VW T5.1 Caravelle BCM Upgrade and Cruise Control on Steering Wheel...SOLVED
Limalex
Drives: Touareg R-line
Re: VW T5.1 Caravelle BCM Upgrade
Post by Limalex »
Thank you Ciclo
Monday,16,November,2020,20:18:54:36108
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZCH133237   License Plate: AJ62
Mileage: 138970km-86351mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 25 69 78 0B
VIN: WV2ZZZ7HZCH133237   Mileage: 138970km-86351miles
02-Auto Trans -- Status: Malfunction 0010
0D-Slide Door, Left -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
69-Trailer -- Status: OK 0000
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 022 JD    HW: 03L 907 309 H
   Component: R4 v002 EDC   X36 8749
   Revision: 22X36---    Serial number: 00000000000000
   Coding: 0125401A232400080000
   Shop #: WSC 79883 336 16496
   ASAM Dataset: EV_ECM20BTD01103L906022JD 002011
   ROD: EV_ECM20BTD01103L906022JB.rod
   VCID: 70ACD288AB2E1F06E3-8024
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0BT 300 045 M    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H05 1795
   Revision: 00H05V01
   Coding: 0018
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_001_VW36.rod
   VCID: 3FCE41B4A6F0B07E2A-806A
1 Fault Found:
10694 - Clutch 2 Opens Unintentionally
          P176E 00 [040] - -
                    Fault Status: 00000001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 138517 km
                    Date: 2020.11.03
                    Time: 21:23:21
                    Engine speed: 964.00 /min
                    Vehicle speed: 0 km/h
                    Coolant temperature: -40 °C
                    Clutch: primary stat: New
                    selected gear: GANG N
                    Driving position: P
                    Engine torque: 104 Nm
                    Control Module temperature: 91 °C
                    Accelerator position: 14.8 %
                    DTC memory status: 255
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 108764AD09A7089826A49074AA6510
   Shop #: WSC 02756 790 49152
   VCID: 393A2FACB0D49E4E14-806C
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
                    Fault Status: 01100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 95
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2015.04.09
                    Time: 00:00:01
                    Count: 16512
                    Count: 257
                    Count: 8215
                    Count: 764
   Serial number: 13011913470275
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB0FCB0E17A797661-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 AC    HW: 7E5 907 040 AC
   Component: ClimatronicT5 H19 0407
   Revision: 00001003
   Coding: 0004000102
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 699ABFEC88F4EECEA4-803C
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0012304120015096
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 170170512
   Coding: A0B279382E612413932888106C2B8EDD0080410F60844000300003000000
   Shop #: WSC 02737 534 163773
   VCID: 2B1605E44A883CDE96-807E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 180412 05  54  0403
   Coding: 02302E
   Subsystem 2 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Coding: 010000
   Subsystem 3 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 4 - Part No: 7E1 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 6 - Part No: 7E1 951 171
   Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39170003041710068034
   Coding: B00000
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 138242 km
                    Time Indication: 0
                    Date: 2015.03.24
                    Time: 16:17:42
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 138242 km
                    Time Indication: 0
                    Date: 2015.03.24
                    Time: 16:17:43
01504 - Bulb for License-Plate Light (X)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 138242 km
                    Time Indication: 0
                    Date: 2015.03.24
                    Time: 16:17:43
Address 0D: Slide Door, Left        Labels: Redir Fail!
   Part No: 7E0 959 243 D
   Component: Schiebetuer-SG  407 0328
   Shop #: WSC 02756 790 00000
   VCID: 302C1288A3AE5F06A3-8064
   Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H11 0013
   Revision: --------    Serial number: 47461208500166
   Coding: 108102
   ASAM Dataset: EV_VW75XParkAssis8K A01005
   ROD: EV_VW75XParkAssis8K_A01_VN75.rod
   VCID: 34241E989FB66326C7-8060
1 Fault Found:
1111828 - Front Left Parking Aid Sensor
          B10F7 14 [008] - Open or Short to Ground
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 138318 km
                    Date: 2020.10.31
                    Time: 17:31:33
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag00P H07 0013
   Revision: --------    Serial number: 003HM002866L
   Coding: 000000000000000000000000000000003050
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3620249089CA7136F9-8062
   Serial number: 3495ZRB405B0P7HOEHCF
   Serial number: 3505ZRB40510P7AOGGM1
   Part No SW: 7E0 920 980 E    HW: 7E0 920 980 E
   Component: KOMBI         H04 0306
   Coding: 460F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   VCID: 2D120BFC7C9C32EE88-8078
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 2404EED8E756F3A657-8070
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042305
   VCID: 689CBAE89BFED7C6BB-803C
   Component: IMMO          H04 0306
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6A98C0E08DF2E5D6AD-803E
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000509112665
   Coding: 0100000101000000
   VCID: 322818806DA26D16D5-8066
Address 78: Slide Door, Right        Labels: Redir Fail!
End----------(Elapsed Time: 02:03, VBatt start/end: 13.9V/13.8V)-----------
Try this new BCM coding (headlights and f fog with LED bulbs).
A0B279382E612413932888D06C2B8EDD1080412F60844000300003020000
- Clear all DTC's and visually check the lights for operation.
- Please report the results. (no need to post a new autoscan, only the permanent faults)
The static cornering lights do not work because you have to do the basic setting of G85 sensor in the ABS unit (03). Please find out how to do the G85 basic setting for your T5 on the ross-tech website (wiki) in case you have never done it before.
Have you manufactured and installed the wiring for automatic lights or just the adaptation wiring for the new BCM?
The answer seems obvious, but please confirm it.
Limalex
Post by Limalex »
Thank you i will try the coding tomorrow.
I got the wires for auto headlights but did not installed them.
The issue with lights come up well before the sensor calibration.
Yesterday i changed my stalk for a T6 one without CCS and MFD control and the calibration issue come up after that.
I am on Rosstech forum regarding that because it seems the recommended procedure not working.
Under channel03 security code accepted but on basic settings 060 calibration not available
Although probably it was my mistake because i tried the calibration without turning the steering wheel. Since i found out it is an important step. So i will make another attempt tomorrow .
Follow Dana's instructions. :arrow: https://forums.ross-tech.com/index.php? ... post-69730
If it worked for John it should work for you.
Advice:
The prerequisites are very important, as well as positioning the steering wheel between the tolerated angles.
Do the basic setting as indicated, and regardless of the result, close the basic setting, close address 03, and verify that the warning lights on the Instrument Cluster have turned off.
Take a little ride with the van, and when you park, turn the steering wheel completely to both sides.
Check again that everything is OK.
Try it as many times as necessary.
In each attempt you must exit/close completely from address 03 and re-enter for the next attempt (it is not necessary to close the VCDS program).
Regarding SCLs:
- Without G85 basic setting the SCLs do not work.
- It is likely that they did not work previously due to the type of LED lamp you are using.
We will see how to solve these problems as we progress with the tasks.
Good luck with these routine jobs.
Limalex
Post by Limalex »
Ok G85 Sensor calibrated and it works well, I copied the coding but unfortunately did not changed anything. I still have the same faults.
Led lights was there well before the BCM upgrade and I did not have any fault back they supposed to be error free. Should i replace them for the originals?
Hi Limalex, we are making progress.👍
Do the SCLs work again after performing the G85 basic setting?
Continues the license plate lights fault? :shock: (with factory yellow bulbs)
edit
I assume there is still part of the BCM adaptation wiring installation that needs to be done (at the same time you install the wiring for automatic lights that you got).
Until everything is done completely there is no point in introducing new BCM codings to avoid those faults.
Limalex
Post by Limalex »
Hi Ciclo,
Yes SCLs still not working and fault still there with the yellow numberplate bulbs.
I thought the wire mod only needed if I want auto lights that is why I did not installed them.
So I will finish the wiring mod and just in case replace all the LED bulbs to the factory ones just to start clean and see what happens.
Just to confirm. I need to fallow step three only "modify the original electrical installation - Fusebox, BCM, Light Switch" Am I right?
I done step one here wiring from ebox to BCM, but have not done the rest.
It will take some time for me to do that because this pre Christmas period is very busy and sometimes the 24 hours dat not enough to everything I planned :)
I will get back once everything ready.
Yes, you have to finish what is missing from the part of the wiring adaptation: :arrow: viewtopic.php?p=528735#p528735
It can be done on the large T17 connector, but automatic lights ('OEM way') would not be possible due to the light switch. In your case it does not make sense because you already have the RLS installed.
For you it is absolutely better to adapt the wiring for the small T10 connector for AUTO light switch, ...that is, follow the link above as described.
I totally agree with you, we are going to have to take a spaceship and travel to another planet with rotations of at least 36 to 48 hours per day ... :lol: the Christmas period was always the most complex in terms of available time.
No worries, enjoy the best you can of the Christmas period and then we continue. :wink:
Limalex
Post by Limalex »
Hi Ciclo hope you are well,
I having some difficulties. The guy who made me the wiring put wrong terminals some sides what goes on the BCM.
Could you please confirm which terminals i need to
T73/B 3
T73/A 5
T7/ A62
Also could you tell me what kind of tool i need to fit this terminals I never worked with this and my crimp tool is definitely not good for this job
Hi Limalex,
There are four types of terminals used on BCM connectors:
- MCP (multiple contact point), the three most used sizes + the MQS (micro qualock system).
You have a picture of all of them here:
https://www.a4-freunde.com/showwiki.php ... uebersicht
From largest to smallest:
- MCP 6.3 / 4.8 - Multiple Contact Point - 5.8mm
- MCP 2.8 - Multiple Contact Point - 2.8mm
- MCP 1.5 - Multiple Contact Point - 1,5mm
- MQS - Micro Quadlok System - 0.63mm
It is very easy to select the ones you need if you look at this image:
As for a crimping tool that achieves good results, I recommend ... viewtopic.php?p=537392#p537392
Very professional crimps can be made with this tool PA-21 8) , the cost of which is very reasonable.
There are high-cost crimpers with which the crimps are perfect, but they are 'very expensive'.
Note:
In all manual terminal crimping there must be a certain personal art that is learned over time. :lol:
Limalex
Post by Limalex »
Lovely great info Ciclo as always. Really appreciate it
I going to hunt the terminals and the tool and finish the job soon :)
Have a nice weekend Sir!
Be precise when crimping the terminals, it is the key for a good job. If necessary use a magnifying glass and good light to accurately visualize the bite of the crimping tool on the tabs/legs that hold the wire to contact terminal.
MCP 1.5 contact terminals are somewhat delicate, keep in mind to keep them at a perfect 90º angle with respect to the crimping tool, avoiding any other angle at all times during crimping.
Very good weekend for you too!
Limalex
Post by Limalex »
Thank you. It seems I need to buy a practice package to allow a few errors :)
Limalex
Post by Limalex »
Hi Ciclo,
I wish you a happy new year!
I hope you and the family Covid free.
I did catch it over the holiday, but luckily managed to finish the wiring.
I worked without a fault for a week than that little yellow light appeared again now with more bulb faults.
I also would like to ask something regarding my stalks. I replaced my original non sprung T5.1 stalk to a T6 sprung-type one without trip and cruise control buttons and the switching the headlights from low beam to high beam is not working. It flashing but not stay on high beam. I have to constantly pull or push it to use high beam.
It was mentioned on T6 forum that maybe there is an issue with coding and have to change BCM adaptation channel 054 from 0 to 1. When I tried it was set to 1 but on the values boxes all for showed N/A.
Have you come across something like this?
I bought the stalks second hand so maybe the switch broken. I just want to make sure the adaptation or coding is ok before I buy another one.
Wednesday,13,January,2021,14:20:35:36108
VCDS Version: 20.12.0.1 (x64)  HEX-NET CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WV2ZZZ7HZCH133237   Mileage: 140850km-87520miles
   ROD: EV_ECM20BTD01103L906022JD_002.rod
   VCID: 70ACD288AB2E1F04F2-8024
   Revision: 00H05V01
   Coding: 0018
   ROD: EV_TCMDQ500021_A01_VW36.rod
   VCID: 3FCE41B4A6F0B07C3B-806A
   Revision: 00H43001
   VCID: 393A2FACB0D49E4C05-806C
   Coding: 01
   VCID: 7EB0FCB0E17A797470-802A
   Revision: 00001003
   Coding: 0004000102
   VCID: 699ABFEC88F4EECCB5-803C
   Slave 1:
   Coding: A0B279382E612413932888D06C2B8EDD1080412F60844000300003020000
   VCID: 2B1605E44A883CDC87-807E
   Coding: 02302E
   Coding: 010000
   Coding: B00000
5 Faults Found:
02745 - Bulb for Daytime Running Light; Left
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 140850 km
                    Time Indication: 0
                    Date: 2015.06.06
                    Time: 22:19:42
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 140850 km
                    Time Indication: 0
                    Date: 2015.06.06
                    Time: 22:19:42
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 140850 km
                    Time Indication: 0
                    Date: 2015.06.06
                    Time: 22:23:50
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 140850 km
                    Time Indication: 0
                    Date: 2015.06.06
                    Time: 22:23:50
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 159
                    Mileage: 140850 km
                    Time Indication: 0
                    Date: 2015.06.06
                    Time: 22:23:50
   VCID: 302C1288A3AE5F04B2-8064
   Coding: 108102
   ROD: EV_VW75XParkAssis8K_A01.rod
   VCID: 34241E989FB66324D6-8060
   VCID: 3620249089CA7134E8-8062
   Coding: 460F01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 2D120BFC7C9C32EC99-8078
   Coding: 0000031
   VCID: 2404EED8E756F3A446-8070
   Revision: B9082001
   Coding: 042305
   VCID: 689CBAE89BFED7C4AA-803C
   Serial number:
   VCID: 6A98C0E08DF2E5D4BC-803E
   VCID: 322818806DA26D14C4-8066
End----------(Elapsed Time: 02:04, VBatt start/end: 13.9V/13.9V)-----------[CODE]
Hello Limalex, Happy New Year to you too!
Fortunately, my entire family is fine and none of us have caught Covid.
I am well aware of the current harsh circumstances of Covid in the UK, Germany, etc ... well, from all over Europe and the rest of the world. I'm somewhat concerned about it, some data gives me the creeps. I send my warmest virtual hug to all those who are suffering from these circumstances.
We must maintain personal protection measures for the good of all, and in turn we have to continue with life as close to what we knew as normal life. There are not, nor will there be, guilty or innocent in this pademic, it is absurd to think about it, but we can all collaborate so that this situation ends as soon as possible. Health personnel and other workers will end up totally exhausted physically and emotionally if we do not collaborate.
Please Limalex, explain to me exactly what wires you have installed so that I can give you a new BCM coding. Thank you.
Channel 54 of your BCM has the correct value (the first value is useful, the rest of the N/A values ​​are useless) and according to your comments those stalks with return spring for HB also work correctly.
The problem is that you are making an electrical installation for BCM adaptation and 'automatic lights' based on the T5, and for those stalks with return spring to work, an electrical installation based on the T6 is needed, which is different and many more cables need to be modified.
The electrical installation based on the T6 is the one made by Adam87 in his T5.
Therefore, in your current situation you must install the stalks without return spring and set the values of channels 54 and 53 to 0.
