DJ's Polo 6R
Re: DJ's Polo 6R
Looks like he taped the light switch to avoid some rattle. I mean, you have a donkey polo, some of us have a few rattle snakes behind the dash making noises all trip long. :lol:
Re: DJ's Polo 6R
LOL! my rattlesnakes are still hidden, .. fingers crossed so that they do not appear. Image
claudio-dj
Drives: Polo 6R - 1,6 TDI - Highline
Re: DJ's Polo 6R
Post by claudio-dj »
Can you copy the link to the sale? For the switch is a bit 'ruined because of the many changes made and I wanted to make ahahahah [emoji28][emoji28]
Inviato dal mio SM-G950F utilizzando Tapatalk
Re: DJ's Polo 6R
claudio-dj
Re: DJ's Polo 6R
Would this be?
B- Wiring for BCM Max adaptation + Automatic Lights Wiring + CH/LH
For those with a BCM from factory 6R093708X. X=5/6/7.
You need a BCM Max (7H0937089/90 or 7E0937090), Light Switch Auto, Rain Light sensor.
Wiring for BCM adaptation + Wiring for Automatic lights + CH/LH (see above) + BCM coding + Support (via email)
Examples:
7E0 LHD. Works like a charm. 8) http://www.uk-polos.net/viewtopic.php?f ... 06#p506893
7E0 RHD (IND). Works like a charm. 8) http://www.uk-polos.net/viewtopic.php?f ... 21#p515534
7H0 LHD. Works like a charm. 8) http://www.uk-polos.net/viewtopic.php?f ... 80#p514546
7H0 D LHD. Will work like a charm. :wink: viewtopic.php?f=56&t=70853&p=529913#p529529
Price: 135€
Shipping: registered with tracking number. 16€ Europe. Charges/prices
Payment by Paypal
FULL SUPPORT
Requested information
Pictures from:
Relay carrier
Light Switch connector
Dimmer connector
Fuse box
New BCM.
VCDS Autoscan. Recent.
With this wiring can I still add the self-leveling of the headlights at a later time? Or do I have to modify your wiring?
Re: DJ's Polo 6R
Yes.
The wiring for headlamp range regulator system (AFS) is not related to the BCM adaptation wiring or Auto lights wiring.
You can install it (AFS) at the time you prefer or need.
The most important electrical installation is the BCM adaptation, everything else is secondary.
The problem is that people has their ideas on the secondary things (logically :mrgreen:), - Bixenon, Autolights, many new functions with the new BCM via coding/adaptation, Direct TPMS, etc.
But, without the BCM adaptation wiring, nothing will work correctly in 6R without BCM Max from factory. As simple as that.
However, and as a tip, the adaptation wiring looms should never be modified, the modifications are made in the original wiring (to improve it :)).
claudio-dj
Re: DJ's Polo 6R
ah ok, perfect! But then this wiring B is available? Contact me in pvt if you can ...;)
Re: DJ's Polo 6R
Claudio, I think you don't understand what I want to tell you, apart from I see that English is not a language that we both master to perfection. :lol:
I sell these wiring as a favor to forum users, I don't need to sell these wiring looms, but the materials and the use of my time due to my knowledges must be paid.
100% success.
If you want them, are you who should contact me, or request them at the sale (above link) or also here, I have no secrets for this.
claudio-dj
Re: DJ's Polo 6R
But in fact if it were not for the translator I would not be here! ahahahaha [emoji23] in any case I asked you to talk in private simply because this topic I do not think is the right one, but not for anything else! Since I'm also a moderator of the Italian forum I know the rules and to avoid problems with the mods I allowed myself, but imagine I really appreciate the work you do for users !! I simply wondered if they were available only because in some posts I seemed to understand that now you had no availability .... that's all [emoji4]
Re: DJ's Polo 6R
Under study. :wink:
claudio-dj wrote: Tue Mar 20, 2018 11:55 am
UP performed:
- Dayline GTI lights with 5000 ° xenon system
Please, can you show me an image of these headlights? thanks.
Have you made any modifications to the wiring when installing these headlights?
Please, I need you to clarify the following questions included in the below images.
In order to improve everything that be possible of be improved.
claudio-dj
Re: DJ's Polo 6R
So, the headlights I currently have are the Dectane and I did not make any changes to the wiring. for the photos you sent me it is rather difficult to answer because I do not remember the various up. However I installed retrofit, cruise control, volumetric anti-theft, folding mirrors, light and rain sensor, rear view camera and parking sensors.
Re: DJ's Polo 6R
Well, fortunately your Static Cornering Lights (SCLs) are controlled by the BCM.
I can manufacture your wiring looms for BCM adaptation and Automatic lights :arrow: 'B' (according to your current electrical installation). Your new 7E0 BCM, your new Bixenon headlights, and your automatic lights will work perfectly.
It is imperative that you install all of them at the same time. I will provide you here technical support for it.
Now, to your question by private message:
Do you want me to make your wiring looms?
YES / NO
claudio-dj
Re: DJ's Polo 6R
yes, of course you can!
Will the coming / leaving home and turning lights in the bi-xenon also work with this harness? While the fog lights will remain only such.
Re: DJ's Polo 6R
Ok, I'll start manufacturing your wiring looms today.
I explain you:
(prova a leggere senza usare il traduttore)
Your 6R is built from the factory in a certain way, which is the starting point to install the new Bixenon headlights, etc... in a correct way (factory/OEM).
To make everything work perfectly in your 6R, the following is mandatory:
1- New BCM Max. New Bixenon headlights. Light switch with AUTO function.
2- Wiring looms 'B'. BCM adaptation wiring + Auto lights wiring.
3- Adapter harness T10-T14 for Bixenon headlights.
https://www.kufatec.de/shop/en/volkswag ... ?info=8428,
This part... https://www.kufatec.de/shop/media/image ... -38357.jpg ...OK.
This part... https://www.kufatec.de/shop/media/image ... -38357.jpg ...to the trash.
or http://www.carsystems.pl/adapter-bi-xen ... d1268.html same instructions as previous links/pictures.
4- Foglights, wiring adaptation (in your case).
:arrow: https://drive.google.com/file/d/1evzipD ... sp=sharing
5- AFS (automatic headlights regulator system)
And everything will work like a charm in your 6R.
claudio-dj
Re: DJ's Polo 6R
so basically you only provide me with the right 2 point?
