benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
iichel wrote:I'll have you know that it took me the best part of three years to figure out that 'ciclo' is basically 'bike' in English.
And I have a t-shirt and a pillow with a bike on it. And secretly a headwarmer with "I [heart] [bike]'.
I guess I'm secretly a big fan....
:oops:
Wow. No wonder i always see "bicycle" image in most ciclo's diagram!
NEW discovery :)
Static cornering lights. Steering wheel angles.
Note: I am obliged to remember that before changing any lights configuration it is your obligation to comply with the traffic regulations of your country.
BCM adaptation (PQ25) :twisted:
Channel 33 Angle required to activate the static cornering lights. Factory setting = 80º ..... (I set in 65º to test)
Channel 34 Angle required to deactivate the static cornering lights. Factory setting = 30º ..... (I set in 20º to test)
Bixenon headlights :wink: ... :lol:
:arrow: If you remember: Channel 32 Upper speed threshold of static cornering lights. Factory value: 40 Km/h
Perhaps Channel 31 is the lower speed threshold (0). I did not have time to test. :mrgreen:
New mod
Power steering assistance to Sport mode (GTI/RS).
For example, WRC factory coding: 11221
For reference:
It must be codified with the engine OFF. ACC (logically).
My new coding:
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 00788
VCID: 2F9834F52F43FDFA07-807A
Full Autoscan:
Wednesday,25,January,2017,14:49:13:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.2.0
Data version: 20170109 DS267.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate:
Mileage:    Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6ADFBAA48F989F175F-803E
Readiness: 0010 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02778A7CE3600F3F9F-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 08021613470174
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EEB92E0FFFC17A3BF-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38A1261EDF9ECBB5CF-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 320160060
   Coding: 3CB02FBF48E1240093380ED1FCEB9FD1DAC067AF600D30D0200000030800
   Shop #: WSC 12345 123 12345
   VCID: 2A9F3AE487581FD75F-807E
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 110215 03  37  0059
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3EAB1220FFBC9763BF-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4ABFFA440FF85F375F-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   VCID: 35A22007DB61D9A0F7-8060
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002200
   VCID: 68D1C6AE9F6EAB054F-803C
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E9B32F0BF4CF7F33F-807A
   Component: IMMO          H05 0607
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   VCID: 37A0241DDB9BCDB2C7-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Coding: 11221
   Shop #: WSC 00788
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77E0A4DDD3DB4DF2C7-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3BAC1C29C38FA54EA7-806E
End-------------------------(Elapsed Time: 04:15)--------------------------
The steering assistance is still correct, in high speed you have a better feeling of stability.
This change is due to this year I feel more sporty. Image
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote:NEW discovery :)
Great work as always Fernando, [emoji106]
ORiOn
Drives: Polo BlueGT / Audi S5
Post by ORiOn »
ciclo wrote:New mod
My new coding:
Coding: 11221
Shop #: WSC 00788
I just did this a week ago. :o
Adam87 wrote: Great work as always Fernando, [emoji106]
Thanks Adam87, these possible mods for your T5.2 will have to be in the fog lights, because the function of additional lamp in the VW Transporter Bixenon Headlights is for assistance to High beam.
ORiOn wrote: I just did this a week ago. :o
I think it's a good change :wink: , it depends on the tastes or needs of each one.
Btw, in somewhere I read that you are going to buy another car soon. Some clue? Golf VI restyling? :lol:
I guess I'm secretly a big fan.... :oops:
[/img]
benzinkopf wrote: Wow. No wonder i always see "bicycle" image in most ciclo's diagram!
When I was a kid I had fun so much with my bicycle that it is impossible for me to forget about it. However it would have been another dangerous artifact if it wouldn't had been a bicycle, I'm sure. :lol:
Now I can see that almost everything is a cycle in this fascinating universe.
I decided to put a bicycle in my schemes/diagrams instead of Made by ciclo / by ciclo.
(In order to assume all the consequences/responsibility of having done something wrong in the diagrams)
benzinkopf
You really have a good "branding" there! Keep it up[emoji1360]
wamba
Drives: polo 1.2tsi
Post by wamba »
ciclo wrote:New mod
For reference:
My new coding:
Coding: 11221
Shop #: WSC 00788
Full Autoscan:
www.Ross-Tech.com
   Revision: --------
   Coding: 01
   Revision: V0000000
   Coding: 0728DD
   Coding: 0200A3
   Coding: 1000AB
   Coding: A4FFFF
   Coding: 18BC32
   Coding: 18BC32
   Coding: 308001
   Coding: 00314D
   Coding: 140E01
   Revision: B9081001
   Coding: 002200
   Revision: AA001001
   Coding: 010100
   Coding: 11221
   Shop #: WSC 00788
I had already tested in GTI mode a few months ago and I found the direction too heavy in city and I think the best setting and the original (11250)
but Good for the finding of the adjustment of the steering angle
Adam87
Drives: T5.2
Post by Adam87 »
I wonder if it can be made lighter at lower speeds with eeprom edit, VCP maybe?
wamba wrote: I had already tested in GTI mode a few months ago and I found the direction too heavy in city and I think the best setting and the original (11250)
I agree, but the truth is that this change has a double intention. I have to find something somewhere ... :lol:
It is something that I have seen and that it coincided in a Skoda Fabia and in a Polo 6R (not WRC) that they had a special configuration. 8)
Adam87 wrote:I wonder if it can be made lighter at lower speeds with eeprom edit, VCP maybe?
Maybe, are you thinking of turning your static into dynamic cornering lights? Image
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote: Maybe, are you thinking of turning your static into dynamic cornering lights? Image
This has actually been discussed yesterday with a friend, is it possible?? It was never an option on T5/6 Guessing motors need changing in the headlight if possible to mount new hardware?
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
ciclo wrote:New mod
For reference:
Wow. I got one up on the Great Ciclo. I changed the steering feel 3 years ago. :mrgreen:
I was referring to this because of the fact that you talked about VCP.
Mart!n-GTI-DK wrote: Wow. I got one up on the Great Ciclo. I changed the steering feel 3 years ago. :mrgreen:
:lol: :lol: :lol:
Do you have noticed the VCDS version of the image I posted? :mrgreen: :mrgreen:
..However this is not a topic dedicated to new discoveries that I make, It's the topic dedicated to my R-line and that's why I posted the change I made on my R-line ... other than future reasons. :twisted:
Locked
