Kimd41, everything is solvable in case of faults. In the worst case, return to the previous state.
Btw, I have the control unit and airbag wiring (5K0) from my previous multifunction steering wheel (R model), in perfect condition. Maybe I could sell them to you (very cheap) in case you need them.
Both = 36€ + shipping - Spain - registered with tracking number 4,85€, payment by paypal.
Also, I'll give you three little presents that you'll need to install this MFSW, the two wires (+ and LIN) and the fuse.
Ooooh that would be awesome manciclo wrote:Kimd41, everything is solvable in case of faults. In the worst case, return to the previous state.
Let's just wait for the wheel to arrive, I'll keep you updated.
Thanks and cheers.
Customize VCDS Autoscan
(Dedicated to a friend)
; created many moons ago
(look in the Autoscan text file for better information)
CLICK HERE
Oh! yes...
My dear friend, the small adapter is a little joke, you already know me ... you can use it for whatever you want, you can even throw it away if it is your desire, the joke has fulfilled its mission ...
CLICK HERE
Oh! yes...
Kimd41 wrote: Ooooh that would be awesome man![]()
Let's just wait for the wheel to arrive, I'll keep you updated.![]()
Thanks and cheers.
prog-amateur
- Drives: Polo 6R
Dear Ciclo, CNK, thanks to both of you, I will read more and try to assemble it.
gti16
- Drives: VW Polo 6r 1.6 TDI
There is no error in the modules, everything ok but the battery light does not turn off.ciclo wrote:Maybe it's a coding problem. Have you spoken with firegrafik or ZZZhuk?gti16 wrote:I installed it clear
Negative pole and its connections. It appears on the auto scan but the battery light does not disappear.
Will the alternator with LIN (LIN) be missing?
We are here if you need our help during installation.prog-amateur wrote:Dear Ciclo, CNK, thanks to both of you, I will read more and try to assemble it.
Do a test: (engine OFF)gti16 wrote:There is no error in the modules, everything ok but the battery light does not turn off.ciclo wrote:Maybe it's a coding problem. Have you spoken with firegrafik or ZZZhuk?gti16 wrote:I installed it clear
BCM:
- Enable Byte20 Bit3
- If coding is accepted, make an ignition cycle. (extract the keys from the ignition, etc ...)
- Return to the previous state if nothing happens.
Post here VCDS scan. I think it will help the diviners, magicians, fortune tellers, geniuses and other specimens.
gti16
Thank you, I'll test it tomorrow and then report the situation.
gti16
Ciclo
I do not have bit 3 in byte 20.
OMGgti16 wrote:Ciclo
Put here your BCM coding.
[emoji23][emoji23]ciclo wrote: OMG... everyone has Bit3 in the Byte20
What is byte20 bit3 responsible for?
it indicates the presence of the LIN generator (alternator operated by the LIN databus)
firegrafik, please, can you translate the 0 and 1 Bits?
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
No problem.ciclo wrote:firegrafik, please, can you translate the 0 and 1 Bits?![]()
Bit 0 Alternator with LIN bus installed
Bit 1 Battery/sensor with LIN bus installed
