ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Locked
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
Mart!n-GTI-DK wrote: Tue Jan 12, 2021 7:52 pm Hey Ciclo. Am I so lucky that you happen to know which mal and female pins I need for the plug fra the A pillars to the front doors in the mk7?
:arrow: https://www.a4-freunde.com/showwiki.php ... uebersicht
https://www.uk-polos.net/viewtopic.php?p=575519#p575519
New fuses and connections for the installation of 8IU LED headlights.
New fuses
Previous info :arrow: viewtopic.php?p=577138#p577138
Installing the new fuse holder (4 fuses) is easy but a very hard task. :)
- To insert the fuse holder into the parking unit bracket a pliers are required.
Note: I have quite a bit of strength in my hands 🐒, but it was impossible for me to insert the fuse holder without removing the parking unit bracket.
erWin indicates a procedure to remove and install the bracket for the parking unit, but it is a crap procedure because the plastics on the bracket tabs are of very, very, very poor quality. It is very easy to break the plastic tabs.
Note: At this point I want to emphasize that currently the manufacturing quality of plastics has notably worsened (6R 2013 vs G7.5 2019), the ones used in the 6R are of better quality.
To avoid breaking the plastic tabs, it is best to remove the BCM, press lightly on the plastic tabs, and pull down the parking unit bracket. Easy.
With the help of the pliers the new fuse holder is inserted little by little and kindly into the parking unit bracket. Easy.
Note: I could have saved myself this explanation. 🤪
- Reference number of the parking unit bracket: 5Q0937503F (11€ approx)
Connections.
Once all the harnesses of this installation reach the TIUL coupling point, I proceed to connect the wires.
This is how I'm going to do it:
LEVEL SENDER G76
- Blue wire to T73a/23
- Black wire to T73a/22
- Brown wire to T73c/57 ... (ground)
FCM J745
- CAN convenience
Driver door ... 4 high green-orange , 5 low brown-orange
TIUL black ... 6 high green orange , 11 low brown-orange
- CAN extended (many devices here, slightly saturated :)))
TIUL black ... 12 high grey , 13 low brown-orange --> new splice-->T2 connector: H grey-black , L white-black
Connect to new T2 connector ... H black , L white-black
- CAN headlights
Direct connection
grey-orange ... high
brown-orange ... low
- Positive +30
TIUL black ... '8' or 9 new red-black wires.
- Negative -31
brown ... ground point.
NEW FUSES (Wires: red 2.5mm, red 2.5mm -/> 0.5mm x2, white x2: 0.75mm )
- whites (+15 headlights, SC 36 and 37) ...From 123...to   7.5A x 2
Headlights white wires. Direct connection.
- red (+30) 2.5mm -/> 0.5mm x2 ...From 120...to   10A
TIUL black ... '8' and 9 red-black.
- red (+30) 2.5mm ...From L128...to   *30A
Any TIUL 16 slot connector , choose the most easy to work in the future.
8IU LED HEADLIGHTS *Automatic headlights control. (cut T46b/2 and 39 wires with the same length :)))
LEFT MX1
- Feed (low beam). T73c/5 red wire. Direct connection (isolate original)
- Sig (High beam? - SCLs? - P/S/M - BLK - DRL). T46b/2 black-blue wire. Direct connection (isolate original)
- +15. white wire. Direct connection to fuse.
- CAN, direct connection to FCM.
RIGHT MX2
- Feed (low beam). T46b/1 red wire. Direct connection (isolate original)
- Sig (High beam? - SCLs? - P/S/M - BLK - DRL). T46b/39 black-yellow wire. Direct connection (isolate original)
- +15. white wire. Drect connection to fuse.
CAMERA -A5-
- Can Extended
To new T2 ... grey-orange to grey-black , brown-orange to white-black.
- CAN ACC --> A5
ACC. 5 High white-orange , 6 low brown-orange.
TIUL brown. 9 High white-orange , 11 low brown-orange.
- +15 positive.
TIUL black 15. green-black wire.
- -31 negative.
brown ... grown point.
- Dome lights buttons (58d). T6/3 blue connector --> T73c/62 grey... splice new black wire. (Y)
It will take some time for a new update of this installation, I have yet to receive some parts that I requested, ... between the delays due to the pandemic, the Christmas holidays, the adverse weather conditions where I live and other PRO circumstances there will be delays.
Slow but safe. We endure. We resist! :lol:
5Q0937503F
I find it very rare that this bracket has 9 dedicated places to hold the parking unit, 4 relay holders or fuse holders and another 4 for connectors or other devices and is finally held by a system that is based on two such weak tabs. In my humble opinion, a very elaborate bracket but with a weak clamping system.
I suppose it is because it is made of plastic and a new one does not imply a high cost, ... I can think of hundreds of ways to fasten it much better or repair it if necessary, however, I bought a new one. :|
Finally 👉, inserting or removing the single relay holder or the 2-fuse holder is as it should be, a very easy task and will not require removing the bracket for the parking unit, so I recommend buying this type of holder/s for your retrofits.
:mrgreen:
Heeelp! :lol: . Original wiring for HELIX sound system. CHW051419B
As some of you know, I installed the Helix sound system in my 6R:
- viewtopic.php?p=538499#p538499
- viewtopic.php?p=538553#p538553
- viewtopic.php?p=540220#p540220
Now I found this programmer on eBay:
I bought it, because I want to test the Helix sound system on my wife's Golf 7.5.
:arrow: https://www.volkswagen-zubehoer.de/de/p ... ystem.html
So I only need to install the wiring for the sound system in the Golf to be able to use the subwoofer and amplifier in both cars:
CHW051419B
Someone would be so kind to help me find this wiring or provide it to me before I decide to make it myself.
Please contact me by private message if you want to make me an offer.
Thanks in advance.
Edit
Your help is no longer necessary, thanks, I have already bought all the parts (less than 50 euros) and I have all the info to make this wiring myself.
Golf 7.5, TIUL. Highlights of the wiring installation for 8IU LED headlights and A5 camera.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/v-ZN_Dy5X ... autoplay=1
Test after the wiring installation at the TIUL coupling point.
Taking a walk to have all the sensors recalibrated due to the battery disconnection, I check with the VCDS.
Tuesday,19,January,2021,19:57:59:32438
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: TEST AFTER INST WIRING ON TIUL. 8IU LED HEADLIGHTS ... OK
Mileage: 34703km-21563mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 3C 42 44 52 5F 65
VIN: WVWZZZAUZKPCICLOW   Mileage: 34703km-21563miles
42-Door Elect, Driver -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92304C-807C
Readiness: 0110 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A4082430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DB59E-8022
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Component: Climatronic   H04 1801
   Revision: 00001K08
   Coding: 00020003200110011005004000101022
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_ACClimaBHBVW37X 006145
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 6D8734C87D161503A84-8038
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0312
   Serial number: 72007150025702
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 015F7878518EE1637CC-8054
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043  0551
   Serial number:         180705074106
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052  0107
   Serial number: SBY18M08D06H04M32S34
   Coding: 06A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0060
   Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417318277
   Coding: 0271165841
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF8838C16ED1E3ACC-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2B00678119FFC728949C810560400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 44D1B16C0E1C344B17A-8010
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA92324C-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A52A802688000801887A0D1401000000000000
   Shop #: WSC 00200 935 01530
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 2B03FAD08382DB33F60-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 09012020001767
   Coding: 030100047F085700DB00025C080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B92DBC6A24F8EB832-8024
   Generator:
   Component: 4-01-02-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190002063230049307
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
   Part No SW: 3G0 857 511 BD    HW: 3G0 857 511 BD
   Component: FLA           H01 0010
   Revision: AA001001
   Coding: 0404000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B833AD043021B33B60-803E
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0519386082
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C4886DF64583584-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0519601132
   Coding: 020111
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000305474246
   Coding: 00150320D000048000001000
   Shop #: WSC 00020 999 12345
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 48C9A55C3234102BFB2-801C
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Coding: 831F0000
   Shop #: WSC 12345 102 209715
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B322B01B32C3F37E0-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000336638884
   Coding: 00150320DE00048000001000
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 47CBA6603F2A1F53F28-8012
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Serial number:
   Coding: 02731001FF0000005111000100880A001F0500F401200000CF
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFBB56-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000250801
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1AC5EBC84CBA7A-8060
End----------(Elapsed Time: 01:22, VBatt start/end: 12.2V/14.6V)-----------
In order to ensure the following works in the installation/coding/parameterization/adaptation of the 8IU LED headlights (units) and not leaving pending work or previous faults.
Thanks :wink:
Golf 7.5 ... Helix sound system wiring. Info for DIY.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/HZ205f4we ... autoplay=1
🔎 https://drive.google.com/file/d/1d3Ixx3 ... sp=sharing
:arrow: viewtopic.php?p=579277#p579277
- The twisted wires are to avoid possible interference in the "unamplified" audio output signals from the main unit, they avoid interference due to magnetic field of the power wires that go in the harness itself, if posssible chose a different location for supply wires.
- The amplified audio output signals are not affected by these possible interferences...
- When installing the harness in the car, avoid as much as possible that the audio signal wires are close to any device or power wires.
:arrow: :arrow: :arrow: viewtopic.php?p=579907#p579907
+30 positive :arrow: viewtopic.php?p=579929#p579929
Now that no one is listening to us, I am going to tell you a secret:
January 4, 2021
January 23, 2021
On December 3 of the wonderful 2020 I placed this same order at VW PRO Service, a local store belonging to the VW group.
:arrow: viewtopic.php?p=578488#p578488
I still haven't received the part I paid for ...January 23, 2021
safm
Drives: Golf MK7.5 Variant
Post by safm »
Hello Ciclo
First I want to congratulate you for the work you do in your wife's car.
Second, I follow your topic religiously, it is a source of inspiration.
In the last few days to see and read your posts about the led headlights I had some doubts or misunderstood :(
If you can help me understand, thank you.
From what I saw in the photos of the optics, they only have pins 1,2, 5, 6, 7, 11. But when you prepared the new cables, you have placed cables for pins 4 and 6, did anything escape me?
Thank you, and continue with the fantastic work.
Hi safm, thanks for your comments.
In response to your question:
1- At first, I made my wiring looms for my new LED headlights according to the erWin diagram, but at first it was not clear to me what type of LED headlight I was going to install.
:arrow: viewtopic.php?p=577212#p577212
There are three types of LED headlights for Golf MK7.5:
- 8IT, the basic one, with only one control module per headlamp
- 8IX which is an improved version of the 8IT, with additional functions, but with the same set of internal LEDs as the 8IT.
- And finally the 8IU, the highest, and whose set of internal LEDs are ready for DLA (Dynamic Light Assist), in addition to the additional functions of the 8IX.
The last two have two control modules.
Depending on the type of LED headlights, 6, 7 or 8 wires are needed in the T14 connector.
Note: I am not sure, but I think it is also possible that the number of wires depends on the date of manufacture of the headlight.
A brief comment:
As a joke I say that there are three versions of the Golf mk7.
- The original. 2013 MY (MK7)
- The Face Lift. 2017 MY (MK7.5)
- And the Ass Lift of the Face Lift. 2019 MY (MK7.75)... those manufactured from August 2018 until the end of production (Europe).
A notable increase in improvements in each of them. My wife's Golf would be a MK7.75 ... 🤣 ... I love it.
2- After consulting with some minor gods, and subsequently having some religious conversations with Slavik (Madwarlock) 😄, I decided that I would buy the 8IU LED Headlights for the DLA possibility, despite having already updated the HBA (Light Assist basic) on my wife's Golf.
I received my new 8IU LED headlights :arrow: viewtopic.php?p=577598#p577598
That is, they are the highest but with only 6 pins on the T14 connectors. With these images you can know exactly how to manufacture your wiring looms in case of retrofitting 8IU LED headlights.
I finally left the wiring looms I made as they were. They will always allow me to install 8IT or 8IX headlights as well (if needed), because the two additional wires you are referring to are duplicate signal wires. N/A in my case.
Ground and +15, ... they are duplicated due to the internal construction of the type of LED headlight.
:arrow: viewtopic.php?p=578869#p578869
Video installation (of this part) :arrow: viewtopic.php?p=579136#p579136
I keep having fun with this process which is slow due to the pandemic, and also due to a little covert fight I have with a demigod who thinks he is a god ...
I am eating him slowly, because he tastes very pleasant ... 🤭
On the other hand, I would like to sincerely apologize 🙏🙏🙏 to all the followers of this thread due to the intentional modification by third parties :evil: of the information that I have posted in each post.
To correctly view the videos, both music and information, it is necessary to update the page as many times as necessary, until the information posted makes sense.
safm
Post by safm »
Hello Cycle
Thanks your answer.
You and Slavik (Madwarlock) are my mentors, I have also spoken to him a lot, he has a lot of patience to help me :oops: ....
I'm also going to try to assemble the 8IU optics, so my question about the cables you made.
But now with your clarification I already realized .... :lol:
I also have a Golf MK7.75 just like your wife, but mine is a 1.6Tdi Variant.
So, I apologize already, if you are bothered with doubts about some mods, Madwarlock too .... :P
I love the way you are taking your wife's car many steps ahead of the original.
A doubt, when you turn off the battery and then turn off the ECU, then when you turn on, do errors appear? Is it necessary to do anything before disconnecting?
Thanks for your nice introduction.👍
You don't have to do anything special to remove the battery and subsequently any other unit, including the engine unit (ECU).
What you should NEVER, NEVER, NEVER do is remove the ECU without disconnecting the battery, the ECU may suffer irreparable damage. It would be catastrophic.
To remove the negative battery terminal you must first remove the connector from the battery monitor, loosen the nut, and remove the negative terminal.
To install the negative battery terminal proceed in the reverse order, being very important not to connect the battery monitor connector until after having tightened the terminal nut.
Then you take a ride with the car and the VCDS, and do an Autoscan clearing all the DTCs.
If you think you are going to ask a lot of questions about technical issues of your car, it is best to open a new personal thread in this section of the forum. It is not necessary to build a magnificent thread with spectacular images or things like that, a basic thread is enough.
In this way, if you request our help, everything will be clearer to detect what is happening in your car due to the information you post to ask for help and prior information.
So, if you ask for my help it is only necessary that you post in my thread the link to your question in your thread.
Things that everyone should understand is that this is my personal thread, it is not a technical support thread.
Nor do I allow to post images or videos in my thread, ... of any kind, to anyone, I only allow the links to. :lol: (I am not kidding)
safm
Post by safm »
No, I will not kidnap your topic with photos or videos or questions about my car, that would be a lack of respect on my part.
Sorry if I made you think I was going to do it :oops:
safm, don't take it personally, it's just a generic reminder for everyone, just that.🙏
I have very good reasons to do so.
For other types of communications, there are already those other "wonderful" social networks that are not a forum, in which many things are written but practically nobody shares anything interesting and that are used mainly through that magnificent device that is small, has rectangular shape, it's used with a single finger and whose name implies that the user is not 'smart'. ... hmm ... ah yeah, now I remember the device ... the smartphone.
I think it is impossible to choose a more perfect name for said device.🤣
Locked
