diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
Adam87 wrote:The split Disciver pro system won't work as it MQB platform, you need the single unit Discover media as that is PQ platform,
It's working in a Polo 6C and that's not a MQB car...
Never the less, I'll got it a try tomorrow :)
CNK
Drives: 6R
Post by CNK »
Our instrument clusters from Polo 6R doesn't support CP, but this is available in PQ25 Amarok's IC (since 2015).
diskoboy wrote: It's working in a Polo 6C and that's not a MQB car...
Polo 6C is MQB :idea: :lol:
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
This is getting interesting. [emoji1360]
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
CNK wrote:Our instrument clusters from Polo 6R doesn't support CP, but this is available in PQ25 Amarok's IC (since 2015).
Not according to https://en.m.wikipedia.org/wiki/Volkswa ... B_platform
'Polo 8' (or whatever it's callled after 6C) will be a MQB car. 6C is something in between.
CNK
Drives: 6R
Post by CNK »
diskoboy wrote:Not according to https://en.m.wikipedia.org/wiki/Volkswa ... B_platform
No, 6C is other platform than 6R :wink:
Look at any log from VCDS, e.g.:
Address 17: Instruments (J285) Labels: None
Part No SW: 6C0 920 741 A HW: 6C0 920 741 A
Component: KOMBI 211 0260
Coding: 072409003580000800886A011000000000000000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_DashBoardVDDMQBAB 009036
ROD: EV_DashBoardVDDMQBAB_VW26.rod
VCID: 2142FD5F3008A232AC-8074
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H06 0046
Revision: -------- Serial number: 007278020956
Coding: 030100044F0A590071000000800000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear.rod
VCID: 65CAA94F64A08E1210-8030
Multifunction unit control module:
Subsystem 1 — Part No SW: 6C0 959 442 B HW: 6C0 959 442 B
Component: E221__MFL-TAT H03 0015
Serial number: 1431405261600586AF1B
Coding: 2C0000
Subsystem 2 — Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 51157C55592821366669
:arrow: viewtopic.php?p=510472#p510472
iichel wrote:The all-on-one headunit is the PQ version like T6, Scirocco, Beetle.
The split unit like Polo 6C, Golf 7 etc is the MQB version. Keep this in mind.
:arrow: viewtopic.php?p=506475#p506475
:arrow: http://forums.ross-tech.com/showthread. ... #post29380
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
Yep - I can see the component in gateway says MQB, but then it's funny that all other sites says that only the next Polo is a "real" MQB then...
Just a few links:
https://de.wikipedia.org/wiki/Modularer_Querbaukasten
http://www.autoexpress.co.uk/volkswagen ... -supermini
+ english wikipedia
In case Wikipedia should be wrong, it would be nice if you would take the time updating the UK and DE site :-)
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
In my opinion, the letters MQB mean, first of all, the body platform with specific type/modification. Of course, the electric systems was designed also new for it. So Polo 6C got face-lifted but old body, but it took new electric systems (from Mqb). Next one will be MQB fully.
CNK
Drives: 6R
Post by CNK »
most of the parts in the Polo 6C are from MQB platform.
Polo 6C has got BCM PQ26, like new Skoda Fabia:
50% MQB + 40% PQ26 + 10% PQ25
log from Fabia III:
Monday,13,July,2015,22:04:00:12646
VCDS — Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
Workshop Code: 048 00567 000001
VIN: TMBEN6NJ9FZ053196 License Plate:
Chassis Type: NJ (6C0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 44 5F
VIN: TMBEN6NJ9FZ053196 Mileage: 55km-34miles
01-Engine — Status: OK 0000
02-Auto Trans — Status: OK 0000
03-ABS Brakes — Status: OK 0000
05-Acc/Start Auth. — Status: OK 0000
08-Auto HVAC — Status: OK 0000
09-Cent. Elect. — Status: OK 0000
10-Park/Steer Assist — Status: OK 0000
13-Auto Dist. Reg — Status: OK 0000
15-Airbags — Status: OK 0000
17-Instruments — Status: OK 0000
19-CAN Gateway — Status: OK 0000
2B-Steer. Col. Lock — Status: OK 0000
44-Steering Assist — Status: OK 0000
5F-Information Electr. — Status: Malfunction 0010
Address 01: Engine (J623-CJZD) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 BC HW: 04E 907 309 AF
Component: 1.2l R4 TSI H22 8229
Revision: R4H22---
Coding: 01250032232415080000
Shop #: WSC 73430 031 00047
ASAM Dataset: EV_ECM12TFS01104E906027BC 001006
ROD: EV_ECM12TFS_VW26.rod
VCID: 66C387B29956AB11F43-8033
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 046 P HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 6221
Revision: 00043014 Serial number: CU501503095305
Coding: 0014
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_AU37.rod
VCID: 479D6A36FE9C9219EF5-8012
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6C0 907 379 G HW: 6R0 907 379 BA
Component: ESP9.0i H03 0003
Serial number: 08501848150314
Coding: 41F5487D892833C3111510720057821291CC8808000DCBF98F00
Shop #: WSC 13765 031 00047
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
ROD: EV_Brake1ESP90iBOSCHPQ26_SE26.rod
VCID: 33652EE69A040EB9A3D-8066
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0362567493
Coding: 030C0C
Shop #: WSC 13765 790 00047
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_SK26.rod
VCID: 3A7B03C2BD6EFFF160B-806F
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 6V0 907 044 HW: 6V0 907 044
Component: Climatronic H01 0201
Serial number: 1503121A-0409
Coding: 100000001011100001
ASAM Dataset: EV_ACClimaValeoPQ26 003001
ROD: EV_ACClimaValeoPQ26.rod
VCID: 74E7EDFADF8A49817A7-8021
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 6C0 937 090 B HW: 6C0 937 090
Component: BCM PQ26 HiKR H07 0065
Serial number: 001108013121
Coding: 0C011850421509FB03A04080B10703081800D900D70A3500000000000000
Shop #: WSC 73430 790 00047
ASAM Dataset: EV_BCMA0 004008
ROD: EV_BCMA0_SK26.rod
VCID: 275DCAB65EDC72190F5-8072
Subsystem 1 — Part No SW: 6V1 959 801 B HW: 6V1 959 801 B
Component: FHSG DRV 007 0001
Serial number: 00000000000000988729
Coding: 011200
Subsystem 2 — Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1502014L9
Subsystem 3 — Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000031977943
Subsystem 4 — Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 21036703
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 7K H03 0048
Revision: -------- Serial number: 39391506401416
Coding: 0011051051
ASAM Dataset: EV_EPHVA18AU3700000 002024
ROD: EV_EPHVA18AU3700000.rod
VCID: 3D7108DEAC40C8C9459-8068
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 26021503272528
Coding: 00001000FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001015
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 387F19CA8362EDE196F-806D
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 F HW: 6C0 959 655 F
Component: VW20Airbag733 001 0360
Revision: -------- Serial number: 003RJ001DYLW
Coding: 88CCC000000000005C5400CF000800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X_SK26.rod
VCID: 366317F289761B91843-8063
Crash sensor for side airbag; driver side:
Subsystem 1 — Part No SW: ----------- HW: 410 821 103 15
Component: SideSensor_Df 151 0800
Serial number: 3575H000428BCCA2A0F.
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 2 — Part No SW: ----------- HW: 410 821 103 15
Component: SideSensor_Pf 151 0800
Serial number: 3585H000228BCCA1D3B.
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 3 — Part No SW: ----------- HW: 442 151 403 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00991A728309277
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 — Part No SW: ----------- HW: 442 151 403 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00991A72831D217
Coding: 2D2D2D
Part No SW: 6V0 920 740 HW: 6V0 920 740
Component: KOMBI 214 0290
Coding: 072401182180000801882A011000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_SE25.rod
VCID: 72EBEBE2A59E47B168B-8027
Part No SW: 6C0 909 901 HW: 6C0 937 090
Component: GW MQB A0 H07 0065
Revision: -------- Serial number: 001108013121
Coding: 030100042F0A640000000000000000010001050000000000000000000000
ROD: EV_GatewA0Lear_SK26.rod
VCID: 65C180BE6450A009FD9-8030
Subsystem 1 — Part No SW: 5E0 919 719 B HW: 5E0 919 719 B
Component: E221__MFL-PR6 H04 0100
Serial number: 000000000A0038270712
Serial number: 62068301262821636139
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000060480004
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_SE25.rod
VCID: 34672DFA9F0A0981BA7-8061
Address 44: Steering Assist (J792) Labels: Redir Fail!
Part No SW: 6C1 909 144 M HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3211
Serial number: CF3L0086
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_SK26.rod
VCID: 326B2BE2651E07B1A8B-8067
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5Q0 035 820 HW: 5Q0 035 820
Component: MU-S-D-ER H11 0137
Serial number: SKZAZ2R0078849
Coding: 03620000BE0000001111120400880A002F0100C40120010000
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_SK26.rod
VCID: 68DF898A9342BD61C6F-803D
Media Player Position 1:
Subsystem 1 — Part No SW: 6V0 919 604 HW: 6V0 919 604
Component: ABTm_Std2 H40 1022
Serial number: SKZ8Z9RH300DWZ
1 Fault Found:
1637 — Interface for External Media
U11B8 00 [008] — No Communications
Intermittent — Confirmed — Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 46
Mileage: 18 km
Date: 2015.04.20
Time: 17:08:15
End-------------------------(Elapsed Time: 03:14)--------------------------
Polo 6C
Chassis Type: 6R (6C0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 55 5F
55-Headlight Range — Status: OK 0000
5F-Information Electr. — Status: OK 0000
Address 01: Engine (J623-CZEA) Labels: 04E-907-309-
V1.clb
Part No SW: 04E 906 027 AT HW: 04E 907 309 AB
Component: 1.4l R4 TSI H21 8236
Revision: R6H21---
Coding: 01250032236419080000
ASAM Dataset: EV_ECM14TFS01104E906027AT 001008
ROD: EV_ECM14TFS01104E906027AT.rod
VCID: 76CD1569C9D62B8849-8023
Part No SW: 0CW 300 046 Q HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 6220
Revision: 00043014 Serial number: CU501501135467
Coding: 0014
VCID: 48B1AB91F3A2ED78EB-801D
Part No SW: 6C0 907 379 H HW: 6C0 907 379 B
Component: ESP9.0i H01 0003
Serial number: 08501601150112
Coding:
23DD48858B2833C71116106A0058C412D1CC8808000ACBFD8F00
VCID: 3449EF619F2A7998B7-8061
Part No SW: 6C0 907 044 A HW: 6C0 907 044 A
Component: Climatronic H02 0105
Serial number: 1501203A-0100
Coding: 200000001001000001
VCID: 2265193935DEE72855-8077
Part No SW: 6C0 937 089 B HW: 6C0 937 089
Component: BCM PQ26 Hi4R H07 0065
Serial number: 001098051609
Coding:
03001A5042132AFB0B244080B12F07C810005B0257010000000000000000
ROD: EV_BCMA0_VW26.rod
VCID: 2F43E00D760C5A40CA-807A
Slave 2:
Subsystem 1 — Part No SW: 5Q0 955 547 A HW: 5Q0 955 547
A
Component: RLHS 037 0059
Serial number: S5Y15M01D24H03M50S34
Coding: 0038DD
Subsystem 2 — Part No SW: 6R0 959 802 CK HW: 6R0 959 802
CK Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 9620
Serial number: KU0KU025061441767909
Coding: 1400A1
Subsystem 3 — Part No SW: 6R0 959 801 CH HW: 6R0 959 801
CH
Component: J387__TSG_BT 003 9620
Serial number: KU0KU025061441766145
Coding: 0400A1
Subsystem 4 — Part No SW: 6C0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY14338179Y
Subsystem 5 — Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000031477009
294.clb
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391502001201
Coding: 0031151011
VCID: 3D5FCA45AC60B8D048-8068
572.clb
Serial number: 17011503213494
VCID: 3851DB5183429DF89B-806D
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag010 001 0330
Revision: -------- Serial number: 003LM008FL04
Coding: 88C0C000000000005C000000008800000000
VCID: 3147E67560384CB0DC-8064
Subsystem 1 — Part No SW: ----------- HW: 410 820 701 15
Serial number: 3575H009D1885F4291F+
Coding: 2D2D2D
Subsystem 2 — Part No SW: ----------- HW: 410 821 201 15
Serial number: 3585H00BB16DB7D3724+
Coding: 2D2D2D
Subsystem 3 — Part No SW: ----------- HW: 442 151 701 15
Serial number: 3517A00B5183BFD6B2A-
Coding: 2D2D2D
Subsystem 4 — Part No SW: ----------- HW: 442 151 001 15
Serial number: 3527A00C7183ADF443BW
Coding: 2D2D2D
Address 17: Instruments (J285) Labels: 5G0-920-XXX-
17.clb
Part No SW: 6C0 920 940 A HW: 6C0 920 940 A
Component: KOMBI 211 0290
Coding: 272D01082D80260001882A011000000000000000
Revision: -------- Serial number: 001098051609
Coding:
030100047F0A560071000000000000010001010000000000000000000000
ROD: EV_GatewA0Lear_VW26.rod
VCID: 65EF42256470D010F0-8030
Subsystem 1 — Part No SW: 6C0 959 442 D HW: 6C0 959 442
D
Component: E221__MFL-DC1 H03 0039
Serial number: 27140002455720054417
Coding: 35FFFF
A
Serial number: 62023345072821382716
Part No SW: 6C2 909 144 M HW: 6C2 909 144 D
Component: EPS_TRW_ALow 321 3211
Serial number: CF210824
Coding: 0007
ROD: EV_SteerAssisUDSTRW_VW26.rod
VCID: 334BEC7D9A247EA0AE-8066
Address 55: Headlight Range (J431) Labels: 5Q0-907-
357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 0D8E000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
VCID: 75CF1265D4D0209040-8020
Part No SW: 3Q0 035 842 HW: 3Q0 035 842
Component: MU-S-D-ER H04 0135
Serial number: VWZAZ2P4554164
Coding: 02620000BE00000011111201000808001F0100D60120010000
ROD: EV_MUStd4CTSAT_SK35.rod
VCID: 6AF531198D6EFF68DD-803F
Subsystem 1 — Part No SW: 6C0 919 603 B HW: 6C0 919 603
B
Component: ABTm_Std2 H43 1017
Serial number: VWZ8Z9RH1003LH
source: https://www.drive2.ru/b/2157503/
BCM from Polo 6R/T6:
BCM from Polo 6C:
Image Image
6C BCM is very similar to the BCM from Golf 7:
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
Fair enough... electrically it looks like MQB...
Discovery Pro is not working together with the 7E0 BCM. Let's just close that one.
I have tested all can-busses and none of them can communicate with the 7E0 BCM.
benzinkopf
[emoji29][emoji24]
firegrafik
benzinkopf wrote:[emoji29][emoji24]
Don't worry, there is some possibility to retrofit Discovery media 5C0035680C.
Of course It has Component Protection and we need to have Instrument Cluster with supports it also.
Yes, maybe it is possible, it is necessary to do a series of tricks, which I can not remember now, with another original unit already installed from the factory in another car that does not yet have component protection activated.
Then there is someone (in this vwonderful world) who modifies your 'new unit' so that it can work in your car with data collected from the other factory unit, or so. :lol:
CP = In my humble opinion it is not legal under any circumstances. In any case my opinion is irrelevant.
hmm ... I fear that my next car will be a bicycle without communications systems.
Image Image
Info
NEW STEERING WHEEL MODELS on PQ25/26 platform (2015--->). Factory coding.
Polo 6R: (PQ25)
Leather
6C0959442...(no CCS)... 240000 (Ind,Rus,Mex)
Sport. Leather
1K8959442...(no CCS)... A4FFFF (Sedan GT)
Mandatory BCM 2015---> for the buttons backlighting.
Transporter T6: (PQ25)
Leather
2H0959442...(no CCS)... A4FFFF
7E0959442...(CCS)... B0FFFF , B1FFFF (dsg)
7E0959442A...(ACC)... B4FFFF
With CCS/ACC buttons on MFSW (not in stalk) LIN-Bus buttons wire goes to T73b/36 (in case of Euro6 emissions -Erwin-), BCM coding Byte17 Bit2,7 and Byte29 Bit6
CCS wire goes directly to ECU from T41/11 connector/slot (usually for Petrol T94/45, for Diesel T94/64, not in all cases, better check/ask wiring diagrams)
According to this my 1.2 TSI CBZC petrol engine complies with Euro6 emissions and I could to install a multifunction steering wheel with CCS buttons on my Polo 6R. :?
Polo 6C: (PQ26)
Leather
6C0959442...(no CCS)... ?
6C0959442A...(CCS)... 280000 (also Jetta PQ25)
6C0959442B...(ACC)... 2C0000
Sport. Leather
1K8959442...(no CCS)... ?
6C0959442C...(CCS)... 30FFFF , 31FFFF (dsg)
6C0959442D...(ACC)... 34FFFF , 35FFFF (dsg)
Does anyone know why the 6R WRC does not have TPMS?
I don't know but wondered about the same. They all have the ESP 9.0i so the hardware is there. It seems to be in the long coding of the last byte. They all end with 0904 in the last two bytes so it's not activated.
Maybe it is the combination of high torque and low volume tires (18") that makes the system too sensitive to small pressure fluctuations?
They don't have an active system, as far as can be seen on Autoscans. But it's odd; in many countries, having a TPMS is mandatory since many years.
Locked
