Yes. I guess it's another good choice. :wink:
firegrafik wrote:
iichel wrote:...
PS, ciclo, does your 7E0 937 090 B BCM have the adress 65 (TPMS) available in the CAN gateway?
my 7E0 937 090 does not have it
iichel, you, me, CNK should search BCM 7E0937090B from T6 if we would like to have RKDS system. Ciclo's BCM is for Russian Polo Sedans with bixenon headlights and it doesn't work properly with LED headlights. The DRL has only one mode with full LED brightness, the parking-lights doesn't work at all.
I see. I have some money available for a T6 BCM. Any recommendations on the right Z-code?
There are so many, high window rear door, mechancally locking tailgate etc etc. i don't know it anymore, too many options :oops:
The only one I know for sure is 8T1 :mrgreen:
iichel wrote: The only one I know for sure is 8T1 :mrgreen:
CNK
Drives: 6R
Post by CNK »
Adam87 wrote:Only other way - gateway update/flash
I asked my friend about it, and there is only update to 090_0736 and 090A_0736.
Adam87
Drives: T5.2
Post by Adam87 »
That is for BCM? I know it is integrated but can gateway not be flashed independently? As it has a separate SW no
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
I suppose yes, it is for the whole BCM
For example my current BCM 7E0937090 from T6 for my LED headlights, which CNK helped me to buy, has 0736 firmware. But my previous one has 0733.
I haven't found any difference (except correct Led headlights working), maybe with 0736 firmware it was some bug fixes released...
Please share with me a little of what you smoke.Image
Oh yes!, the icing on the cake would be if you have a 'Gra_High' for my 6R 1.2TSI 5-speed MT. :?: :mrgreen:
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Russian Reverse Engineering!!!!
firegrafik
Unfortunately they produce color Mfa+ displays is only for old type clusters. For VW Colf IV, Bora, Jetta, Passat B5/B5+, Sharan and maybe Scoda Oktavia MK1, Fabia MK1, Superb MK1
Help. No hurry. :lol:
Picture from 6R WRC fusebox (SB) :?:
Cosmonaut21
Drives: 6R 1.2 TSI
Post by Cosmonaut21 »
Hello Ciclo! :D Been watching this thread for a while and i think you do a wonderfull job.
I have a question.I want to change the dash trim around the headlight switch both on my polo 6r and on my father's passat b6 but i cannot find a way to remove that thing.
Is there any way to do it? I pulled out the switch first but i don't see what else i can do.It seems glued to the dashboad.
Adam87
Drives: T5.2
Post by Adam87 »
Push in at '0' position and turn to first position, then pull out
Cosmonaut21
Drives: 6R 1.2 TSI
Oh.I meant how can i remove the trim around the switch.I have already disconnected the switch a couple of times.That's very easy.Even when i searched on ETKA it doesn't show that plastic trim as a part itself.
Locked
