sure Bronando, will try as soon as i'm back from holidays
Enjoy your holidays.iichel wrote:sure Bronando, will try as soon as i'm back from holidays
I have compared with another autoscan from another 2016 Jetta without lane assist and the test is reduced to the BCM Byte28, Bit5 (enable).
And still do the gateway to 042201?
Yes, we have to take into account all the possibilities in our experiments since we have no VCDS label for Gateway.
For the second Byte my Gateway accepts these codings (without communication faults): 002201 or 002203
chisyelamos1
- Drives: 6c 1.4tdi
Hello ciclo, i need your help!
I need to know what is the Code of this component
Sorry for the low quality of the picture
Thanks!
Enviado desde mi LG-H815 mediante Tapatalk
Thanks!
It seems to be this, but you'd better tell me where you want to connect (there are many similar models).
it's difficult to estimate the size and scale. maybe it's 1J0 972 752, but i think ciclo is right.
you can see here:
http://www.passatplus.de/umbauteile/stecker/stecker.htm
you can see here:
by the way, i just realized something.
recently i was messing a bit with the adaptation channels of the bcm.
i noticed that the headlight washers now start at the 5th cycle.
before it was at the 1st cycle.
i guess it's somewhere in 27, 28 or between 50 and 60. it just popped into my mind... but cannot test
channel 42 is to define how many cycles before the washers spray.
but what i meant is that if I pull once, before I had headlight and windscreen washers, the next 4 pulls only windscreen, then windscreen + headlight washers.
now it's 4x windscreen, 1x headlight + windscreen, 4x windscreen, 1x headlight + windscreen etc.
(channel 42 is 5 on my car)
I do not understand what the difference is, sorryiichel wrote:channel 42 is to define how many cycles before the washers spray.
but what i meant is that if I pull once, 'before I had headlight and windscreen washers', the next 4 pulls only windscreen, then windscreen + headlight washers.
5 is factory value for the 42 channel.
In any case, all the changes/modifications that you have made in coding/adaptation are in the 'Debug' folder VCDS program. Search by date.
hm you're an engineer. i don't speak engineer...
maybe a table?
maybe a table?
Thanks.
chisyelamos1
- Drives: 6c 1.4tdi
Re: RE: Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
thank you very much to both . Would be connected hereiichel wrote:it's difficult to estimate the size and scale. maybe it's 1J0 972 752, but i think ciclo is right.
you can see here:
ciclo wrote:It seems to be this, but you'd better tell me where you want to connect (there are many similar models).
maybe it's easier if you send us the link to that website instead of making photos of the screen
if it goes onto a footwell light, my first guess would be a 1J0 972 923, the one that ciclo suggested to you
