firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
wamba wrote:
You can ask ZZZhuk if there is a way to display the high cruise control in MFA+
Already asked. He doesn't know the way.
wamba
Drives: polo 1.2tsi
Post by wamba »
:wink:
Question for the experts...
Currently helping someone to fit the battery in the boot of a polo 1.2 TSI
There is the fuse retainer 6R0915343C
On the bottom, there is a two pin connector, I suspect for a 1J0 973 752.
But I really don't know what to connect it to. Does anyone have an idea?
iichel wrote:Question for the experts...
N253 E74 :mrgreen:
I'm not so sure. The battery isolation bomb 4F0915519 is located on the plus terminal on the battery 8J0915459.
What part of this diagram do not you understand?
Note: The suppression filter -C24- is installed in bracket for fuse holder A -SA- and cannot be replaced separately.
Happy holidays to everyone.
Image :lol:
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote: Adam... it's a nice mod, what do you think? I think it would be good for our Big Brother T5/6. :)
All the best
Fernando
Yes Fernando, I think it would be an excellent addition, part no.s and I'll get looking for parts [emoji6]
Adam87
Drives: T5.2
Post by Adam87 »
iichel wrote:it is only the lights in the mirror
There is also a light for it in the cluster? I'm pretty sure there is
CNK
Drives: 6R
Post by CNK »
Do you have any photos of mirror with this light? What warning lights you used? OEM from Jetta?
I think this will be good for this mod: https://aliexpress.com/item/2-Pcs-lot-1 ... 57101.html
What do you think @iichel? :)
And second question..
Do you know if Travel Mode works with LED headlights in Polo 6C?
Travel Mode in Passat:
Travel Mode in my 6R:
If this isn't possible in Polo, how can I disable this option from the IC menu? :D
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Here you have some photos. I took the OEM way and fitted a pair of 35D959145 and 35D959146
The travel mode also works with the ledheadlights, no problem.
wamba wrote: You can ask ZZZhuk if there is a way to display the high cruise control in MFA+
Hi wamba,
You know I tried many things to get it, also by updating the ECU software at the VW dealer (by pay, OFC), but I was not successful. :(
At that time I also remember that I was going to buy a Polo 6C to replace our Polo 9N3 ... but it did not happen in the same way.
wamba
Drives: polo 1.2tsi
Post by wamba »
It must surely have a solution
I think it just found a way to unlock the channel in adaptation, I try with odis but without result :cry:
Kimd41
Drives: 6R
Post by Kimd41 »
Hey ciclo, greetings from Spain ;)
Your 6R is amazing, thank you so much for posting the guides too! Could you please give me a hand?
I want to install the TRIP stalk for the MFA, but I'm not sure about the 3 cables shown here:
Are they ordinary 'VW Repair Cables" or I need to go to VW and ask them about 'blue/green', etc (color specific) repair cables?
Thank you very much man, and keep the good work!
These repair wires from vw are always in the colour yellow.
The reason that vw uses a lot of colours is to make the identification easier in the factory wiring harness.
For yourself it can be good to note the colour, for later on (repair, diagnostics)
Locked
