Polo 6R Scan Help
Valgas6R
Drives: Polo 6R
Re: Polo 6R Scan Help
Post by Valgas6R »
i dont have alarm
I tried again disable RLS Without effectively.
After reading through the service number vin is a version TrendLine. So everything in the car makes
It may need a code to access the channel 09 Central Electric.
Code 31347 is not working.
http://ifotos.pl/z/arhqqqs
1st
BCM
25B02BBF08A1000001300C916CAB0FD05A80672F60053041200000010000
2nd
RLS
02302D
Everything should work correctly with these codings. Except CCS.
Keep in mind that it is very strange that your 6R is coded to have cruise control installed (Engine, BCM) and no faults in Autoscan about it. (you said that the cruise control wiring is not installed) :? Take pics of T41 connector wires... hmm... and fusebox.
You do not need any access codes.
It is the third time I ask you for images, also is the last time. :wink:
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
Thank you for the images. :wink:
Codings without cruise control system
BCM
Unmark Byte17 Bit7.
or new coding
25B02BBF08A1000001300C916CAB0FD05A00672F60053041200000010000
Engine Control Unit (Address 01)
Turn ignition key to ACC (as usual) but don't start the engine.
Unmark Byte5 Bit5
or new coding
00114016000400080000
When you have installed the CCS wires, revert this process.
I wonder if you have installed in your 6R the Dynaudio Sound System, if not:
Navigation (Address 37)
new coding
04000400040000A00001
and restart/reset once the coding is accepted CLICK :arrow: <+>+eject+micro/star
As for Rain/Light Sensor something weird happening here. Your sensor is an OEM part, but it is not from factory (i mean when your 6R was manufactured).
Component: RLS 190913 05 54 0403
The coding 02302D should be accepted.
Try the following:
Remove the battery ground wire, wait for 2 min, reconnect.
Try to enter the RLS coding again.
Finally don't forget to do a new autoscan once you Clear all DTCs.
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
Beam cruise ordered with kauftec will be on Wednesday, Thursday.
Do you have a scheme for Dummies how to install RLS.
And how do yourself a bundle.
I was looking at but did not find to buy. Because as I install cruise control immediately I would install rls
EDIT: http://forums.ross-tech.com/showthread. ... r-31/page2
I got Ver. 16.8.0 <<< this cable Have a bug ;/ need go china forum to look how update to 16.8.1 ;/
the RLS installation --> https://www.dropbox.com/s/e42r847zagv5o ... ..pdf?dl=0
but your RLS is already installed and working. it's just that the coding is not accepted directly. this is not unusual.
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
Then tell me what to do now :(?
Dont know where download a 16.8.1 ver china vcds ;/
usually the china clone cables don't upgrade. so you can continue using 16.8.0.
that's a good version anyway :)
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
yep 16.8.0 have a bug ...
That's why I can not encode RLS to turn it off and writes error 31
EDIT: I am waiting for your account to update MMHAUTO because the cable is possible
HAHA 15usd to register in page :) Never !
EDIT: Rear view mirror works great.
I can not continue to transcode driver RLS
The only way out would be to dismantle the mirror. But to do that I have to buy plastic tools. And I begin to put on OEM Ross tech :)
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
Is it a problem with the button switching lights do not have Auto
Therefore, it may not work this sensor.
How to turn on the lights and the main Fog shone turn?
No, it's no problem that you don't have a light switch with auto setting.
The RLS can still operate other things like the background lights of the navigation map, the auto setting for the windscreen wipers and the CH/LH function.
The last sentence, do you mean how to turn on the fog lights? If I understand correctly, you have bi-xenon OEM.
So the fog lights only operate when you pull the switch towards you.
The cornering lights are integrated into the main headlight.
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
Yes, but as I turn against the light-hazing is burning just right so what is left? I think I remember from before encoding your burned in August. I find some time tomorrow, it'll look.
and tomorrow pile of plastic tools and see if the sensor RLS is at all connected
Valgas6R
Drives: Polo 6R
Post by Valgas6R »
As for Fog lights, cornering lights, and main headlights:
Byte21 Bit7, but it is not a factory option for 6R with bi-xenon headlamps.
My replies within the quotation:
Valgas6R wrote:yep 16.8.0 have a bug ...
I do not know what you and iichel are talking by private. The solution for your Rain/Light Sensor is to update the VCDS program.
You do not need to change the RLS or dismantle the mirror.
The last Autoscan :?: :wink:
A tip: As iichel said,
iichel wrote:i think it's important to first have the car free of errors,....
we don't have contact outside of the topic, don't worry. i wasn't aware of the vcds but at 16.8.0, i thought i actually coded my rls recently with this version (genuine cable though).
