CNK's Polo 6R 2.0 Shadow Blue
Re: CNK's Polo 6R 1.4
CNK wrote: This 7E0 BCM will be ok?
18.11.15, 0733 H80
It's perfect. :wink:
CNK
Drives: 6R
Post by CNK »
18.11.15, 0733 H80
That's good news, thanks Fernando!
So I have right BCM, now :)
Could you tell me, if I need any new connectors?
I know only about additional wires (https://drive.google.com/file/d/0B2nv91 ... JXSnc/view)
Rear View Camera works great:
zarfield wrote:I like your polo so much! i didn't expect this post comes from Poland, a remote mistery country for us!
i will view all your photos when i am back at home with my pad at hand~
Thank you for your kind words, zarfield ;)
The end of winter, so I replaced the wheels, now it's look much better.
Beautiful rims, the new looK is awesome.
CNK wrote: Could you tell me, if I need any new connectors?
I have reviewed some of your posts on the forum but I am not able to find an image your fuse box. An image of the fuse box is essential. :)
Depending on what you are going to install in future (Bi-xenon, RLS, auto lights, HBA - mirror 8G1) the wirings can be installed in one way or another.
Initially you need the wirings to BCM Max (read again :!: 090) and communication wiring between BCM and instrument cluster.
It would be very advisable to install 5K7 rain light sensor and 7E0 stalks in order to install these wirings, it requires redo DRL wiring in your 6R, and perhaps the front foglight wiring.
In this way everything would be perfect. :wink:
CNK
Drives: 6R
Post by CNK »
ciclo wrote:Beautiful rims, the new looK is awesome.
Hmm.. In future I'm going to install headlight washers, washer fluid reservoir and Bi-Xenon or LED headlights.
Later (maybe next year? :roll: ) I would like to change the mirror to 8GI with rain and light sensor. Then I could activate a coming / leaving home and auto lights :D
My fusebox:
This afternoon I look your questions (email), I have not yet had time. This is a hell... :lol:
Do not worry that everything has a solution.
According to autoscan you sent me by email ...
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0256
   Revision: BF046001
   Coding: 002200
   Shop #: WSC 85046 004 02308
   VCID: F0E9208223D4F99EEBD-80A5
3 Faults Found:
01304 - Radio
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 160
                    Mileage: 48124 km
                    Time Indication: 0
                    Date: 2003.14.19
                    Time: 01:00:20
01300 - Control Module for Navigation with CD-Rom (J401)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 160
                    Mileage: 48124 km
                    Time Indication: 0
                    Date: 2003.14.19
                    Time: 01:00:20
01303 - Telephone Transceiver (R36)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 160
                    Mileage: 48124 km
                    Time Indication: 0
                    Date: 2003.14.19
                    Time: 01:18:28
... there is a problem in the new harness that you have installed, I think that communication wires not are connected properly. Maybe (not sure) the harness is not appropriate. Try to do an autoscan where it is possible read all units. Clear all DTC's if possible.
Please tell us a brief history (images, links) of how, when and why it was installed the new harnness.
However...
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Component: RNS-MID       H23 6276
   Revision: AB001001    Serial number: VWZ6Z7P2234584
   Coding: 00000440000000A20000
   VCID: 3D7749B6A406C4F6B0B-8068
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V13  8348
... try this new coding to activate the Voice Control
New coding: 00000440000000A10000
CNK
Drives: 6R
Post by CNK »
ciclo wrote: ... there is a problem in the new harness that you have installed, I think that communication wires not are connected properly. Maybe (not sure) the harness is not appropriate. Try to do an autoscan where it is possible read all units. Clear all DTC's if possible.
However...
These are old errors, when I removed RNS510
Today I clear CAN Gateway and it's ok, no errors :)
Thursday,14,April,2016,23:09:49:30570
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WVWZZZ6RZCY019098   License Plate: NEW 14.04.2016 23:09
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
56-Radio -- Status: OK 0000
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 CN    HW: 03C 906 024 BH
   Component:       CGGB  MM4HV G 8994
   Revision: --H09---    Serial number:
   Coding: 0000071
   Shop #: WSC 00788 648 00255
   VCID: 6CD1B4F24CFC9D7E575-5072
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3216E00BB842524EB84D900401300
   VCID: 871B6B5E325ADE265A7-80D2
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045.clb
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326D6A8A6D580B8E5D9-8067
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0256
   Revision: BF046001    Serial number: 0434 158110732
   Coding: 3CB02BBF08F32400923808002C2B0CD100C0410F60040000200000000000
   VCID: 45872156CCD68C36E8B-8010
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 1K8 951 171 A    HW: K89 511 71A
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 08BC32
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00NXZLZ
   Coding: 003232
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9D126AEDC8634E059-801F
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB40570INGS61HS
   Crash sensor for side airbag; passenger side:
   Serial number: 3585HRB405R0ILP041NW
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515RRB404P0K4DOJGD6
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525RRB404P0K4DOM92Z
   Part No SW: 6R0 920 870 CX    HW: 6R0 920 870 CX
   Component: KOMBI         H05 0608
   Coding: 140A00
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 8D1759765C26B47660B-80D8
   Revision: BF046001
   Coding: 002200
   Component: IMMO          H05 0608
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADD32EA0D08034EA59-80BF
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660186144
   Coding: 010000
   VCID: 295F8DE6408E4856EC3-807C
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6B63FEEA6A2666327-807A
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: None
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105249241
   Coding: 020100010101010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: N/A
   VCID: 254781D624966C36C8B-8070
No ASAM data for: "EV_UHVPremi" (VW25)
End   ---------------------------------------------------------------------
The problem is with uncheck field Voice Control inactive...
I can't save any new coding with this option, maybe I should enter any access code?
I have alert "Coding accepted", but when I close controller and open it again, there is old coding with checked "Voice Control inactive" field.
I connect wires like this scheme:
Now it looks a bit clearer.
With this MFSW you have...
...and must be...
Subsystem 6 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Coding: A4FFFF
... so there is a communication problem between MFSW buttons and BCM.
By the other hand...
   ROD: N/A
... maybe the problem to activate the Voice Control is in this coding and therefore you can not encode navigation module to enable Voice Control. Must be correctly coded telephone module, radio or radio-navigator, and MFSW buttons to work properly the Voice Control.
Maybe anyone can help us because I do not know how is coded this telephone module. :|
CNK
Drives: 6R
Post by CNK »
ciclo wrote:Now it looks a bit clearer.
Component: DWA-Sensor 00 001 0103
...and must be...
Coding: A4FFFF
Hmmm.. :? Subsystem 6 is Seat Mem. Pass:
I clear all DTCs and after many attempts of saving new coding i have some success..
I found this instruction: http://www.carsystems.home.pl/instrukcj ... 8%20EN.pdf
New coding:
I have tried many times activate the buttons MFSW, and finally it works. Same with Inactive Voice Control (http://www.my-gti.com/1234/volkswagen-r ... ce-control).
New log:
Friday,15,April,2016,18:19:54:30570
VIN: WVWZZZ6RZCY019098   License Plate: 15.04.2016_18.19
Mileage:    Repair Order: Clear-all-DTCs
   Coding: 0000071
Readiness: 0110 0001
   Revision: --------
   Revision: 0002S 02
   Coding: 18BC30
   Coding: 08BC30
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003232
   Coding: 140A00
   Revision: BF046001
   Coding: 002200
   Serial number:
   Coding: 010000
   Coding: 00000442000000A10000
   Coding: 11250
   Shop #: WSC 00788
   Coding: 020000010100010000000100
   ROD: N/A
However finally I'm confused.. When i push "Push-To-Talk" button I have only alert: "Należy pamiętać, że obsługa głosowa w języku polskim nie jest dostępna" which mean "Please note that the service voice in the Polish language is not available" And that's all. Any voice control, probably it's not available in my software.. :| :cry:
CNK
Drives: 6R
Post by CNK »
Ok, I change language of my RNS510 to English, and now it works.. but only when I press star on RNS510.
Button in MFSW is strange and it does not work as it should: https://www.dropbox.com/s/akbxdqe8mdjle ... 8.mp4?dl=0
Any ideas?
PS. If it's possible to use english voice commands with set Polish language?
An idea :idea: :
Remove and isolate T41/11 wire from connector of the steering column, this wire is no longer necessary with multifunction steering wheel. It may be the cause of conflict between the buttons and bcm.
Try to coding subsystem 6 again. A4FFFF
Test the MFSW buttons and horn, and save the new Autoscan. :)
CNK
Drives: 6R
Post by CNK »
ciclo wrote:An idea :idea: :
Horn and buttons works, I will try to coding this on the new BCM.
Some new photos:
Image Image Image
Willni
Drives: Polo '14 6R, Golf 07' Edition 30
Post by Willni »
When are you doing the r-line bumper, I'd like to know what it looks like without sideskirts
CNK
Drives: 6R
Post by CNK »
Willni wrote:When are you doing the r-line bumper, I'd like to know what it looks like without sideskirts
But I bought sideskirts too :mrgreen:
Without sideskirts it looks like a single stair between bumper and rest of car.
For example: https://scontent.fwaw3-1.fna.fbcdn.net/ ... e=572D24D1 :wink:
CNK wrote: Horn and buttons works, I will try to coding this on the new BCM.
Therefore will be soon, let's see what happens.
Do you have the three bags?
By the way, Krzycho's Golf can be one of the best in its class around the world, I like it 8) , your 6R follows the same path. :mrgreen:
