UK-POLOS.NET - THE VW Polo Forum • ciclo's Polo. R-line 1.2 TSI 90hp 119gr.🤝 - Page 211
Page 211 of 333
Posted: Wed Feb 22, 2017 4:50 pm
by peza2309
ciclo wrote:
peza2309 wrote:Hi, I'm fairly new to all this but looking to start somewhere and this car looks gorgeous :D
Was wondering where you can find all these parts especially bits like the r line grille and bumpers?
Own a new 1.2 tsi 6c and parts are hard to come by I find
Hello, welcome. :wink:
:arrow: If you learn to use these links will solve many of your questions.
In the first page of my topic there are many info but remember that you have a Polo 6C and, although it is similar to a 6R they are not the same car. Keep it in mind.
6R --- 2009-2014
6C --- 2015->
Thank you glad to be here :wink:
I thought that would be the case but just wanted it clarified by someone who knows what they're doing
As I said I'm struggling to find anything to fit the 6c and if you have he names of any dealers or websites that may have bits that would be greatly appreciated?
Thanks :P
Posted: Thu Feb 23, 2017 12:01 pm
by wrecksigge
Hey guys!
Sorry for hi-jacking this thread. I have a simple question. If i wanna disable the headlight washers, is it Fuse 46, 20A in the SB fuse box i should remove?
It says:
Headlight washer system relay
On-board supply control unit
It's the On-board supply Control unit that makes me a Little confused. Does that mean it's the powersupply to the relay on the controlunit for the wipers?
Or is it better to use VCDS to remove the function?
Posted: Thu Feb 23, 2017 7:08 pm
by ciclo
Thanks :P
It's very difficult to answer your question. There are many places to shop and everyone deserves a chance.
I think it is best to search with google or your browser and ask in forums about the particular item you want to buy.
Posted: Thu Feb 23, 2017 7:48 pm
by ciclo
wrecksigge wrote:Hey guys!
It says:
VCDS only
Byte14 Bit0 disable
If you remove the 46 fuse the horn emits a deafening noise. :mrgreen: Test it.
Posted: Thu Feb 23, 2017 8:50 pm
by ciclo
Today I discovered that the rain closing works on my 6R without locking the door with the remote.
Test conditions:
Wipers lever in the first position + light switch in AUTO position and without lock the car with the remote.
Once the water is sprayed on the windshield/RLS the windows are raised and the mirrors are folded automatically at the same time, but the central locking no works...
VCDS Autoscan = first page of this topic.
Edit:
:arrow: Video here
Posted: Thu Feb 23, 2017 9:09 pm
by Adam87
Part way there Fernando [emoji848], you must have some coding correct for it to function at all
Posted: Fri Feb 24, 2017 6:27 am
by wrecksigge
ciclo wrote:
VCDS only
Byte14 Bit0 disable
Haha really :mrgreen: ? Guess ill stick to VCDS then, thanks Ciclo :D !
Posted: Fri Feb 24, 2017 8:52 am
by ciclo
wrecksigge wrote:
ciclo wrote:
VCDS only
Byte14 Bit0 disable
:wink: :lol:
Posted: Fri Feb 24, 2017 9:10 am
by ciclo
Adam87 wrote:Part way there Fernando [emoji848], you must have some coding correct for it to function at all
Yes, ... I suppose something related to the WRMs coding (btw :wink: ), or to the RLS (tested Byte1 Bit6 & Bit7 without appreciable changes for rain closing)
RLS test:
From 0728DD
To 0768DD or 07A8DD or 07E8DD (accepted codings)
Posted: Fri Feb 24, 2017 10:25 am
by benzinkopf
ciclo wrote:Today I discovered that the rain closing works on my 6R without locking the door with the remote.
Test conditions:
Did you check whether it's working after a while, let say 10mins? I've tested mine, even without locking the doors, it seems to be working only within short time, and the BCM is going to sleep mode. Once u unlock remotely after a period of time(although the car is not lock), BCM will wake up, RLS detected the water I tested, it closed the windows again.
Posted: Fri Feb 24, 2017 12:53 pm
by ciclo
benzinkopf: Good observation. I'll have to check.
to olegre:
ImageOLEGRE!... :lol: viewtopic.php?f=62&p=518599#p518599
Posted: Fri Feb 24, 2017 3:17 pm
by rdasadia
ciclo wrote:First you must show us an autoscan with your original BCM. Your question requires it.
However, I think that the best option would be 7E0937090B, as you know, to install it on your GT imply some adjustments in the original wiring. Bear in mind that the Direct TPMS (High) has not yet been tested on the POLO 6R through CAN lines powertrain.
Your best bet or my recommendation is talk to firegrafik for the BCM purchase.
Hi Below is my scan log. After you go through my scan log I have following question.
1) Difference between 7E0937090B & 7E0937090D?
2) If I upgrade the BCM for only High TPMS do I need to change/modify the wire harness for this BCM to work
3) Please help me where to buy high BCM
Chassis Type: 60 (6RU)
Scan: 01 02 03 08 09 15 17 19 25 44 56
VIN: MEXA16604GT072590 Mileage: 20km-12miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FJ.rod
VCID: 6DDBDF03BC6C5056AA-8038
Readiness: 0010 0101
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6501
Revision: 00043014 Serial number: CU501511017434
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3A71245F75A237EE7F-806E
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422A03C2461924724251C0800908
Shop #: WSC 00788 648 00255
ROD: EV_Brake1ESP90iBOSCH_AU21.rod
VCID: 0B1FB19BA2B8FE6614-805E
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 418353B3D87464363E-8014
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 087 M HW: 6RU 937 087
Component: BCM IM H+4 H40 0432
Revision: BZ040001 Serial number: 0300 015160323
Coding: 3AB02BFF08A10000013800006C2B069000C0414F608C0000200000000000
Shop #: WSC 124697 483 00190
VCID: 6CDDD2078F76595EBD-8038
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 271115 03 37 0059
Coding: 0368DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 020 2551
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED
Component: J387__TSG_BT 020 2551
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 019 1552
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 019 1552
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW012EG31
Coding: 003036
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 49934B93E844AC76E6-801C
Part No SW: 6RF 920 861 B HW: 6RF 920 861 B
Component: KOMBI H01 0215
Coding: 140800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 4A91749FED42A76EEF-801E
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 087
Component: GW-K-CAN TP20 H40 0432
Revision: BZ040001
Coding: 002300
VCID: 1933DBD310641CF696-804C
Component: IMMO H01 0215
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AD1D41F8D82476ECF-803E
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_SE12.rod
VCID: 418353B3D07464363E-8014
Address 56: Radio (J503) Labels: None
Part No SW: 6RF 035 187 HW: 6RF 035 187
Component: Radio 013 0116
Revision: -------- Serial number: VWZGZ1R3521196
Coding: 0000040000000F
VCID: 060980AFB1DA830E4B-8052
End-------------------------(Elapsed Time: 02:08)-------------------------
Posted: Fri Feb 24, 2017 3:58 pm
by ciclo
Is it the first Autoscan you did? :)
1) The second is the one I would like to have just now, but I'm afraid it does not exist yet. :lol:
If you mean 7H0 937 090 D as the second, the difference with the first is that the first has the most updated software.
I do not know if this 7H0 BCM will manage High TPMS (probably not). Hmm... 7H0937090D = aliexpress?
2)Yes. It is possible to do some tricks, but it ends up being a nightmare, so it is necessary to adapt the wiring.
3) viewtopic.php?f=56&t=58703&start=3135#p518474 (again)
Posted: Fri Feb 24, 2017 4:45 pm
by firegrafik
rdasadia, please check your private messages. Three days ago I had sent you the info concerning max BCM purchasing.
Posted: Sat Feb 25, 2017 11:49 am
by rdasadia
Yes I received it. Can you please help me purchase this BCM.
