I think he told me that you were helping him in that matter.
Adam87
Drives: T5.2
Post by Adam87 »
ciclo wrote:
Hi Adam87, do not buy yet ... wait. :wink:
Do you think wait for a used one?
No, everything you need to know is here, thanks to rdasadia. 8)
Two links for fast people:
http://www.ebay.de/itm/391739327940?ul_noapp=true
http://www.ebay.de/itm/Neu-Original-VW- ... Swr7ZW5HUe
:lol:
iichel wrote:Maybe it also needs some wiring to pass by the external can gateway in Bluemotion 6R
ciclo wrote:I think he told me that you were helping him in that matter.
iichel, what do you think?
I apologize for the images and some comment on them ... :lol: (always with the best of my intentions)
So comfort can is there already....
You need dash can wires for the cluster, tpms and hba with 7E0
You need new diagnostics can wires to obd2
New powertrain can wires, splice i.e. with G85
New lin to old can wires for lin generator and battery monitoring sensor.
Forever remove the old can gateway and isolate the old wires :-)
iichel wrote:So comfort can is there already....
In short, everything it has already been said in my topic (a long time ago) and the recent links.
Or maybe you have not read it?
How to install 7E0937090B BCM Max for 2011 Polo 6R Bluemotion H4 halogen headlights LHD
To my friend Cihan.Image
Preview (10 pages)
View or download here
Haha havent read all of it... Only most of it :-)
Hmm... since you are moderator in the Dutch forum (long time ago) you do not pay attention to what really matters ...
I deduce from your previous reply about the CAN for TPMS that you pay no attention to what really matters... in this same page. :wink:
By the way, how about your keyless mod? Have you solved the riddle?
I'll explain the question in case you do not pay enough attention: :lol: :lol: :lol:
I do not ask you if others have solved the riddle, I ask you if the riddle has been solved by you.
Between your lack of attention and my bad english we can become the most comical couple in the whole network ... :lol:
giorgiofrattolillo
Drives: 6R GTI
Post by giorgiofrattolillo »
Hi, are you able to provide me with some help about some headlights please? Having problems with my DTRL. Would message you but i am unsure how as i only joined today. Thanks!
Welcome giorgiofrattolillo.
In order to send private messages it is necessary to have at least 10 messages in the forum.
Tell me here what the problem is with your DTRL (DRL :?:), please specify what type of headlights are. H4 single, H7 twin, Bixenon.
Hmm... GTI with front WRC bumper?
patil
Post by patil »
Master I have ordered the 4 parts you mentioned for passenger side door lock switch mod for my 6R RHD.
I want to know, what size terminals and wires are required for wiring so that I can order. Thanks :D
door lock switch = micro quadlock system, wire diameter 0.35mm2 or larger
0.5mm2 = 000 979 009 E 2x
1 wire holds two crimp connectors
Door connector T28:
Female MCP 1.5 and male MCP 1.5
000 979 025 E and 000 979 020 E, both 1x
Remember, you only lead one wire to the T28, the other two (58d and GND) are in the door wiring harness
patil
Post by patil »
iichel wrote:door lock switch = micro quadlock system, wire diameter 0.35mm2 or larger
Door connector T28:
Thanks a lot iichel :D
But according to Master Ciclo's wiring diagram, 2 wires(T28a/11 to T28/14 and T28a/14 to T28/15) lead to door lock switch,
plus other two 58d and GND from door wiring harness as you said.
Am I missing something?? :roll:
Here :arrow: viewtopic.php?f=56&t=58703&start=75#p473025
ciclo wrote:Welcome giorgiofrattolillo.
https://scontent.cdninstagram.com/t50.2 ... 7696_n.mp4
Image wow! :lol:
patil wrote: :lol: :lol: :lol: ciclo I have ordered the 4 parts you mentioned for passenger side door lock switch mod for my 6R RHD.
How many times will I have to post the following link?
viewtopic.php?f=10&t=42713#p466570
I can assure you that all the information you need is contained in those links with absolute precision.
First look at the etka the connectors reference of your car. (At the end of the electrical part)
Then look at the Russian link to know which terminals are needed for each type of connector depending on numbers of pins.
It's really simple.
Please understand that it takes me the same time as anyone to do the necessary searches ... :wink:
Locked
