BCM High to BCM Max, AFS, LED Headlights and HBA
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Re: BCM High to BCM Max, AFS and LED Headlights
Post by firegrafik »
ciclo wrote: Mon Jan 15, 2018 10:41 am
Have you checked the exterior lights with the light switch in 0 position (not Auto) and when opening the rear lid with the driver's door switch?
Checked, in all light switch positions, and with all ways of opening boot lid. Nothing unusual happens with exterinal lights.
Anyway, if I remember correct when I studied T6 diagrams. If T6 has rear lid so the T73b/56 is used for it, in this case only one T73b/28 is used as PWM for both LED headlights through the splitting relay.
The relay is only with wing doors (diagrams below), with rear lid are direct signals from BCM.
Thank you very much for all the checks you did, maybe one day we'll discover if these two signals/wires with PWM are only for diagnosis of the LED headlights modules or have some other function.
left
right
In any case, the J1069 relay representation in the diagram is intriguing ... :lol:
federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
Auto Scan with 17.8 VAG cable.
Tuesday,16,January,2018,10:09:12:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY020628   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 55
VIN: WVWZZZ6RZCY020628   Mileage: 82520km-51275miles
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021     HW: 03P 907 425 A
   Component: R3 1.2 DCM3.7 H06 8410
   Revision: 11002001    Serial number:
   Coding: 00114014002400080000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM12TDI03103P906021 001010
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 65C089086461C76E19-8030
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416F00B2842B14E482D900421700
   Shop #: WSC 00788 648 00255
   VCID: 071CA380B22D357ECB-8052
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326A22546D2F60D64C-8066
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0251
   Revision: BF046001    Serial number: 0434 160111826
   Coding: 3CB02BBF08E32600923808006D2F8CD00088672F60860000200000000000
   Shop #: WSC 12469 483 00190
   VCID: 45806988CCA1E76EF9-8010
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU030051100011446
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU025051100015419
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: K8 951 171 A    HW: K89 511 71A
   Serial number: ÿK8951171A  °103
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027051100012627
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU027051100013292
   Coding: 08BC32
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00NWXFQ
   Coding: 003232
   VCID: 4A9A5AB4EDBF081614-801E
   Serial number: 3575HRB40550INGS999T
   Serial number: 3585HRB40570INGSBHPF
   Serial number: 3515RRB40510JNPM7P50
   Serial number: 3525RRB404P0K4DOA8O1
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 140A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3A7A0A74BD5F989684-806E
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0251
   Revision: BF046001
   Coding: 002200
   VCID: 70EEE85CA3A312C67A-8024
1 Fault Found:
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 82348 km
                    Time Indication: 0
                    Date: 2012.06.01
                    Time: 10:04:14
   Component: IMMO          H03 0505
   Serial number:
   VCID: 6ADAFA348D7FE81634-803E
   Part No: 6R0 423 156 B
   Coding: 11210
   Shop #: WSC 00788
   VCID: 2F6C2B20EA1D4D3E23-807A
   Revision: --------    Serial number: --------------
   Coding: 0202000001000000
   Shop #: WSC 02757 790 50316
   VCID: 77FCD340CECD45FEBB-8022
4 Faults Found:
5256213 - Front Vehicle Height/Level Sensor
          C114D 15 [137] - Open or Short to Plus
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 26
                    Reset counter: 106
                    Mileage: 82348 km
                    Date: 2018.01.09
                    Time: 10:04:38
5256725 - Rear Vehicle Height/Level Sensor
          C114E 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 26
                    Reset counter: 106
                    Mileage: 82348 km
                    Date: 2018.01.09
                    Time: 10:04:38
5276949 - Positioning Motor for Headlight Range Left
          C1085 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 98
                    Mileage: 82348 km
                    Date: 2018.01.09
                    Time: 10:04:38
5277205 - Positioning Motor for Headlight Range Right
          C1086 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 98
                    Mileage: 82348 km
                    Date: 2018.01.09
                    Time: 10:04:38
End-------------------------(Elapsed Time: 03:03)--------------------------
AFS Module still rejected the code. I tried "0116000001000000" and "0110000001000000".
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
same like mine. cannot code byte 0 to 01. but i ve no error. I knew i bought second hand afs module from a polo. not T5. thats make me wonder. [emoji848]
federicodrdpro wrote: Tue Jan 16, 2018 9:21 am AFS Module still rejected the code. I tried "0116000001000000" and "0110000001000000".
As indicated by firegrafik, your AFS unit comes from a T5.
Buy a new one for your Polo 6R ... 6R0907357 Z03 (ESP)
Your coding for AFS unit should be this:
- with RLS... 0112000001000000
- without RLS... 0110000001000000
- in no case: 0116000001000000 (RHD, RLS)
federicodrdpro
ciclo wrote: Tue Jan 16, 2018 11:07 am As indicated by firegrafik, your AFS unit comes from a T5.
Thanks for the details. I am waiting for Vag Can Pro cable. I could try to edit the coding before buy a new AFS unit.
benzinkopf
federicodrdpro wrote:I am waiting for Vag Can Pro cable. I could try to edit the coding before buy a new AFS unit.
If i understand correctly, with VCP, we can reflash the software inside the module to the correct one. So, any idea where can we get the new software file? I would like to flash the software as well.
just a wild guess, but maybe read it from an existing module? :D
federicodrdpro
Now I have LED headlights, BCM 7E0937090C, 6Q0941334 dimmer and 2H0920871B Cluster (thanks to firegrafik).
I bought a new manual lights switch to install LED headlights, new BCM and new Cluster without Auto lights. (Like Pave's guide)
I am waiting to receive the new Stalk 7E0953507B , new HBA mirror 7E0857511G with the RLS 5K7955559B .
LED headlights + BCM 7E0 + 6Q0941334 dimmer + manual lights switch wiring:
Remove Relay J331
Install the Relay carrier
WL1
T73b/54 - T32/28
T73b/57 - T32/29
WL2
Left:
T14 / 1 - AFS T26 / 17
T14 / 2 - AFS T26 / 19
T14 / 3 - AFS T26 / 16
T14 / 4 - AFS T26 / 18
T14 / 5 - halogen connector T10 / 5
T14 / 6 - halogen connector T10 / 6
T14 / 7 - halogen connector T10 / 5
T14 / 8 - halogen connector T10 / 1
T14 / 9 - halogen connector T10 / 9
T14 / 10 - BCM T73b / 5
T14 / 11 - halogen connector T10 / 8
T14 / 12 - BCM T73b / 3
T14 / 13 - Vacant
T14 / 14 - BCM T73b / 56
Right:
T14 / 1 - AFS T26 / 15
T14 / 2 - AFS T26 / 21
T14 / 3 - AFS T26 / 22
T14 / 4 - AFS T26 / 20
T14 / 10 - T73b / 6
T14 / 12 - T73a / 5
T14 / 13 - Vacant
T14 / 14 - T73b / 28
WL3
T73b/2 - exSB39 (yellow original) (output to right low beam)
T73b/68 - SB39 with terminal (input)
T73a/2 - exSB59 (yellow/black original wire) (output to left low beam)
T73a/63 - SB59 with terminal (input)
T73a/62 - exSB34 (white/green original wire) - SB34 terminal
WL4
T73b/4 - T6/3 New Dimmer
T73b/7 - exT17/16 (original)
T73b/29 - T17/3 (isolate original T17/3)
TT73b/43 - T17/9
T73a/6 - exT17/9 (original)
T73a/45 -T17/16 (isolate original T73a/45)
WL5
T73b/7 - License plate lights
T73b/12 - T6/5 Left Tail light
I need the WL5 in my Polo?
And everything work like a charm :lol:
Am I on the right way? :mrgreen:
Fatherless One
Drives: GTI 6C
Re: BCM High to BCM Max, AFS, LED Headlights and HBA
Post by Fatherless One »
Post some photo’s once done, before and after 👍🏼
just to check, you know that HBA requires auto light switch via BCM?
federicodrdpro
Fatherless One wrote: Fri Jan 19, 2018 9:08 pm Post some photo’s once done, before and after 👍🏼
Yes, sure! :wink:
iichel wrote: Fri Jan 19, 2018 9:17 pm just to check, you know that HBA requires auto light switch via BCM?
Yes I know, but I don't have already installed the RLS. Ciclo told me that in the first place I should install the wiring for BCM Max adaptation with LED headlights. Then I can install other equipments.
Step 1: Install BCM Max + LED headlights + manual lights switch (meanwhile I can install the new cluster)
Step 2: Install HBA mirror (with windscreen adjustment) + new Stalk + Auto lights switch
Please, tell me if I'm wrong. :)
Last edited by federicodrdpro on Sat Jan 20, 2018 5:16 pm, edited 1 time in total.
that makes sense, yes. proceed! :mrgreen:
federicodrdpro wrote: Fri Jan 19, 2018 9:42 pm
Yes, sure! :wink:
You can do the whole installation at one time if it is your wish.
But you told us the conditioning factors:
- Times to receive the pieces.
- Money available for each moment. (this happens to everyone)
- Light sensor, windshield, etc...
So, makes sense to prioritize the installation processes. All installation processes (levels) are explained in this forum.
federicodrdpro
As I told, in the first place I will install BCM Max + LED headlights + manual lights switch. It's not a problem of money, I already bought all parts. I am only waiting to receive some parts. Next week I should receive all necessary to install LED headlights with manual lights switch. :wink:
If I understood I have to make a new wiring for the reverse Tail light and License plate lights.
WL5
T73b/12 - T6/5 reverse Tail light
Ciclo, can you confirm?
P.S. I am reading several threads from days but many infos are difficult to find.
