numberior´s 2011 Polo 6R GTI DSG
numberior
Drives: Polo GTI 6r
Re: numberior´s 2011 Polo 6R GTI DSG
Post by numberior »
Hi Ciclo,
Yes, there is some difference in the wires reaching the Light switch/Dimmer connectors.
- Blue / Gray = Yellow / Gray (T17 connector, and T6 connector)
- You must also remove/isolate the T17/6 original wire.
I left out T17/6.
Will get to doing it.....just thought I tell you in case it's causing the error. :roll:
numberior wrote: Thu Oct 19, 2017 5:27 pm
When I switched off engine, the cabin light is on until I leave the car and locks the car by remote.
When I unlock the car by remote, cabin light comes on, then turns off when ignition on.
I did not know at time of testing to observe the headlight and tail light also. Was not familiar with this feature.
Will observe again tomorrow.
This function was already coded in your previous BCM. It is absolutely correct.
What is the problem?
If you do not want this function, uncheck Byte12 Bit2
Latest scan gave error on reverse lamp diagnostic, which I find strange as diagnostics for backup lamp is already disabled.
It comes back even after clearing the DTCs.
I'm using full LED taillights https://item.taobao.com/item.htm?spm=a1 ... uav4oqe1eb
by the way.
As I said, the faults shown in the autoscan are due to the use of non-original parts, the coding is perfect. :wink:
Replace them by OEM parts ...
Another error is related to xenon range module.
I'm using LED H7 bulbs https://www.philips.com.sg/c-p/12985BWX ... light-bulb for the cornering lamps.
I can change them out for halogen if required.
Yes, change them... by H7 55W.
numberior wrote: Thu Oct 19, 2017 5:34 pm Hi Ciclo,
I left out T17/6.
Remove/isolate, and everything will work as it should. :wink:
numberior
Drives: Polo GTI 6r
Post by numberior »
okie Ciclo,
thanks for your help again :)
Regarding our bi-xenon headlamps: will they perform a up/down sweeping range check each time the engine is started?
Because I don't see them doing it, even after xenon range basic setting is accepted.
They should do this every time you make a new ignition cycle.
To try to solve the problem of back-up lamp (with Taobao taillights) do this BCM coding:
3CB02BBF08A1000008380CC16C2B0CD05AC0672F60051040200000030000
I will never be in favor of losing the diagnosis of such an important lamp.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
I retained your BCM coding. The worker at the body shop broke my reverse lamp wire(was modded for RHD). I've since repaired it so
now no fault code in BCM. I've temporarily disabled hi-beam diagnostic while waiting for halogen ones to come in.
One last problem though.... the headlight range module is not working. :(
I've checked connections at sensor, re-seated the connector and checked the wires to the AFS control module.
The AFS is supplied with permanent +12V as in Kufatec's instruction. I'm not sure if it's the cause. :roll:
I seem to be having similar issues as "sanders" viewtopic.php?f=56&t=68178&start=105
Monday,23,October,2017,16:55:31:27502
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116   License Plate: 12TH SCAN
Mileage: 100290km-62317mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 55 56 0B
VIN: WVWZZZ6RZBY312116   Mileage: 100290km-62317miles
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAVE)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 AR    HW: 03C 906 027 AR
   Component: 1.4l R4 TSI   H15 9971
   Revision: L2H15---    Serial number: 00000000000000
   Coding: 00250012002400000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
   ROD: EV_ECM14TSI01103C906027AR.rod
   VCID: 71E99E02A0C274CE75-8024
Readiness: 0010 0101
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230248E3416E02B4C42612E382D740811700
   Shop #: WSC 00788 648 00255
   VCID: 071DD0DAB2465A7ECB-8052
   Part No SW: 6R0 907 044 E    HW: 6R0 907 044 E
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 35616A129C2A18EE69-8060
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 321160318
   Coding: 3CB02BBF08A1000008380C916C2B0CD05AC0670F60051040200000030000
   VCID: 2A5B496E45944716F4-807E
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  007 1611
   Serial number: KU0KU024031100012688
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  007 1611
   Serial number: KU0KU016031100015781
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 591 A    HW: 7P0 959 591
   Component: J245 PS72.015  H05 0006
   Serial number:     WOO1165901/
   Coding: 081001
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0050759
   Coding: 830000
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU011041100017315
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU011041100013053
   Coding: 08BC32
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10Airbag01E H09 0020
   Revision: --------    Serial number: 003GZ000HCNK
   Coding: 003145
   VCID: 4C972FF6E7A0792626-8018
   Serial number: 3575HRB40550HJHG9ON%
   Serial number: 3585HRB40590HJHG919A
   Serial number: 3515RRB405B0I4AG6OGL
   Serial number: 3525RRB404R0H4DUHPLR
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 870     HW: 6R0 920 870
   Component: KOMBI         H21 0320
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 72EB910EA5C44FD68C-8026
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002300
   VCID: 68DFF3669B18B50622-803C
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.13
                    Time: 23:57:39
   Component: IMMO          H21 0320
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADB896E8D14871634-803E
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F6D587AEA76223E23-807A
   Revision: --------    Serial number: --------------
   Coding: 0114000001000000
   VCID: 77FDA01ACEA62AFEBB-8022
4 Faults Found:
12583424 - Databus
          U1201 00 [008] - No Communications
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 55
                    Mileage: 100298 km
                    Date: 2017.10.23
                    Time: 16:46:14
13705472 - Databus
          U1121 00 [008] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 100298 km
                    Date: 2017.10.23
                    Time: 16:46:13
13705474 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 100298 km
                    Date: 2017.10.23
                    Time: 16:46:13
13705475 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 100298 km
                    Date: 2017.10.23
                    Time: 16:46:13
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:54)--------------------------
Hope to hear from u soon. :o
numberior
Drives: Polo GTI 6r
Post by numberior »
I left out T17/6.
I've done it by the way.
numberior
Drives: Polo GTI 6r
Post by numberior »
I moved AFS supply to switched 12V.
And it instantly worked.
:P
Monday,23,October,2017,18:16:29:27502
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116   License Plate: 13TH SCAN
Address 01: Engine        Labels:. 03C-907-309-V1.clb
Cannot be reached
   Revision: --------
   Revision: V0000000
   Coding: 18BC30
   Coding: 08BC30
   Coding: 081001
   Coding: 830000
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003145
   Coding: 140A00
   Revision: B9081001
   Coding: 002300
1 Fault Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.13
                    Time: 23:57:39
   Serial number:
   Coding: 11230
   Shop #: WSC 31414
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:55)--------------------------
Thanks for all the help here.
Especially the BIG HELP extended by Cilco!
numberior
Drives: Polo GTI 6r
Post by numberior »
ciclo wrote: Mon Oct 23, 2017 11:50 am As you can see in the following image the headlights range control module (J431) is powered by fuse nº11, which receives power after turning the ignition key, +15.
... in the following image you can clearly see that +15 is the +ve signal assigned for fuse nº11.
I'm glad that everything works now, enjoy it, you deserve it. 8)
Check out these links, maybe some useful for you :) :
http://www.uk-polos.net/viewtopic.php?f ... 05#p474349
http://www.uk-polos.net/viewtopic.php?f ... 95#p477710
http://www.uk-polos.net/viewtopic.php?f ... 65#p491539
http://www.uk-polos.net/viewtopic.php?f ... 65#p491577
http://www.uk-polos.net/viewtopic.php?f ... 30#p504328
http://www.uk-polos.net/viewtopic.php?f ... 82#p517482
http://www.uk-polos.net/viewtopic.php?f ... 15#p517604
http://www.uk-polos.net/viewtopic.php?f ... 20#p518296
http://www.uk-polos.net/viewtopic.php?f ... 20#p518219
http://www.uk-polos.net/viewtopic.php?f ... 80#p520980
Thanks for your explanation on the terminals Ciclo....
@ the end of it, the result justifies all the hard work.
The cornering lights feature is fantastic.
Also those VCDS tweaks will so bring out the BCM Max :twisted: They'll be on my to-do list.
numberior
Drives: Polo GTI 6r
Post by numberior »
Hi Ciclo,
My lamps are working fine now.
As you know, I'm waiting for halogen bulbs to come in to replace the existing LED bulbs I use for cornering lights.
So I would expect errors(if any) from cornering lights.
However, errors are captured in BCM module when I activate high beam.
The code brings out "M30" and "M32", which are high beam bulbs bulbs in halogen headlights.
Is this intended, in the case of retrofit?
There's no error when cornering lights are activated.
That means to the BCM, cornering lights= high beam and vice versa?
2 Faults Found:
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.14
                    Time: 00:12:04
01499 - Bulb for High-Beams; Right (M32)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.14
                    Time: 00:12:04
numberior
Drives: Polo GTI 6r
Post by numberior »
For those interested in WRC look........
My Polo 6R, with newly fitted WRC front bumper and bi-xenon headlamps.
numberior wrote: Mon Oct 23, 2017 1:57 pm Hi Ciclo,
2 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.14
                    Time: 00:12:04
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.14
                    Time: 00:12:04
:lol:... Something odd is happening here.
Do this :arrow: https://drive.google.com/drive/folders/ ... sp=sharing
... and post a link so I can download your BCM adaptation channels log.
numberior wrote: Mon Oct 23, 2017 3:00 pm For those interested in WRC look........
[img]https://i.imgur.com/C48JjKy.jpg[/img
wow!!! 8)
numberior
Drives: Polo GTI 6r
Post by numberior »
Here is it Cilco: :o
https://drive.google.com/file/d/0B7xS6r ... sp=sharing
Latest autoscan:
Tuesday,24,October,2017,12:59:34:27502
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116   License Plate: 14TH SCAN
Mileage: 100340km-62348mi   Repair Order:
VIN: WVWZZZ6RZBY312116   Mileage: 100340km-62348miles
Readiness: 0000 0101
Cannot be reached
   Revision: --------
   Revision: V0000000
   Coding: 18BC30
   Coding: 08BC30
   Coding: 081001
   Coding: 830000
   Coding: 08BC32
   Coding: 08BC32
2 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 100300 km
                    Time Indication: 0
                    Date: 2012.03.15
                    Time: 19:35:47
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 15
                    Mileage: 100300 km
                    Time Indication: 0
                    Date: 2012.03.15
                    Time: 19:35:47
   Coding: 003145
   Coding: 140A00
   Revision: B9081001
   Coding: 002300
1 Fault Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 10
                    Mileage: 100245 km
                    Time Indication: 0
                    Date: 2012.03.13
                    Time: 23:57:39
   Serial number:
   Coding: 11230
   Shop #: WSC 31414
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:03)--------------------------
The BCM adaptation channels appear to be correct according to VCDS reading.
TESTS:
Current BCM coding
Try with these BCM codings
1st
3CB02BBF08A1000008380C916C2B0CD05AC0470F60051040200000030000
check for faults
2nd
3CB02BBF08A1000008380C916C2B0CD0DAC0470F60051040200000030000
check for faults
3rd
3CB02BBF08A1000008380C916C2B0CD0D2C0470F60051040200000030000
check for faults
By the way, all of the above is by assuming your high beams are working correctly despite the faults. According to your electrical installation the BCM does not have a diagnostic control over the highbeam lamps, it only controls the switching (lowbeam/highbeam) to activate the shutters (T73a/62).
What is the donor car of your 7E0 BCM? Where did you buy this 7E0 BCM? Do you have its PR-codes?
