Adam87
Drives: T5.2
Post by Adam87 »
firegrafik wrote:
ciclo wrote:firegrafik, please, can you translate the 0 and 1 Bits? :wink:
No problem.
Bit 0 Alternator with LIN bus installed
Bit 1 Battery/sensor with LIN bus installed
Guessing that also has to be selected for battery regulator?
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
Adam87 wrote: Guessing that also has to be selected for battery regulator?
Yes, and not only in 0 Byte.
The coding in all bytes should filled.
On the picture above is coding for T6
Adress 61 coding for T6:
byte 0
bit 0 generator with LIN connection installed
bit 1 battery/current sensor with LIN installed (in the negative pole of the battery)
byte 1
bit 0 start/stop with voltage/current sensor installed
bit 1 recuperation installed
bit 2 history storage (MY 2012+)
bit 3 extended recuperation active
bit 5 FSI engine
byte 2
bit 0 battery in boot
bit 1 battery transverse (in combination with bit 3)
bit 3 battery in the front
bit 4 AGM battery OR enhanced flood battery
bit 5 enhanced flood battery
bit 6 enhanced flood battery
bit 3: generator ratio
HEX values:
58 generator ratio 2.38
5A generator ratio 2.4 (all other 4 cyl engines + CFWA)
64 generator ratio 2.50 (1.2l and 1.4 FSI)
73 generator ratio 2.65 (3.6 V6 and V6 FSI)
76 generator ratio 2.68 (110A)
FE generator ratio 4.04 (140A)
PS
gti16
Drives: VW Polo 6r 1.6 TDI
Post by gti16 »
Ciclo
As you can see, everything is correct but the light is always on.
In byte20 it does not have any bit3, how do I then ?.
Sunday,08,January,2017,12:47:26:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ6RZBY158866   License Plate:
Mileage: 75049   Repair Order:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 56 61
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 G    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 9970
   Revision: --H13---    Serial number:
   Coding: 00114016002400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM16TDI02103L 003010
   ROD: N/A
   VCID: 2A5BE4234D0AF24EEA7-807F
No ASAM data for: "EV_ECM16TDI02103L" (VW36 *)
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210248E3417200BA842D12E882D700421300
   VCID: 8603F09335D2762E2EF-80D3
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 387FCE6B8BA650DE6C3-806D
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0715
   Revision: B9074001    Serial number: 0571 116130727
   Coding: 7DB02FB848610E0093380E307CAB8ED80F80610F60862001200000010000
   Shop #: WSC 36457 123 104857
   VCID: 2D51EF3F74E4E5760F5-8078
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 281010 05  54  0403
   Coding: 0E302D
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T
   Component: J387__TSG_BT  006 0902
   Coding: 08BC30
   Subsystem 5 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
   Subsystem 7 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H07 0013
   Coding: 020000
   Subsystem 8 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 35811333101508
   Coding: 308002
   Shop #: WSC 12345 123 12345
   ROD: EV_VW75XParkAssis8K.rod
   VCID: 3B75D167B2907BC6811-806E
   Component: VW10Airbag01M H09 0020
   Revision: --------    Serial number: 003GX00ANB5F
   Coding: 00314D
   ROD: EV_AirbaVW10BPAVW250_VW24.rod
   VCID: 4A9B84A3ED4AD24E0A7-801F
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405B06JDC6PVZ
   Crash sensor for side airbag; passenger side:
   Serial number: 3585HRB4053085G2CH2L
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515RRB405504QLU3P1V
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525RRB405704QLU1PE2
   Part No SW: 6R0 920 861 F    HW: 6R0 920 861 F
   Component: KOMBI         H04 0304
   Coding: 140E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 387FCE6B83A650DE6C3-806D
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-19.lbl
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0715
   Revision: B9074001
   Coding: 002200
   VCID: F0EFB64B2356489EE43-80A5
   Component: IMMO          H04 0304
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EADBA4230D8AB24EAA7-80BF
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H04 5238
   Revision: AB001001    Serial number: VWZ6Z7K3029008
   Coding: 04000440010000A10001
   Shop #: WSC 72796 133 80617
   VCID: 377DCD5786B85FA6659-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V12  8195
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F6DF537EAE897663D9-807A
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H74 0715
   Coding: 16890A5A
   VCID: EBD5A1270A70AB46D11-80BE
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
End   ---------------------------------------------------------------------
maybe try this coding for the 61: 16800A5A
your current coding indicates that your car has the start/stop system, but i guess it doesn't.
your byte 20 bit 3 is set to 0 (off), that is ok.
gti16
Post by gti16 »
iichel wrote:maybe try this coding for the 61: 16800A5A
I already tested all these options in module 61 and the light does not turn off.
Is BCM well configured?
gti16,
...there are several ways to enable bits, via binary, via hexadecimal, via mark the box, or via copying and pasting the full coding.
I think that in the Ross tech page is somewhere explained. :lol:
Test this BCM coding:
7DB02FB848610E0093380E307CAB8ED80F80610F68862001200000010000
(Byte20 Bit3 enabled)
Please, in case of faults, copy and paste them here.
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote:
Does LIN need connecting to the alternator if I don't have start/stop?
Thanks [emoji106]
maybe to someones inspiration:
7L6907155A
7L6864298 9B9
1J0972753
Polo 6R
I think it's a bright idea :-)
Adam87 wrote: Does LIN need connecting to the alternator if I don't have start/stop?
Apparently not. :arrow: https://www.drive2.ru/l/457363852879727312/
BCM 7E0937090B
gti16's BCM
7L3? 7L6? ... unknown.
I guess the parameters from both bcm and both batteries will be different. The question is how to easily :) fix the warning battery light in gti16's 6R (7L3) since it is only a parameter fault, it is not a real warning.
More info:
Adam87
Drives: T5.2
Post by Adam87 »
iichel wrote:maybe to someones inspiration:
7L6907155A
7L6864298 9B9
1J0972753
Polo 6R
Cool [emoji41] I think I may install it in my transporter, what amp is it rated to?
7L6907155A
7L6864298 9B9
1J0972753
Polo 6R
<big ass picture>
it's rated at 150W at 230V, but in the fuse box I took 30A at 12V. The reason is that all the other models with factory fitted 230V sockets (i.e. Golf 7 estate, Touareg) have it on 30A.
The peak current is probably higher than (130W/12V = 11A), due to the transformer. For me, it feels ok to have it at 30A even though it feels a bit over-powered :p
Adam87
Drives: T5.2
Post by Adam87 »
Where did you connect to convenience module pin to? BCM?
No simply to a terminal 15. ;)
gti16
Post by gti16 »
I tested the new code on the BCM and the battery module and nothing happened.
Locked
