Page 3 of 7
Re: Polo 6C Rain Light Sensor DIY Help
Posted: Fri Nov 23, 2018 9:10 am
by fleagal
Sorry, I should been clearer - I don't have rain or light sensing on my car.
I wanted automatic headlights and a third party unit solved this problem which involved placing a light sensor at the bottom of the windscreen.
Posted: Fri Nov 23, 2018 6:15 pm
by fatih.saday
fleagal wrote: Fri Nov 23, 2018 9:10 am
Yourwelcome,
my bcm 6c0937089d supports rain light detection, electrical connection and vcds encodings are correct, but sensor bcm does not appear in subsystem
Posted: Tue Nov 27, 2018 1:51 am
by massimo23
my polo 6c 2017 has rls installed and is working , wipers go on when it rains automatically and low light beam turn on when near dark. But I don't have rls sub system in central electric. I have rain/light sensor menu set to Lin_Regen_licht_Sensor. is it normal not to see the rls sub system option?
Posted: Tue Nov 27, 2018 4:47 am
by fatih.saday
Can you put an auto scan here? and a 09 block admap
I think, you have 09 blocks is 2Q0
Posted: Tue Nov 27, 2018 1:14 pm
by massimo23
I have obdeleven. I was able to download the history log of the long code and adaptions if that's any good. I will check to see if there is a better way to download the information. Car: Volkswagen Polo
Year: 2017
Body type: 5-dr hatchback
Engine: CHYB 55 kW (75 HP) 1.0 l
Mileage: 32644 KM
Control unit: 09 Central Electrics
System description: BCM PQ26 Hi4R
Software number: 6C0937089D
Software version: 0093
Hardware number: 6C0937089
Hardware version: H10
Serial number: 006238046367
ODX name: EV_BCMA0
ODX version: 006002
Long coding: 0300084042530A7B4F844000402703C800005B0253010000000000000000
Driver side: Right
Traffic: Left
Brand: VW
OCU: not installed
Expanded high beam control: Halogen
Versorgung_des_Lenkstockschalters_KL30: installed
Seat heater not connect.: Not connected
Eingriff_durch_Energiemanagement: active
Lock/unlock, direct button: Rocker sw.
DWA_push: not active
Lichtdrehschalter_mit_Nebellicht_bei_Assistenzfahrlicht: Yes
Rain/light sensor: LIN_Regen_Licht_Sensor
Low beam, bulb type: H7
Hybrid: No
Input medium, search illumination: HMI
Light rotary sw. connection: Discrete signal current
Radio freq.: 434,42MHz
Profile function: Key profile
Rear lid lock control: Contact control
Central locking, rear lock type: 1 or 2 notch rear actuator
Type of lock: 1 Motor locks without Safe (NAR locks)
Windshield_wiper_typ: direct
Rear_window_wiper: nur Komfortwischen
Heated_mirror: installed with mirror switch
Art_des_Lenkstockschalters: ohne Elektronik, FL tastend
Signalhorn_ueber_LIN: horn_via_LIN
GRA-Bedienung: MFL-Bedienung
Fernlichtstellung: FL rastend
Window lift type: PQ25_window_regulator
window_regulator_node_adress: standard
Verortung Schiebedachmodule: LIN
Remote HuF Hupfrequenz: 0
Posted: Tue Nov 27, 2018 1:33 pm
by fatih.saday
bytes in bold indicates that the rain/light sensor is in the subsystem,
byte 6 "0A", byte 7 "7B" byte 13 "27"
What is the sensor part code?
5Q0 955 547?
Posted: Tue Nov 27, 2018 3:38 pm
by massimo23
I was able to take photos of sensor without removing it.
there is a code 17008138-01 MRO
Posted: Tue Nov 27, 2018 3:52 pm
by fatih.saday
Your sensor is 5Q0 955 559B rain/light sensor not humidity
Posted: Tue Nov 27, 2018 3:54 pm
by fatih.saday
Where are you from my friend
Posted: Tue Nov 27, 2018 4:03 pm
by fatih.saday
Do you have sunroof, start stop and auto air conditioning in your car?
Posted: Tue Nov 27, 2018 6:49 pm
by massimo23
I am from Ireland.
I dont have sunroof.
I have all electric windows, electric foldable led indicator side mirrors with heating, 300w beats system, start-stop, front assist , opc , rearview camera, voice control, android / carplay / mirrorlink. Normal air con.
Posted: Tue Nov 27, 2018 7:13 pm
by fatih.saday
Will you be able to auto scan?
Posted: Tue Nov 27, 2018 7:30 pm
by massimo23
I would love to get rear mirror dip but no joy.
Want to add blindspot monitor and auto high beam .
Added led interior light and had no problem. Have footwell led already installed.
Posted: Tue Nov 27, 2018 7:33 pm
by massimo23
I have obdeleven and i am new to this. There are loads of options but also load in german language. I will see what i can do tonight when i finish work.
Posted: Wed Nov 28, 2018 4:42 am
by fatih.saday
Ok friend, I patiently wait for you.
I vcds hexv2 user, I didnt use obdeleven
