AFAIK the automatic folding mirrors function is only for WRM software (pq25 platform) that starts with 8 (due to reports from other 6R and T6).
Example (my WRMs):
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU003041440937042
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU006031440656541
Coding: 1000AB
But I have no scientific basis to assert this.
It works in all 6R and T5.2/T6 with this software.
patil
Post by patil »
ciclo wrote:AFAIK the automatic folding mirrors function is only for WRM software (pq25 platform) that starts with 8 (due to reports from other 6R and T6).
Example (my WRMs):
Coding: 0200A3
Coding: 1000AB
Thanks for the information Master.
It means my current window controller modules do not support autofolding of mirrors with remote :(
What are options available now for me to enable this feature on my Polo6R?
patil wrote: It means my current window controller modules do not support autofolding of mirrors with remote :(
Not necessarily. There is still no accurate information for this.
graaja is trying to enable his folding mirrors with the remote (via vcds), he knows what he has to do, his WRMs are the same as yours.
The codings for different hardware/software can be totally different although the amount of Bytes is the same.
Example:
My original WRM (driver's side, not folding)
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
current
Coding: 0200A3
The VCDS labels are not accurate because no one knows the different codings (Bits/definitions) for the different versions of WRMs. There are several versions (logically, 2010-2018).
I think this labels will be updated soon, but I'm afraid they will not be for our 6R.
However, the labels (7E0 for the T6, for example) can be renamed for the 6R in order to be able to use them for WRM like mine, for example.
Make a copy from 7E0 label, rename like 6R0, and paste to user folder (labels).
patil
Post by patil »
Hi Master
I did copy and renamed the 7E0 labels to 6R0 and pasted them into user folder. I did not find any difference than before in coding and long coding options.
Did I miss anything?
Our cars support comfort function for all 4 windows. I mean all 4 window glasses can be rolled up or down with remote. If our WRM's support this feature then
I think they might also support remote autofolding???
patil wrote:I did copy and renamed the 7E0 labels to 6R0 and pasted them into user folder. I did not find any difference than before in coding and long coding options.
Updated VCDS? .
The new labels will be available in the next version to 17.1.3, I guess.
rdasadia
Drives: Polo GT 1.2TSI DSG 6R 2016
Post by rdasadia »
@ciclo & @firegrafik. Thanks alot for your inputs and help.
TPMS II/High in my 6R with BCM 7E0937090B works perfectly.Image
https://ibb.co/myV41Q
rdasadia
Post by rdasadia »
@ciclo where did you purchase this sensor? Tried to search but no luck..
ciclo wrote:New Mod: RLHS (6R non Bluemotion 8))
Volkswagen. Humidity sensor.
A special sensor system in conjunction with the control algorithms in the Climatronic reduces misting-up of the windows and enhances climatic comfort by managing the humidity levels inside the car.
From the data delivered by the humidity and temperature sensor in the base of the interior mirror, the Climatronic control unit calculates the dew point temperature of the air – that is, the temperature at which the air humidity would condense. An infrared sensor remotely measures the radiated heat on the windscreen, and calculates the window temperature. To prevent the windows from misting up, Climatronic regulates the volume of air projected on to the windscreen and, with the compressor switched on, also the air humidity inside the car. Relative humidity based on interior temperature can also be kept at a pleasant level.
VCDS
BCM--> Byte8 Bit5 enabled
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 320160060
Coding: 3CB02FBF48E12400B3380FD1FCEB9FD0DAC067AF600D30D0200000030800
Shop #: WSC 12345 123 12345
VCID: 2A27B27C0FD0875FAD-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Autoscan
Monday,27,March,2017,17:31:53:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: RLHS OK
Mileage:   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6A67323C0710079FAD-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02FF02F46B187747ED-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 08021613470174
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7E730A7877749F2B0D-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38299E964716333D5D-806C
   Coding: 0728DD
   Coding: 0200A3
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E338AB877341FEB0D-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A4772DC8770C7BFAD-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   VCID: 352A989F5319412875-8060
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002200
   VCID: 68593E2607E6138DDD-803C
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E23AA8837C47F7B8D-807A
   Component: IMMO          H05 0607
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   VCID: 37289C954313353A45-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2F20AC8DB7FB650285-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77681C554B53B57A45-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B3494A17B072DD625-806E
End-------------------------(Elapsed Time: 04:21)--------------------------
Works like a charm. :D
I have tested all the automatic functions I had previously (all, many), lights, wipers (just today it was raining :lol:), etc ... and maybe it's a personal sensation, but I think all these functions have also improved in regards to the sensor sensitivity.
Previous sensor:
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 110215 03 37 0059
Coding: 0728DD
The humidity sensor function will have to be observed over time ... :mrgreen:
Previous info
rdasadia wrote:@ciclo where did you purchase this sensor? Tried to search but no luck..
probably at the dealer or a big online firm, i.e. http://www.kfzteile-profis.de/
rdasadia wrote:@ciclo & @firegrafik. Thanks alot for your inputs and help.
If there is no Autoscan, this is a joke... :lol:
Image :lol:
rdasadia wrote:@ciclo where did you purchase this sensor? Tried to search but no luck...
https://store.technikvalles.com/buscar? ... it_search=
rdasadia
Post by rdasadia »
I havent integrated the lights through the new BCM hence the Bulb Out Error :) . I want to purchase the complete wire harness from you to fully integrate the highline BCM...
Image :lol:
rdasadia wrote:I havent integrated the lights through the new BCM hence the Bulb Out Error :) . I want to purchase the complete wire harness from you to fully integrate the highline BCM...
Yes I know, and I want to help you, you can be absolutely sure of it.
I received the images of your 6R by email, but the right place to post the images and Autoscan is here in the forum. You must open a new topic.
There are many people asking for my cables and I can not attend to everyone, only to those who publish the requested information. (new topic)
You must understand that it is the best way possible for you. :wink:
patil
Post by patil »
Updated VCDS? .
Master, is it possible to install TPMS with BCM High (087)?
I am also planning to install passenger side door lock switch. The procedure you have documented is same for RHD? How easy or difficult is it do :roll:
Incitement to theft publicly (from Ross-tech software) and use of qualifying adjectives. :lol:
edit:
Video deleted.
Locked
