ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Locked
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
iichel wrote: Sun Nov 29, 2020 9:41 am We have the same nonsense here, so I decided to register myself as an independent car shop at the Chamber of Commerce. This way I'm able to order parts at the VW dealer. At a discount too!
Well, my official VW dealer, and in deference to the large number of parts (and cars) that I usually request from them for years, they also applied the discounts to me as if I were an independent workshop. (I am not dedicated to car repair)
I'm also registered in VW Pro service, but they do not apply any discount and I have the feeling that the parts have an 'extra cost'. :evil:
On the other hand, there is the question related to the fact that VW Pro Service also sells non-original parts that are not contemplated in the VW repair manuals. This I consider to be a degradation of customer service by VW. Hence, I contribute to this action with my actions, buying in Aliexpres, amazon, eBay, etc ... which means a huge amount of taxes that flow to other places that are not the welfare of Europeans.
I think that currently the European Union is legislating so that parts can be repaired without using special tools to avoid all the electronic waste that we generate. Something that will greatly benefit those of us who make retrofits without the intention of making money. (plug and play 😂).
Sub
:lol:
:arrow: viewtopic.php?p=577791#p577791
- Easy to remove and put back.
- It fits perfectly, does not produce additional noise.👌
Golf 7.5 Driving MODE Selection. OK!
Previous info:
:arrow: viewtopic.php?p=577258#p577258
:arrow: viewtopic.php?p=577701#p577701
:arrow: viewtopic.php?p=577859#p577859
In my case, at the moment it operates on these systems.
The Sport and Eco modes for ACC are the most appreciable.
The most notable thing from the outset is on the steering wheel in Sport mode.
In ECO mode with ACC activated it makes very low consumption values.
According to instructions manual, before activation using ODIS S online with the codes provided, it is necessary to code the units involved. It can be done online by connecting to VW servers, but it is better, easier, and more effective to introduce the new codings/adaptations without this 'help'.
I did it with VCDS (with beta labels), and it worked perfectly.
In my case:
0009 - Central Electrics
Adaption
[VN]_Center_Console_Buttons:
[LN]_Function_button_3: [VO]_0_not_defined [VN]_Driving_programm
[VO]_Personalisierung:
[LO]_Personalisierung_Profilfunkion: [VO]_profiles_inactive [VO]_profiles_active
[LO]_Profil_Variante: [VO]_Schluessel [VO]_Konto (v. 1.x)
[LO]_Personalisierung_aktiv: [VN]_not_active [VN]_active
0013 - Adaptive Cruise Control
coding
[LO]_Drive_pmode_selection: [VN]_MMI_menu_ACC [VN]_Driving mode selection
0019 - Gateway
coding
[LO]_FPA_Funktion: [VN]_not active [VN]_active
[LO]_FPA_Funktion_RGS: [VN]_not active [VN]_active
[LO]_FPA_Funktion_ACC: [VN]_not active [VN]_active
0044 - Steering Assist
coding  (SA)
Byte0 Bit7 - enabled
VCDS autoscan. After online activation, and tests.
Monday,30,November,2020,17:36:12:32438
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4526.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOw   License Plate: FPA OK!
Mileage: 34402km-21376mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 3C 42 44 52 5F 65
VIN: WVWZZZAUZKPCICLOW   Mileage: 34402km-21376miles
42-Door Elect, Driver -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92325D-807C
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A4082430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DB78F-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 00020003200110011005004000101022
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6D8734C87D161503895-8038
   Fresh Air Blower Front:
   Geber für Kältemitteldruck/Kältemitteltemperatur:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0312
   Serial number: 72007150025702
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 015F7878518EE1635DD-8054
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043  0551
   Serial number:         180705074106
   Coding: 0E4DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052  0107
   Serial number: SBY18M08D06H04M32S34
   Coding: 06A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0060
   Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417318277
   Coding: 0271165841
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 51FF8838C16ED1E38DD-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B00678119FFC728949C810560400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D1B16C0E1C344B36B-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA92305D-805C
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Side Sensor Driver Front:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 750 D    HW: 5G1 920 750 D
   Component: KOMBI         310 2700
   Coding: 07A52A802688000801887A0D1401000000000000
   Shop #: WSC 00200 935 01530
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 280905DC9274F02B3A3-807C
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 09012020001767
   Coding: 030100047F085700DB00025C080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B92DBC6A24F8EBA23-8024
   Alternator:
   Component: 4-01-02-01-04
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190002063230049307
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
   Part No SW: 3G0 857 511 BD    HW: 3G0 857 511 BD
   Component: FLA           H01 0010
   Revision: AA001001
   Coding: 0404000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B833AD043021B33971-803E
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0519386082
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C4886DF64583795-8068
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0519601132
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000305474246
   Coding: 00150320D000048000001000
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 48C9A55C3234102BDA3-801C
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 831F0000
   Shop #: WSC 12345 102 209715
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3F35F1-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000336638884
   Coding: 00150320DE00048000001000
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 47CBA6603F2A1F53D39-8012
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Serial number:
   Coding: 02731001FF0000005111000100880A001F0500D401200100CF
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323DE7B4A4A88AFB947-8066
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data medium:
   Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000250801
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1AC5EBC84CB86B-8060
End----------(Elapsed Time: 01:22, VBatt start/end: 14.4V/14.4V)-----------
Works like a charm! 8) :D
My deepest thanks to Slavik (Madwarlock) for his invaluable help and for making this another very good experience between us.💎
We suffer inconveniences of all kinds beyond our control, ... and thus we learned everything there is to know about it. Perfect! :lol:
MOST (FOC)
1->2
2->1
Golf 7.5 How to feed the lighting of the front dome lights buttons.
:arrow: viewtopic.php?p=577772#p577772 :lol:
* Only for front dome lights models with factory LED lights, or front dome lights models with existing pin 3 on the T6 connector.
On some Golf 7.5 models, a wire is missing from the blue T6 connector for the front dome lights.
Add a new 0.35 - 0.5 mm2 wire from slot 3 of the blue T6 front dome lights connector to the 62 wire that reaches the BCM T73C connector, or to T10/10 wire in lights switch connector.
With good crimping tools I recommend add/splice the wire to the T73c/62 wire.
Contact terminals: MQS
In this way, the backlighting of the front dome buttons will function in the same way as the rest of the backlighting of interior switches (adjustable backlighting by menu 5F or knurled switch-knob)
Making progress with other more important retrofits mentioned above in this thread, slowly but surely. :)
It's the small details that make the difference
Yes, those little details.
I have attached this wire with 58d signal to the wiring for the A5 camera, so that all the wires go in the same wiring that I have to run from the roof to the bottom of the A-pillar. ('OEM way' 😄)
I remember when I installed the CAN lines for the Light Assist that the A-pillar upper trim clips have a trick to remove them. They have a double grip, I suppose for accident-related issues.
I think I remember pulling the trim first until the first hold of the metal clips is released, this action frees/clear a gap between the pliar A and the trim, then with a screwdriver or fine pliers or plastic tool is slided the metal clip from the plastic tabs of the trim (avoiding damaging the A-pillar airbag with the tools used).
These chimpanzee jobs are the ones I like the most, the challenge is not to break or damage any plastic. :mrgreen:
Golf 7.5 AID + Frame
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/xb6p8CI78 ... autoplay=1
:mrgreen:
AID frame.
Golf 7.5 Active Info Display OK!
Previous info:
:arrow: viewtopic.php?p=577971#p577971
:arrow: viewtopic.php?p=578217#p578217
Tomorrow I will install the frame. :lol:
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 404 4191
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
VCID: 2B03FAD08382DB33F60-807E
Sunday,13,December,2020,18:15:59:32438
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: AID OK!
Mileage: 34463km-21414mi   Repair Order:
VIN: WVWZZZAUZKPCICLOW   Mileage: 34463km-21414miles
   Revision: D7H20000
   VCID: 290F00D8897EC92304C-807C
Readiness: 0000 0000
   VCID: 76B51BA40840D6DB59E-8022
   Revision: 00001K08
   VCID: 6D8734C87D161503A84-8038
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 015F7878518EE1637CC-8054
   Wiper motor control module:
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Coding: 06A8DD
   Coding: 0271165841
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF8838C16ED1E3ACC-8004
   VCID: 44D1B16C0E1C344B17A-8010
   VCID: 094F605869BEA92324C-805C
   Left seat belt tensioner:
   Coding: 333135
   Right seat belt tensioner:
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   VCID: 70B92DBC6A24F8EB832-8024
   Generator:
   Multifunction steering wheel control module:
   Coding: 2CFFFF
   Revision: AA001001
   VCID: 6B833AD043021B33B60-803E
   Coding: 02011103
   VCID: 3D27C4886DF64583584-8068
   Lane change assistance control module 2:
   Coding: 020111
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 48C9A55C3234102BFB2-801C
   Rear Driver Side Door Control Module:
   Coding: 010000
   Coding: 831F0000
   VCID: 73B322B01B32C3F37E0-8026
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 47CBA6603F2A1F53F28-8012
   Rear Passenger Door Control Module:
   Coding: 090000
   Serial number:
   Coding: 02731001FF0000005111000100880A001F0500F401200000CF
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFBB56-8066
   Display and control head 1 for information electronics:
   Data carrier:
   VCID: 3431E1AC5EBC84CBA7A-8060
End----------(Elapsed Time: 01:22, VBatt start/end: 14.3V/14.4V)-----------
Works like a charm!
My sincere thanks to Madwarlock, once we were properly connected he took care of everything ... he was fast, efficient and as always very pleasant.💎 8)
Ready, set, g ... 🏎
Golf 7.5 leather armrest. OK!
Previous info :arrow: viewtopic.php?p=577396#p577396
Just swap out the original pad for the original leather pad, by removing the bottom cover, the two screws and releasing the two tabs.
Quick and easy.
An image from a youtube video:
:arrow: https://www.youtube.com/watch?v=6jVLxZK1rIM
Other way :arrow: https://www.youtube.com/watch?v=gQVn5WjPE7w
This would be my suggestion for bending the metal tabs (locking lugs):
Suitable pliers ... erWin
Nobody has those suitable pliers... 🤣
Logbook. VW PRO Service.
On December 3, 2020 I ordered a part from the local VW PRO Service store, I had to pay for the part at that time, today is December 18, 2020 and I have not received the part I paid for yet.
5G0868437A Y20
Terrible service.💩
My life does not have time to have to wait and waste time on these trifles.
This NEVER happened to me at my VW dealer, which I no longer go to since I can't order parts from them.
BTW, I miss seeing the new cars that my VW dealer had on the exhibition.
:oops: :mrgreen:
Locked
