Page 3 of 4
Re: My Shadow Blue GTI
Posted: Thu May 15, 2014 9:47 pm
by funlovincriminal
mattymdm wrote:CrypticG wrote:Many thanks again, the PDF and pictures would be great, if you could post them!
+1
Also a like to where you bought the woofer would be great too. If this is a easy install we definatly be doing it!
Here is the
PDF Manual , you are interested in the first few pages for the diagrams pictures, then pages 17-20 are in English installation instructions
http://freepdfhosting.com/cf1d079bdb.pdf
I bought the unit from a German VAG seller on ebay - here it is
http://www.ebay.de/itm/Volkswagen-Plug- ... 35cb8f959e The unit arrived in literally 2 days from Germany!
Hope this helps for now, I can take more pics of my installation, but i'm not really wanting to take the headunit out again!
As far as hiding the cable, it is easy, there are rails down the side of the car, you just pop the cover off & done. Also didn't have to take glovebox out or anything, very easy instillation if you have the right tools.
Posted: Fri May 16, 2014 6:54 am
by ciclo
Excellent, thanks.
Multilanguage PDF.
My Shadow Blue GTI
Posted: Fri May 16, 2014 9:16 am
by CrypticG
. Is it easy enough to clip all in interior back into place and get the carpet looking like it's not been touched?
Re: Re: My Shadow Blue GTI
Posted: Tue May 20, 2014 12:28 am
by funlovincriminal
Car got a full wash and wax this weekend,
Best wheel cleaner I have ever used.
'bilt hamber' auto wheel
Spray it on it goes purple where there is brake dust and lifts it off, then just rub if required then rinse.
It looked amazing for the first few miles!!
Posted: Tue May 20, 2014 12:51 am
by funlovincriminal
CrypticG wrote:Cheers
Sub goes in spare wheel well under false floor and is screwed in using the spare wheel holding down plastic nut
You wouldn't know there was a sub there
The cable then goes on base of boot, under rear seat. (The amp screws into the base of the sub btw)
Once there it goes into the passenger side sill area. (the plastic lid pops off and the cable is laid in the channel) very easy just a couple of clips, no ripping up carpets.
I then opened the little 'hi vis hatch' door shown in photo above and fed it up under the glove box and into the rear of the stereo.
I then got the manual I uploaded earlier and followed the instructions to plug the wires in the correct places in the back of head unit.
Then i put on some Rock n roll and turned the volume right up to test.
Posted: Tue May 20, 2014 5:16 am
by ciclo
Great pictures and explanation.
My Shadow Blue GTI
Posted: Tue May 20, 2014 7:54 am
by CrypticG
Brilliant. Much appreciated.
Posted: Tue May 20, 2014 8:12 am
by mattymdm
How much did the subwoofer cost you? £££
Posted: Wed May 21, 2014 10:59 am
by funlovincriminal
Sent from my Nexus 5 using Tapatalk
Posted: Fri Feb 16, 2018 9:57 am
by marky9074
Just replying here too.. anybody still got that install pdf, as the link seems broken.
Cheers,
Mark
Posted: Fri Feb 16, 2018 10:01 am
by iichel
Posted: Fri Feb 16, 2018 12:34 pm
by marky9074
Thanks for that. I thought this might have some more detail/info, but see it is the same as in the box. Hope it all makes sense once I pull the glove box out...
Posted: Tue Apr 21, 2020 10:17 am
by funlovincriminal
Posted: Tue Apr 21, 2020 8:04 pm
by green justin
How is the 1.4 TSI engine, i heard they were problematic with timing chains, oil consumption etc
Is yours still going ok?
Posted: Wed Apr 07, 2021 1:23 pm
by funlovincriminal
