i managed to get my hands on a gearbox in the end, all free
cleaned it and test fitted it so i could do a little wiring.
i welded up the hole in the floor
been sanding the block down for respraying, cleaning and fitting the spacer plate and flywheel.
and just a few of the engine quickly built up.
just doing some little bits that need doing for the engine.
started sanding alt and steering pump holder ready to polish.
crank seal plate has been cleaned and new seal fitted.
some more polishing on the engine mount to finish off.
been cleaning the steering pump and need to prep the crank pulley for powder coating.
gunna be painting the gearbox and engine block soon so will post an update as soon as these are done
cheers for looking guys.
