[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 UK-POLOS.NET - THE VW Polo Forum • ciclo's Polo. R-line 1.2 TSI 90hp 119gr.🤝 - Page 23
This tutorial is especially dedicated to Holger44805 (GE) and peter_dk25 (DK).
I hope it's very useful for romingo (FR) and Israel (SP), of course is available to everyone.
Before continuing I want comment that coding is not the same for Polo 6R four doors. After playing for a couple of hours with hexadecimal and binary, I got the correct coding so that everything works correctly on a Polo 6R with four doors without losing any feature.
Parts:
There are different references depending on the situation of the steering wheel (LHD, RHD) and the number of doors.
You can find the right parts here:
Works perfectly, like a charm and I very happy about it!
Video
------------------------------------ Tilt passenger mirror when putting reverse
Why is not possible tilt passenger mirror in Polo 6R?
- Because the signal regulating power mirrors is through of the fuse SB12, and not from the BCM, so tilt passenger mirror is IMPOSSIBLE with original parts. With rear view camera, solved it.
BCM provides the following functions for the wing mirrors in Polo 6R: Heated
Directly, for example when is active heated rear window.
Folded
Through BUS line with comfort function for remote.
Posted: Sun Jul 27, 2014 9:13 pm
by Domjames
Hi circlo, could you help me with this one please, my 2011 6r has central locking but not remote, is it possible to retrofit?
Cheers in advance
Dom
Posted: Mon Jul 28, 2014 10:32 am
by ciclo
Hi Domjames,
What is the reference number BCM of your vw polo?
Ciclo, thank you!! Mine is 6R0 937 085Low / medium
Posted: Mon Jul 28, 2014 9:41 pm
by benzinkopf
Hi Ciclo, on the Rain closing, do you have Rain closing Option on your instrument cluster MFA+? I don't have MFA+ in mine, so I'm not sure whether the rain closing box is there or not. I believe, to activate the feature, we need to enable the code in BCM, in sub-code RLS, and in the Instrument Cluster setting.
Posted: Tue Jul 29, 2014 2:31 am
by ciclo
Domjames wrote:Ciclo, thank you!! Mine is 6R0 937 085Low / medium
Damn, the more difficult ... Do the following
-With VCDS check that bits 3,4,7 are marked.
-Lower the driver and passenger windows (and rear if any) in half.
-Close the door.
-Enter the key in the door lock cylinder.
-Turn the key clockwise (close LHD ) and hold for a few seconds.
If the windows go up while holding ... congratulations!Tell us the results.
I checked in my r-line and it works perfectly, up the windows and mirrors folded. (bus line T16/5 both window regulator motor to T73b/17 BCM)
