of these Bytes is for dynamic cornering lights, only for static cornering lights.
VASILEIOS1972
so my friend what must do now ?ciclo wrote: Sat Feb 08, 2020 10:08 am Well, the bytes involved in the cornering lights are Byte12 (activation), Byte19 (diagnosis) and Byte21 (when put the turn signals).
DCLs and SCLs work if the lights are on, that is, with the light switch in the Low Beam position or in AUTO 'ON' position.
I guess that's how you're doing the tests, right?
VASILEIOS1972
yes my friendciclo wrote: Sat Feb 08, 2020 10:21 am DCLs and SCLs work if the lights are on, that is, with the light switch in the Low Beam position or in AUTO 'ON' position.
Test
What happens if you enter this BCM coding?
7A980B3848010000013806B03EEB9BC052C0621F60802041200400020000
VASILEIOS1972
Hello Fernando again , I tried the new bcm coding but for another time the 2 errors insists .
best regards
Vasilis
best regards
Vasilis
... and what happens if you enter this BCM coding?
7A980B3848010000013806B07EEB9BC052C0621F60002041200400020000
Explanation: I am trying to know if any type of BCM coding for DCLs would not even be necessary. (to differentiate the DCLs from the SCLs)
I guess you're inside a garage and you're looking on the wall if the light patterns projected by the headlights move when you turn the steering wheel.
Output tests with VCDS suggest that steering wheel angles (data) do not reach the 55 unit in normal conditions.
Do the G85 Basic setting (03 Address) again.
According to the video (Roomster)...
... the DCLs and SCLs move/ON from a steering angle of very few degrees, I would even say that from 0->1 degrees of steering angle.
If someone remembers this discovery ... viewtopic.php?f=56&t=58703&p=517482#p517482 ✌
BCM adaptation (PQ25):
Channel 33 Angle required to activate the static cornering lights. Factory setting = 80º
Channel 34 Angle required to deactivate the static cornering lights. Factory setting = 30º
What would happen if you set the value of these two channels to 0 or 1?
