05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
.... :twisted:
rdasadia
Drives: Polo GT 1.2TSI DSG 6R 2016
Post by rdasadia »
rdasadia wrote:
firegrafik wrote:
rdasadia wrote:
3) Please help me where to buy high BCM
rdasadia, please check your private messages. Three days ago I had sent you the info concerning max BCM purchasing.
Yes I received it. Can you please help me purchase this BCM.
@ firegrafik. Got your message. How do I communicate with you directly as I am unable to reply your private messages.
@ ciclo how do I get the wiring Harness to upgrade my BCM to 7E0
CNK
Drives: 6R
Post by CNK »
iichel wrote:01-Engine -- Status: OK 0000
.... :twisted:
So your KESSY already works? :shock: :)
ciclo, do you fancy a challenge?
i'm in the process of the kessy retrofit. so far the modules communicate with the rest of the car but keyless entry and start don't work.
i've had the modules adapted by an expert, but i'm also not sure about the VCDS coding and keyless entry.
the immobiliser part, that cannot be done with VCDS, but the coding of the BCM... could you help to check if it's ok?
i've based it on the wiring diagrams on the VW Jetta AW0 and VW Beetle. that all seems to be ok.
05 module coding 000F0F = kessy
05 module coding 010E0E = keyless entry only
25 module coding 000000 = start via ignition lock
25 module coding 000007 = start via kessy
2B module coding 4900000000000000 = DSG
2B module coding 4100000000000000 = manual trans
I have three new kessy keys that should be adapted to the immo and the 2B module and 25 immobiliser
What does work:
the two old keys for opening the door
What doesn't work:
1) the three new keys for opening the door via touch button
2) the three new keys for opening the door via keyless entry
3) switching on ignition via start button, without pressing clutch
4) switching on the engine via start button, while pressing clutch
For 1), the channel 01 of the BCM for remote adaptation should not be available, but it is available.
See: http://wiki.ross-tech.com/wiki/index.ph ... rol_Module
So here, I guess there needs be be some coding to the BCM.
Byte 25 bit 7 is 'kessy installed'. I checked this in my BCM coding, but so far no luck.
For 2), I have ordered a VAS 5054A with VAS PC V19
For 3) and 4), I will re-check wiring...
I would like your advise here, on what to code. I have some Jetta autoscans here:
https://drive.google.com/drive/folders/ ... sp=sharing
my autoscan:
Sunday,26,February,2017,11:41:56:62066
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
www.Ross-Tech.com
VIN:    License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
          61 69 6C 77 0B
VIN:   Mileage: 0km-0miles
25-Immobilizer -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: Sporadic communication error 1000
61-Battery Regul. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9978
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001041
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 2757FDE35E1F6679AE-8072
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 00788 648 00255
   VCID: 07179D63B2DF46798E-8052
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 000F0F
   Shop #: WSC 01342 020 12345
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 37772DA38EBFF6F93E-8062
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 38752E9F8BA1F98137-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 092150183
   Coding: 3CB02FF828CB2400933806E2FFEB9FD080A073EFE08D78D0228400030800
   VCID: 68D5BEDF9B81A90167-803C
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 140415 03  37  0059
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 7 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Serial number: KU0-KU008.06.0910897
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
1 Fault Found:
03444 - Ignition Starter Switch
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 110
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.02.26
                    Time: 21:34:37
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 3B7F3193B297D299DA-806E
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A916457ED4D7B1151-801E
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
1 Fault Found:
9437211 - Igniter for Driver's Airbag
          B1000 1B [137] - Resistance Too High
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 0 km
                    Date: 2017.02.26
                    Time: 00:00:05
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140E01
   VCID: 336F19B39AC71AD902-8066
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042201
1 Fault Found:
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 150
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.02.26
                    Time: 21:27:59
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 040C00E200000000000000
   VCID: 2E5908C771E537316D-807A
   Component: IMMO          H04 0709
   Coding: 000007
   Shop #: WSC 09402 015 1048576
   VCID: 6AD1C4D78D8D9B1171-803E
1 Fault Found:
10493440 - Function Limitation due to Missing Enable from OCU/VTS
          B201E 00 [009] -  -
                    Fault Priority: 1
                    Fault Frequency: 1
                    Mileage: 0 km
                    Date: 2017.02.26
                    Time: 01:54:24
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F6715C376EF3E3966-807A
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
   VCID: 2B5F01D34AF742194A-807E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 366920A781B50FF125-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH14 0120
   Revision: 00H14000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02757 790 00000
   VCID: 2F6715C3BEEF3E3966-807A
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
   Subsystem 4 - Serial number: H21982ˇ
   Part No: 6R0 423 156 B
   Coding: 11220
   Shop #: WSC 00788
   VCID: 2F6715C3EAEF3E3966-807A
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 2855FEDF53016901A7-807C
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0192000001000000
   VCID: 77F7EDA3CE3F36F9FE-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0733
   Coding: 03071A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
1 Fault Found:
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
                    Fault Status: 00100001
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 150
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.02.26
                    Time: 19:09:24
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F6715C37EEF3E3966-807A
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65CBB7EBAC93B4695C-8030
1 Fault Found:
03006 - Back-up Camera System not calibrated
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 110
                    Time Indication: 0
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_002.rod
   VCID: 254BF7EB241374699C-8070
End-------------------------(Elapsed Time: 04:32)--------------------------
(no convenience menu)
CNK wrote:
Autoscan suggests yes, practice is no.
Keyless entry, no:
https://www.youtube.com/watch?v=yI6XTAUz-2Q
Keyless start, no. Emergency start no.
https://www.youtube.com/watch?v=16dQrmmWQko
I'm still in very good contact with the kessy expert, but I'm afraid the PQ25 BCM is not his expertise
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
[emoji33]im totally amazed with what you re capable of! Kessy in 6R!!! nice.
Adam87
Drives: T5.2
Post by Adam87 »
@iichel was it marcin (spacewalker) you have spoken to? I know he retrofitted it into his 2005 touran, he's very knowledgable on IMMO / clusters etc,
What handles did you use for door unlocking?
Yes, spacewalker has been a great expert so far. He is very knowledgeable about immo, kessy and keys. He coded my cluster, kessy module and ELV.
I used the 5N0837205L door handle 4x with the 5N0839167D cover 3x and 1x 5N1837879D cover for lock
Adam87
Drives: T5.2
Post by Adam87 »
I think your in the right hands, between spacewalker and ciclo I'm sure you'll get sorted [emoji6] I wonder if them handles will fit a T5 [emoji23] did you have to drill your dashboard to fit start/stop button?
No I went for the botton on the steering column as on to Tiguan and Scirocco. It's on the place where normally the ignition key goes.
iichel wrote:ciclo, do you fancy a challenge?
:?: Test with Byte25 Bit5 enabled (also) -------- LC,25,5,Komfortschließen über Kessy
What is the reason you have Byte25 Bit2 enabled?
Also:
Byte24 Bit1
Byte20 Bit7
Byte17 Bit5
Byte3 Bit6
The first thing you have to do is read in full this forum topic :arrow: viewtopic.php?f=56&t=69121#p515534
You also can speak with graaja :wink:.
He right now is in this process of wiring adaptation (in addition to the installation of many new parts 8)).
The process would look like this (similar): viewtopic.php?f=56&t=69121&start=60#p517201
Please, take your time to think about this installation process and tell me if you would be able to install my wiring. Thanks.
(must locate the parts in your Polo GT physically and think about the installation at the same time)
Adam87
Drives: T5.2
Post by Adam87 »
Would this "Wake" line not need to be added for KESSY? Where would/have you connect it to for a PQ25 BCM
Adam87 you can have a look at the jetta (low equipment) or beetle ;) they too have kessy on pq25
Adam87
Drives: T5.2
Post by Adam87 »
iichel wrote:Adam87 you can have a look at the jetta (low equipment) or beetle ;) they too have kessy on pq25
Ah I see [emoji6] just looking through wiring and anything that may help you
I'll triple check the wiring tomorrow ;)
If you want a look at the wiring, I'll send you a link to my Google drive
Locked
