Cross Polo 6R Upgrading to BCM Max with Auto light switch
MaDwArLoCk
- Drives: Cross Polo 2010 TSI
Re: Cross Polo 6R Upgrading to BCM Max with Auto light switch
Nope, relay not clicking...
Check wiring for headlight relay (assuming you have BCM Max and auto light wiring in the car).
Climatronic faults... hmm... basic setting?, bad electrical installation?.
Maybe benji58 or iichel can help you fix it. They also swapped from A/C or Climatic to Climatronic.
0B must be there.
61-Battery Regul. Software bug (7H0 BCM 7L6) for your 6R, which is 7L3.
In my topic (in some part of it) there are some comments that we made of this for a 6R from Portugal.
I do not know if this mate from Portugal was able to solve it.
As for lights:
1- Test with this BCM coding and tell me the results (Autoscan).
24B02BBF48E3240093300FB02CEB1ED01BC0610E60042001200000010000
2- Test with this BCM coding and tell me the results (2nd AutoScan)
24B02BBF48E3240093300FB02CEB1ED01BC0610E60042000200000030000
The meaning of these BCM codings is so that I know what is going on, so posting the faults that appear in VCDS autoscans is the most important thing. Two autoscan.
Rear fog lamp
signal: from T10/7 to T73b/43
output power: from T73a/6 to fog lamp. In your case, also through the fuse 18 if you did as indicated in the installation guide, so the fuse 18 must be installed.
0B must be there.
As for lights:
Rear fog lamp
MaDwArLoCk
Here are all connections i've made:
Isolated:
T17/3, T17/6, T17/7
T6/3
T73A/45
WL0
SB49b (30A) - SB57a (15A)
WL2
T73B/68 - SB39b (15A)
T73A/63 - SB59b (15A)
T73A/2 - (orig.) sb39b
T73B/2 - (orig.) sb59b
T73A/62 - SB34b + (orig.) 34b
T73b/11 - SB57b
(bridge to J331 relay)
WL3
T73B/1 - T6/3
T73B/43 - T10/7
T73A/6 - T17/9
T73B/7 - T17/16
T73A/45 - T10/3
T73B/29 - T10/9
WL5
T10/1 - T17/11
T10/2 - T73A/37
T10/3 - T73A/45
T10/4 - T17/1
T10/5 - To Fog Lights Relay (3)
T10/6 - T17/10 - To relay HL (5) - To Relay FL (5)
T10/7 - T73B/43
T10/8 - T17/15 - To Relay Headlights (1)
T10/9 - T73B/29
T10/10 - T17/17
Headlights Relay
(1) - T17/15 - T10/8
(2) - T7/4
(3) - T73A/1
(5) - To Reley FL (5) - T17/10 - T10/6
Foglights Relay
(1) - T17/2
(2) - T17/8
(3) - T10/5
(5) - To Reley HL (5) - T17/10 - T10/6
I will try new coding now...
Isolated:
T17/3, T17/6, T17/7
T6/3
T73A/45
WL0
WL2
T73b/11 - SB57b
WL3
T73B/1 - T6/3
T73B/43 - T10/7
T73A/6 - T17/9
T73B/7 - T17/16
T73A/45 - T10/3
T73B/29 - T10/9
WL5
T10/1 - T17/11
T10/2 - T73A/37
T10/3 - T73A/45
T10/4 - T17/1
T10/7 - T73B/43
T10/9 - T73B/29
T10/10 - T17/17
Headlights Relay
(2) - T7/4
(3) - T73A/1
Foglights Relay
(1) - T17/2
(2) - T17/8
(3) - T10/5
MaDwArLoCk
I saw your solution already!iichel wrote: Mon Aug 21, 2017 7:54 am Solving the HVAC error should be easy
https://www.mypolo.nl/xenforo/threads/i ... ost-173452
Unfortunately it doesn't work for me..
MaDwArLoCk
BCM have no faults!ciclo wrote: Mon Aug 21, 2017 7:29 am
As for lights:
Dimmer working.
High beam and Rear fog light - not working
Monday,21,August,2017,10:33:39:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZAU000000 License Plate:
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 44 56 77 0B
VIN: WVWZZZ6RZAU000000 Mileage: 156960km-97530miles
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 D HW: 03F 906 070 D
Component: SIMOS10.20H02 9851
Revision: -------- Serial number:
Coding: 001900D6202400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TSF02103F906070D 003015
ROD: N/A
VCID: 234234CE2A4EB859D4-8076
No ASAM data for: "EV_ECM12TSF02103F906070D" (VW25)
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AF HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0005
Revision: --------
Coding: 210228E3227300BA842C14E844D600401300
Shop #: WSC 31414 790 31414
VCID: 020C514A99945151FF-8056
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3878F3A28BC8CB8111-806C
2 Faults Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 156965 km
Time Indication: 0
Date: 2012.01.12
Time: 00:40:17
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 4
Reset counter: 51
Mileage: 156965 km
Time Indication: 0
Date: 2012.01.12
Time: 00:40:17
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 017140713
Coding: 24B02BBF48E3240093300FB02CEB1ED01BC0610E60042001200000010000
Shop #: WSC 02756 790 00000
VCID: 2D56D2F6748A7E2972-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 210310 05 54 0403
Coding: 06302D
Subsystem 2 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU028.04.1013935
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU030.04.1010613
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Subsystem 7 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU026.04.1016866
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU020.04.1013618
Coding: 08BC32
MaDwArLoCk
Dimmer does not workciclo wrote: Mon Aug 21, 2017 7:29 am
As for lights:
High beam and rear fog lamo does not work
Monday,21,August,2017,10:45:49:39744
www.Ross-Tech.com
ASAM Dataset: EV_ECM1T2FS02103F906070D 003015
ROD: N/A
No ASAM data for: "EV_ECM1T2FS02103F906070D" (VW25)
Revision: --------
Revision: V0000000
2 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 156965 km
Time Indication: 0
Date: 2012.01.12
Time: 00:40:17
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 156965 km
Time Indication: 0
Date: 2012.01.12
Time: 00:40:17
Coding: 24B02BBF48E3240093300FB02CEB1ED01BC0610E60042000200000030000
Coding: 06302D
Coding: 18BC30
Coding: 08BC30
Coding: 08BC32
Coding: 08BC32
1 Fault Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 52
Mileage: 156965 km
Time Indication: 0
Date: 2012.01.12
Time: 13:24:48
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 A HW: 7E0 919 475
Component: PARKHILFE 4K H10 0011
Revision: -------- Serial number: 64531012301615
Coding: 100003
ASAM Dataset: EV_VW250ParkiAsiss2 S01008
ROD: N/A
VCID: 3C70EFB2B7F0E7A1F5-8068
No ASAM data for: "EV_VW250ParkiAsiss2" (VW25)
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag00K H08 0020
Revision: -------- Serial number: 003GX002F4VI
Coding: 00304B
VCID: 4A9CB96AED24491177-801E
Serial number: 3572SRB40000B53459C7
Serial number: 3582SRB40000B520C0C1
Serial number: 3515RRB405D6QGG0HO90
Serial number: 3525RRB405B6SD5OFPMN
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 D HW: 6R0 920 860 D
Component: KOMBI H03 0207
Coding: 140800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
VCID: 3566FA9694DA36E90A-8060
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 002200
VCID: 70E80B82A33853C119-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H03 0207
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Imm_oUDS_VDD_RM09 A03006
ROD: N/A
VCID: 6ADC19EA8DE4A91157-803E
No ASAM data for: "EV_Imm_oUDS_VDD_RM09" (VW36 *)
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 1T0 035 680 R
Component: RNS-MID H21 6270
Revision: AB001001 Serial number: VWZ6Z7N8319084
Coding: 040104020100002C0001
Shop #: WSC 01357 011 00200
VCID: 3D76E2B6A4EAEEA9C2-8068
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V14 8477
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F6AC8FEEA860C3940-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 D HW: 7P6 035 730 D
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668399469
Coding: 0A00000000010110
Shop #: WSC 05314 115 12345
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 3362C48E9AAE28D924-8066
End-------------------------(Elapsed Time: 03:45)--------------------------
I did not made anything with fuse 18. (it wasnt mentioned in the istallation guide) But i have it in my fuse box (5A)ciclo wrote: Mon Aug 21, 2017 7:29 am Rear fog lamp
Perfect!. Let me check a few things ...
I'll tell you something later.
All these connections are correct.MaDwArLoCk wrote: Mon Aug 21, 2017 9:13 am Here are all connections i've made:
Isolated:
T17/3, T17/6, T17/7
T6/3
T73A/45
WL0
WL2
T73b/11 - SB57b
WL3
T73B/1 - T6/3
T73B/43 - T10/7
T73A/6 - T17/9
T73B/7 - T17/16
T73A/45 - T10/3
T73B/29 - T10/9
WL5
T10/1 - T17/11
T10/2 - T73A/37
T10/3 - T73A/45
T10/4 - T17/1
T10/7 - T73B/43
T10/9 - T73B/29
T10/10 - T17/17
Headlights Relay
(2) - T7/4 ....(T17/4)![]()
(3) - T73A/1
Foglights Relay
(1) - T17/2
(2) - T17/8
(3) - T10/5
Next thing to do:
Test with this BCM coding.
24B02BBF48E3240093300FB02CEB1ED011C0610E60042001200000010000
Depending on the results we will know what happens with the high beam and rear fog lamp. (I guess)
Note: For the results of previous BCM codings, some diagnostics are missing.
I could explain it, but it is something complex and it is not necessary for you (besides that my English is far from being correct). Everything depends on the evolution in the BCM software 7H0 and 7E0, and on the other hand on VCDS software (labels).
MaDwArLoCk
Still doesn't workciclo wrote: Mon Aug 21, 2017 11:34 am
may be it's something wrong with High beam relay connection? its not clicking.. Fog lights relay - OK
High beam works only in "blink" mode.
Monday,21,August,2017,13:12:49:39744
www.Ross-Tech.com
VIN: WVWZZZ6RZAU00000 License Plate:
ASAM Dataset: EV_EMC12TFS02103F906070D 003015
ROD: N/A
No ASAM data for: "EV_EMC12TFS02103F906070D" (VW25)
Revision: --------
Revision: V0000000
2 Faults Found:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 12
Mileage: 156965 km
Time Indication: 0
Date: 2012.01.12
Time: 00:40:17
Fault Priority: 6
Fault Frequency: 3
Reset counter: 52
Mileage: 156965 km
Time Indication: 0
Date: 2012.01.12
Time: 00:40:17
Coding: 24B02BBF48E3240093300FB02CEB1ED011C0610E60042001200000010000
Coding: 06302D
Coding: 18BC30
Coding: 08BC30
Coding: 08BC32
Coding: 08BC32
Coding: 100003
ASAM Dataset: EV_VW250PrakiAssis2 S01008
ROD: N/A
No ASAM data for: "EV_VW250PrakiAssis2" (VW25)
Coding: 00304B
ASAM Dataset: EV_AirbaVW10BAPVW250 A01001
ROD: N/A
Subsystem 1 - Serial number: 3572SRB40000B53459C7
Subsystem 2 - Serial number: 3582SRB40000B520C0C1
Subsystem 3 - Serial number: 3515RRB405D6QGG0HO90
Subsystem 4 - Serial number: 3525RRB405B6SD5OFPMN
No ASAM data for: "EV_AirbaVW10BAPVW250" (VW25)
Coding: 140800
Revision: B9074001
Coding: 002200
And pretty often it show error about "license"..
I need three or four attempts to make full autoscan.
Therefore, the connections are correct from the SB34b (fuse) to the headlights.MaDwArLoCk wrote: Mon Aug 21, 2017 12:14 pm Still doesn't work
... Fog lights relay - OK
Therefore ... exchange the relay to find out if the relay is faulty (you have at least one more, or use fog lights relay.
Also check that the 0.5mm thin wire from SB34b to T73a/62 is correctly installed.
BCM coding:
MaDwArLoCk
I have tried it already, same story!ciclo wrote: Mon Aug 21, 2017 1:19 pm
Therefore ... exchange the relay to find out if the relay is faulty (you have at least one more, or use fog lights relay.).
I am at work now, So I could check this coding only tomorrow morning...ciclo wrote: Mon Aug 21, 2017 1:19 pm BCM coding:
MaDwArLoCk
By the way, at firegrafik's post on Drive2, he wrote:
May be I should try?
He took power for headlights relay from T17/1 instead of T17/15.Питание (15 клемма) с контакта Т17/1 идет на реле откуда при включении реле по команде от ВСМ с контакта Т73а/1 возвращается к проводу с контакта Т17/4 где уже идет на подрулевой переключатель по штатной схеме.
...or better this:MaDwArLoCk wrote: Mon Aug 21, 2017 2:23 pmI am at work now, So I could check this coding only tomorrow morning...ciclo wrote: Mon Aug 21, 2017 1:19 pm BCM coding:
24B02BBF48E3240093300EB02CEB1ED01BC0610E60042001200000010000
NOMaDwArLoCk wrote: Mon Aug 21, 2017 3:11 pm By the way, at firegrafik's post on Drive2, he wrote:
Byte18 Bit5 is the culprit.
It must manage your High beam in all light switch positions when installed automatic lights, must be enabled.
The real problem is that we know absolutely nothing about the BCM you bought. As for example, what was the donor car and its specs...
99% of the problems in these mods are due to the purchase of used parts (cheaped) without the correct identification. (Damn experience
Sometimes it is possible to solve them. ...sometimes.
There is an endless list of BCM Max (7H0 and 7E0) and the data (PR-codes) provided by ETKA are limited, or they are missing.
If you had bought a BCM 7E0937090C, we would all be happier right now.
Precisely, you can speak with firegrafik to help you with this purchase if you want.
