Page 3 of 4
Posted: Fri Jul 15, 2005 3:07 pm
by dxg
That's looking very interesting... Where's the ECU - is it relocated to the interior somewhere?
(BTW - did you get that PM?)
An, on a related note, recevied this in an email with VW this morning:
You will soon hear of developments with the GTI...
:D Deek.
Posted: Fri Jul 15, 2005 4:18 pm
by mfa-polo
That is one hell of a nice polo you have there, must have cost some as well!
Posted: Fri Jul 15, 2005 4:46 pm
by carmadaaron
that is sweeeeeeeeeeet 8)
Posted: Fri Jul 15, 2005 5:20 pm
by ceedubya
the ecu is in the scuttle panel behind the black panel on n/s
the TT clocks are where the airbag used to be on the n/s, i had to put the TT clocks in for the transponder
it never cost that much to do as i did most of the work apart from getting the TT harness converted to plug into the polo fuse box
deek i am sure i replyed to the pm :?
Posted: Sat Jul 16, 2005 10:48 am
by vwclub.gr
What about the battery?
Posted: Sat Jul 16, 2005 10:57 am
by Tigz
polosilver wrote:150bhp from a 1.8T is pretty pathetic if you ask me! 1.6 16v polo is 125bhp and i bet it weights alot less!
Phill.
The 150hp engine is just as tunable as the larger powered models, but were alot more realiable.
Why do you need more than 200hp in a front wheel drive hatchback anyway?
180hp would be avalable witha s imple remap anyway, so its not a big problem.
VW couldnt have given the car any more than that as it would have taken buyers away from the Golf.
Also I have heard rumers of a R Polo that may be built.
That would be intresting :wink:
ceedubya wrote:the TT clocks are where the airbag used to be on the n/s, i had to put the TT clocks in for the transponder
So are you still able to use the Polo Clocks?
Hows that done?
Posted: Sat Jul 16, 2005 6:12 pm
by ceedubya
the battery is now in the boot
may have been able to squeeze it into the front but it looks betta in the boot
the polo clocks are all in place and fully working, getting them to work with the audi stuff was the trickiest part of the whole job because of the candata bus system the polo runs
i went for a TT engine so i can put a bigga turbo on at a later date without having to worry about the bottom end
200 bhp plus in a fwd is good fun and useable
mine will be 225bhp + with the other mods it has and is very good fun, 1st gear is is over before your foot hits the floor but from then on i can get the power down no problem
it will be around 350bhp when i can afford it
it will have a lsd by then too
Posted: Sat Jul 16, 2005 10:09 pm
by Tigz
Rember the quickest 1.8T in a FWD car only had 150bhp.
It was in Ian Carvels 1.8T Lupo Cup car.
Mapped by Jabba Sport, they gave him 150bhp from 2-5k rpm.
He used to be able to go around the track corners in one of three gears, and still have 150bhp.
Thats the way Id be going about it.
Posted: Sun Jul 17, 2005 5:48 am
by bsodmike
Ceedubya, that's heavy...I was thinking about this whole 'transplanting issue'...did you change the drive train, new gear box etc? How long do you figure it would take to get it professionally swapped?
Thanks!
Mike
Posted: Sun Jul 17, 2005 11:09 pm
by ceedubya
i had to change the running to skoda vrs stuff and the gearbox is a TT box converted to fwd
as for the pros fitting one i reckon a good place could do it in a week if they knew which parts to use
i waisted a fair bit of time trying out different parts to see what worked best
Posted: Thu Jul 21, 2005 4:32 pm
by Uk_Polo_GTI
hi, how much is the tottal cost?
Posted: Thu Aug 25, 2005 12:43 am
by ceedubya
i had me polo chipped today :lol:
with the mods already fitted it made 220bhp(1st run) and 218bhp(2nd run) at the wheels BEFORE the rechip
after the rechip they could not get a figure as it was spinning on the rollers in 4th and 5th and when in 6th it was going too fast for the rollers
so i need to find a better rolling road
its a superchip and they say it will give a 40bhp increase
= 260ish bhp at the wheels ??????????????????????
Performance VW
Posted: Thu Aug 25, 2005 4:37 pm
by mfa-polo
Did I see your car in the latest copy of Performance VW? If so, well done!! Nice to see a 9n made it in from the forum.
Performance sounds staggering by the way!
Posted: Fri Aug 26, 2005 12:16 am
by ceedubya
there is a few pics in the current pvw and a full feature in the one due out before e38 show :lol:
Posted: Fri Aug 26, 2005 2:22 pm
by mfa-polo
look forward to reading about that.
