Kuba591 Polo 6R 1.4 GTI Candy white 3D
Re: Kuba591 Polo 6R 1.4 GTI Candy white 3D
For BCM Byte18, 60Hex is the correct value for LED headlights. (factory coding)
The problem is that your electrical installation is not exactly the same as for 6R-family that leave the factory with LED headlights.
- You have an electrical installation for BCMs until 2014 with slight modifications in the wiring for other lights.
- 6R-family LED headlights leave the factory with electrical installations for BCMs from 2015 (the first PQ25 with LED headlights was the VW T6).
In your case it would imply doing (re-doing) this:
https://drive.google.com/file/d/0B2nv91 ... VJSzA/view (ignore the Light Assist related)
More BCM coding (Byte28, etc).
For the moment, and not having to redo anything, test the value 64 HEX in Byte18 with Byte29 with value 00 HEX.
My recommendation is that you ask firegrafik and rofireman about the matter related to the AFS unit for LED headlights (Ref number and parameterization).
iichel and CNK can also help you, they have LED headlights with AFS unit in their 6Rs (not Sedan or Vento).
