Benji58 - Polo 6R TDI 75 - R-Line Conversion
benji58
Drives: 6R R-Line 1.2 TDI
Re: Benji58 - Polo 6R TDI 75 - R-Line Conversion
Post by benji58 »
Thank you for all this information ciclo, so now I think later installed the steering wheel sensor G085 :lol:
For the RDKS system it put me on an idea. My valves may not be compatible with the module :?: :|
Yes, it is likely.
Ask to rdasadia what type of valves/sensors has installed.
What have you finally done with the valves/sensors?
benji58
Post by benji58 »
ciclo wrote: Tue May 16, 2017 11:42 am What have you finally done with the valves/sensors?
I ordered new valves/sensors 3AA907275F
I'm waiting for them to try :roll:
It has to work because I bought them too ...
Yes I have finally decided to install this system. :)
benji58
Post by benji58 »
I installed the new valves 3AA907275F, One problem is solved, the valves are detected by the RDKS module. I have the pressure displayed in the 08 measuring blocks in vcds.
BUT ! always the error and no display on the cluster... :cry:
1 Code défaut trouvé:
12658432 - Fonctionnement limité en raison de l'absence de message
          U1111 00 [008] - -
          Intermittent - Confirmé - Testé depuis RàZ mémoire
             Capture:
                    Etat du défaut: 00000001
                    Priorité du défaut: 6
                    Fréquence du défaut: 1
                    Compteur de RAZ: 80
                    Kilometrage: xxxx km
                    Date: 2017.05.08
                    Temps: 19:16:39
Complete autoscan in English please ?
benji58
Post by benji58 »
iichel wrote: Mon May 22, 2017 6:45 am Complete autoscan in English please ?
here it is my full autoscan in English : :wink:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 47 55 56 65 0B
VIN: WVWZZZ6RZCY129376
47-Sound System -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J0000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021     HW: 03P 907 425 A
   Component: R3 1.2 DCM3.7 H08 9505
   Revision: 11003001    Serial number:
   Coding: 00114014002400080000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_EMC12TDI03103P906021 001016
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 65C03E9B64A7E3697A-8030
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 AE    HW: 6R0 907 379 AC
   Component: ABS8.2 front  H04 0001
   Revision: --------
   Coding: 200224E3016F00BB042824E980D700000000
   Shop #: WSC 00788 648 00255
   VCID: 01080A0B9CCF2F49E6-8054
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0812
   Revision: V0000000
   VCID: 387EA7EF8B95AE8111-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 259160361
   Coding: 3CB029BF48E1240093280E917CEB97D05A80672F608D30C1200000030000
   Shop #: WSC 02737 790 12345
   VCID: 2A5A8DA745390C1197-807E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 161014 05  54  0403
   Coding: 06302D
   Subsystem 2 - Part No SW: 6R0 959 801 CE    HW: 6R0 959 801 CE  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 9612
   Serial number: KU0KU005051551253047
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 CJ    HW: 6R0 959 802 CJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 9612
   Serial number: KU0KU005051551250425
   Coding: 1000AB
   Subsystem 7 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B
   Component: E221__MFL-TAS  H30 0036
   Serial number: 0113742
   Coding: 820000
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261224902578
   Coding: 308001
   Shop #: WSC 02756 790 50316
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 3978A2EBB89FB789EE-806C
   Component: VW10Airbag01K H09 0020
   Revision: --------    Serial number: 003GX00XLZLX
   Coding: 00314B
   ASAM Dataset: EV_AirbaVW10BPAWV250 A01001
   VCID: 4A9AED27ED792C1177-801E
   Subsystem 1 - Serial number: 3575HRB405T0U20SAHVG
   Subsystem 2 - Serial number: 3585HRB405T0U20S2OJ4
   Subsystem 3 - Serial number: 3515RRB405V0R8ACI0O3
   Subsystem 4 - Serial number: 3525RRB40630Q8K49PJW
   Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_Kombi_UDSV_DD_RM09 A04716
   VCID: 346693DF9FFD4AE13D-8060
1 Fault Found
12658432 -  Function Restricted due to Missing Message(s)
          U1111 00 [008]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 11
                    Reset counter: 103
                    Mileage: 112449 km
                    Date: 2017.05.22
                    Time: 22:09:56
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002000
   VCID: 68DE37AF9BB5FE0141-803C
   Component: IMMO          H05 0607
   ASAM Dataset: EV_Immo_UDS_VDDR_M09 A03709
   VCID: 6ADA4DA78DB9CC1157-803E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 P
   Component: RNS-MID       H10 5270
   Revision: AB001001    Serial number: VWZ6Z7N6370477
   Coding: 04070040000000810001
   VCID: 3B74B8E3BAA38599FC-806E
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
Address 44: Steering Assist        Labels: Redir Fail!
   Part No: 6R0 423 156 B
   Coding: 10130
   Shop #: WSC 00788
   VCID: 2F6C9CB3EADB693940-807A
Address 47: Sound System (R12)       Labels: None
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218109097291
   ASAM Dataset: EV_AudioEvrst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 67DC34939EABF17948-8032
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   ASAM Dataset: EV_HedalRegulVWLWRPt 001004
   VCID: 77FC64D3CE0B61F9D8-8022
1 Fault Found
13705474 - Databus
          U1121 00 [137] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 39
                    Mileage: 112449 km
                    Date: 2017.05.22
                    Time: 22:09:56
Address 56: Radio (J0506)       Labels: None
Address 65: Tire Pressure (J502)       Labels: None
   Serial number: 40000000043140
   ASAM Dataset: EV_RDKBEUR30 005005
   ROD: EV_RDKBERU30_VW51.rod
   VCID: 377CA4D38E8BA1F918-8062
End---------------------(Elapsed Time: 03:36, udsna)-----------------------
ah very good. what I would suggest probably is the removal of the ABS based TPMS. Unfortunately I don't know the coding for ABS, only ESP8.2 and ESP 9.0. Maybe @firegrafik could help out. He is from the Russian Polo community where replacing ABS in favour of ESP is done regularly.
iichel wrote: Tue May 23, 2017 7:36 am ah very good. what I would suggest probably is the removal of the ABS based TPMS. Unfortunately I don't know the coding for ABS, only ESP8.2 and ESP 9.0. Maybe @firegrafik could help out. He is from the Russian Polo community where replacing ABS in favour of ESP is done regularly.
It was already done. :wink:
The problem may be in the IC software.
rdasadia has a software updated compared to yours, and Eugene (aka ZZZhuk)...hmm... has a software in his IC from T5 (magic things) :lol: :lol:.
And that's the reason I think the problem is the IC software. Of course, it's all speculation.
The autoscan of rdasadia is our best bet. :wink:
Did you already adapt the sensors to the module?
http://wiki.ross-tech.com/wiki/index.ph ... ecognition
@iichel, the pressures are already recognizable in MBs.
@benji58
To generate the tire pressure settings (according to the pressures table on fuel filler flap) use this application (for ODIS, VCP or Binary):
http://htmlpreview.github.io/?https://r ... rator.html
eg, this is the tire pressure table in my fuel filler flap/cap. 1.2 TSI (215/40 R17):
Enable 'Individual' for customize your tire pressures, or enable more tire sets.
examples: 215/35 R18, Sport mode, Path of rabbits, etc...
benji58
Post by benji58 »
thank you for your replies
iichel : TPMS indirect is already disabled in ABS module.
The adaptation of the sensors took place automatically while driving. If I go to the measuring units in the RDKS module, the ID of the sensors is indicated in all the wheels and the live pressure is displayed.
ciclo : I have already tried to set up my RDKS module, but when I launch the update with VCP it marks me communication error ...
How can I update my IC software?
It may not be necessary to update the IC software (they are only speculations).
