Page 3 of 3
Posted: Tue Jan 18, 2005 11:57 pm
by bstardchild
GroovyCarrot wrote:Eep.. I thought it was a tricky job fitting my timing belt this afternoon, that thing must be hell with the engine in the car.. how many pulleys does it need?! Really is a monster of an engine...
Erm - one less than it should have - bit of a modification I came up with years ago - the black blob just above the top run of the belt should have a pulley on it but then the water pump only gets driven on one side and you need a 2270mm belt and they are neck end of £50 from vaux
However what you can buy is a 2240mm belt - loose a pulley and get better drive on the water pump and it's £20 cheaper for 30mm less!!!!
Posted: Fri Jan 21, 2005 10:38 pm
by bstardchild
You don't need to guess what I've been doing today
Posted: Fri Jan 21, 2005 10:43 pm
by toXXin
Degrilling?
Posted: Fri Jan 21, 2005 10:50 pm
by bstardchild
toXXin wrote:Degrilling?
PMSL - it's (the grill) attached to the bonnet on a Senator
Posted: Sat Jan 22, 2005 4:36 am
by Tahrey1043
thats got an almost unearthly glow to it.... neato...
Posted: Mon Apr 04, 2005 12:15 am
by bstardchild
Final installment - rolling road session results
243 BHP and 229 ft/lb of torque at 4930rpm (With 225 or above avaliable from 1800 rpm to 6500 rpm)
Std is 204 bhp and 199.2 Ft/lb at 3600 rpm
That'll do for now
Posted: Mon Apr 04, 2005 4:48 pm
by GroovyCarrot
Anyone up for fitting one to a polo?
Looks very, very nice...
Posted: Mon Apr 04, 2005 5:24 pm
by SpikeyG40
looks the nuts mate!
good job!
Posted: Mon Apr 04, 2005 9:10 pm
by hardhitter
Looks pretty damn gucci to me mate. Your doing a good job of it. I'm guessing the blasting and powder coating cost you around a 100 quid ?
Posted: Tue Apr 05, 2005 12:47 am
by bstardchild
hardhitter wrote:Looks pretty damn gucci to me mate. Your doing a good job of it. I'm guessing the blasting and powder coating cost you around a 100 quid ?
Spot on
Posted: Tue Apr 05, 2005 12:52 am
by Tahrey1043
f***in' A
