Hi Dave, as we are all fans of the PQ25 platform, we'd be happy to help out.
Maybe it's an idea to consider the following things:
a separate topic to attract the right people to it
a complete vcds autoscan so we can see the equipment and error codes
please tell us what exactly you've already done in terms of wiring
i think that's the easiest and most efficient way to solve your troubles :wink:
Kiogen
Drives: Seat Ibiza 6J
Post by Kiogen »
Hi ciclo, im sorry to mess with your topic but i registered to ask if you could help me out.
Is there a way to ask you a few question without be in this topic.
I have a Seat Ibiza SC and there is very few information about it on the web and i think you might be the right one to help me out as is VCDS related.
Thank you in advance and sorry to post here but i can't send PMs yet.
iichel wrote:Hi Dave, as we are all fans of the PQ25 platform, we'd be happy to help out.
+1
I will subscribe to the new topic. Totally willing to help. :wink:
Welcome to the forum Dave. Model Year? Tenth digit/letter of the VIN.
Kiogen wrote:Hi ciclo, im sorry to mess with your topic but i registered to ask if you could help me out.
Welcome Kiogen, do not worry, this topic is available to everyone.
Make your questions.
Remember, more information = better help, so an Autoscan from your Ibiza SC would be the right one to answer your questions accurately.
Dave v
Drives: 6n2
Post by Dave v »
Thanks guys
Van's in bits at the moment, been reading and think I've got what's required to get it back together and scanned.
As suggested I'll start a thread when the scans are available.
Kiogen
Post by Kiogen »
Thank you.
my car is from 2010 but it's the 2011 model as it has B in the 10th letter.
I'm trying to retrofit Automatic Headlights and i already have the light switch, for my car there is a 17pin switch with auto position and i bought it.
the thing is i searched online in a lot of foruns and the only one that gave me a clue was a german or dutch forum but the guy dont answer me and now i've reached a dead end.
I belive i can't attach an autoscan yet.
try this link please https://drive.google.com/file/d/0B6FlhY ... sp=sharing
Bachecco
Drives: Polo 1.2
Post by Bachecco »
hi ciclo, I mounted the front bumper R-line but the shell of fog don't engage well as seen in the photos. Could you help me?
Inviato dal mio iPhone utilizzando Tapatalk
Kiogen wrote: Thank you.
The BCM shown in the autoscan 6R0 937 087 F can not manage the automatic lights.
But if you change the BCM for a model 7H0937089F (for example) you have to modify the original electrical installation of the lights (area BCM-Fusebox-Light Switch and perhaps also the fog lamps wires), because your original wires were made for the previous BCM.
It is possible, but it will take you time ...
Bachecco wrote:hi ciclo, I mounted the front bumper R-line but the shell of fog don't engage well as seen in the photos. Could you help me?
6R GTI, BlueGT and R-line have different fog lamps.
Check it in ETKA online.
CNK
Drives: 6R
Post by CNK »
ciclo wrote:6R GTI, BlueGT and R-line have different fog lamps.
Yes, Fog lights with DRL — Polo 6R R-Line: 6R0 941 061 E + 6R0 941 062 E (https://www.drive2.ru/l/458163472711033418/) ;)
Thanks CNK.
IIRC Bachecco has bixenon headlights :?:... :lol:
In such case: Polo 6R R-Line: 6R0 941 061 F + 6R0 941 062 F (on eBay.de there is a good deal)
antardaksh04
Drives: TSI
Post by antardaksh04 »
Hi Ciclo,
Could you please share details about following part in your wiring
Electric Bridge inserted into J331
From where can I get this part, I am not able to find anything online.
Regards.
I think you need to manufacture it yourself from a piece of wire and two blade terminals
antardaksh04 wrote:Hi Ciclo,
Regards.
ST-120 terminal flat
Perfect for 6R Model Year: A, B, C
For 6R Model Year: D, E, F, etc ... can be used, but it is better and totally advisable to remove the terminals from relay adapter and splicing the cables with a Butt terminal (30Amp, there are many qualities).
(example)
Read here :arrow: 7E0937090B
antardaksh04
Drives: TSI
(example)
Hi Ciclo,
Thanks, I believe it will be difficult to order one piece of this terminal, I will check if its possible to reach behind relay carrier.
Regards.
Kiogen
Post by Kiogen »
ciclo wrote: The BCM shown in the autoscan 6R0 937 087 F can not manage the automatic lights.
I belive that crossing info with your posts i can find the solution, i've been searching in Elsawin and following the wiring i've seen this:
the under is the one that most recembles mine, only missing the T17/8 wire.
https://drive.google.com/file/d/0B6FlhY ... p=drivesdk
and i've crossed it with this one:
https://drive.google.com/file/d/0B6FlhY ... F3U0k/view
the mods that i've done was adding a direct wire to T17/12 and T17/16 and BCM pin T73a/37
and changed the position of originally fitted t17/16 to T17/13.
my lights work like they used to, whereas before the change none worked, the only problem is obviously the auto that doesnt work and if i left it in the auto position the orange auto light wont turn off even with the key off the contact and the car locked.
i think im heading the right direction :D
Locked
