2021-22 polo GTI Questions
TrebleTA
- Drives: 2021-22 GTI+
Re: 2021-22 polo GTI Questions
I'm looking for a car reader, just not sure where to start, what interface do I need. OBD2. Im after one were I can edit lthe car like I did using vcds. Around the £80-100 mark, I will be using on my 2021-22 polo also a 2020-21 vw transporter van.
TrebleTA
Guess people not to sure with a car diag reader.
Also after looking on the forum I've gone for a key fob tweak, got a gti top crome 5G0959893DFOD, also got a key fob boot 000087012AL GCA, from main dealer £25 total for the 1 key.
Spoken to iichel, his unable to help, thanks tho
- Maarten
My friend uses the RossTech VCDS Cable Full Legal Version
Look on Ross Tech site for authorised resellers
TrebleTA
I own vcds lite version, when I asked them when I got my 2016 polo, they wanted silly money, and was going to get the OBDII pro. But will reask on vcds see what they say now, as it's been years since then?
My ros tec post, what I was told back then.
[https://forums.ross-tech.com/index.php?threads/19175/]
TrebleTA
Also from my cars code LC9AL is my colour code, - the L's?
- Maarten
Colorcodes have 4 digits
LC9A is pure white
LC9A is pure white
TrebleTA
Thanks Maarten, they said its just C9A
I’ve seen VW’s Pure White paint with codes of LC9A, C9A, 0Q and 0Q0Q - I think all are correct, although the ‘official’ VW paint code for pure white - e.g. when buying touch up paint at a VW dealer - seems to usually be LC9A.
I think that historically, some VW paint colours have been shared with Audi. Maybe when this happens, VW and Audi have their own specific / different paint codes for the same colour?
This seller of Pure White touch up paint on eBay at the link below is describing it as ‘Audi / VW LC9A Pure White car touch up paint / C9A / all in one’ (so no lacquer / clear coat required). Both codes LC9A and C9A have been given.
https://www.ebay.co.uk/itm/283689292224
I bought my Pure White touch up paint off eBay. It’s not VW branded but the colour match is 100% accurate. Can’t remember how much it cost as I bought it over three years ago, but it was cheaper than the VW branded equivalent at the time. It was supplied in a ‘pen’ with a hollow nib applicator at the end of the screw on cap for precision paint application into small paint chips - IMHO so much easier to use than using the usual over-sized brush attached to the inside of the cap (it also had a brush - but a fine, thin bristled brush - inside the cap).
TrebleTA
Cool thanks
- Maarten
Correct L stands for Lack (German for paint)
All VAG paint colors/colours start with L
TrebleTA
So been looking in to a spare wheel, so far called vw they managed to fine a space saver costing £246, but was unable at time to find the center clamp that holds the spare in place, anyone know any part numbers at all, For Jack, brace and the wheel clamp male and female bits, i have the metal bracket fitted?
There are two different clamps for the spare wheel. When I bought my 2020 GTI it had the spindle, but no clamp to go on it to hold the wheel down.TrebleTA wrote: Tue May 07, 2024 11:50 am So been looking in to a spare wheel, so far called vw they managed to fine a space saver costing £246, but was unable at time to find the center clamp that holds the spare in place, anyone know any part numbers at all, For Jack, brace and the wheel clamp male and female bits, i have the metal bracket fitted?
This is mine. The clamp to go on it was VW part number 8K0-803-899, this ws for the bolt/clamp only it didn't come with the spindle.
When I first ordered the part the wrong one came for my car.
They sent me this... which didn't fit in the metal bracket around the battery. If this is what you need the VW part number is 2G0-803-899
TrebleTA
Thanks for the reply
Dark_cze
- Drives: AW GTI with MT
If you wish to spend some money then you can buy VW erwin access for a day and there should be full list of options for your VIN (and other stuff for mechanics).
TrebleTA
So I've got a new question, when I got the car I noticed the engine cover is like a lump or black plastic and plain, has anyone changed this at all, is there a better looking design, or just the way it is now?
