patil
Post by patil »
Thanks a lot Master :D
iichel is telling that I have to lead only one wire to T28, but according to your wiring diagram I can see 2 wires being tapped from T28a to T28.
Please clarify the confusion :roll:
1 repair wire = 2 terminals = two wires to T28.
patil
Post by patil »
iichel wrote:1 repair wire = 2 terminals = two wires to T28.
Ah.. now understood :mrgreen:
Thanks buddy :D
patil
Post by patil »
Master.....Regarding passenger side door lock switch mod
Can I tap line from all the 4 wires from the driver side central lock switch and route it to passenger side central lock switch???
Will it work or its a bad idea to do so?
patil wrote:Master.....Regarding passenger side door lock switch mod
bad idea
Image 8)
patil
Post by patil »
bad idea
Understood... thank you master :D
Click :arrow: BOOM! :lol: ... I think it might be interesting.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Today i notice a difference in the CH light activation. If i activate it (pull highbeam stalk) before the door opening, then once the door open, CH light will run for 15secs. But, if i open the door first, then pull the stalk, it seems like CH light will continue to run until i lock the car. Hurm. Anybody can confirm?
benzinkopf wrote:Today i notice a difference in the CH light activation. If i activate it (pull highbeam stalk) before the door opening, then once the door open, CH light will run for 15secs. But, if i open the door first, then pull the stalk, it seems like CH light will continue to run until i lock the car. Hurm. Anybody can confirm?
:arrow: Read page 113 and tell me what you think.
benzinkopf
I think u re awesome!
i may have accidentally locked car exactly 15sec after closing all doors which made me think the CH switch off after i locked. [emoji23]
New VCDS Autoscan
Testing. Nothing remarkable at the moment. :|
Friday,28,April,2017,11:47:25:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: TESTING
Mileage:    Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6A67323C0710079FAD-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02FF02F46B187747ED-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 08021613470174
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7E730A7877749F2B0D-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38299E964716333D5D-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 320160060
   Coding: 3CB02FBF48E12400B3380FD17CEB9FD0DAC067AF600D30D0200000030800
   Shop #: WSC 12345 123 12345
   VCID: 2A27B27C0FD0875FAD-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E338AB877341FEB0D-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A4772DC8770C7BFAD-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   VCID: 352A989F5319412875-8060
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002200
   VCID: 68593E2607E6138DDD-803C
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E23AA8837C47F7B8D-807A
   Component: IMMO          H05 0607
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   VCID: 37289C954313353A45-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2F20AC8DB7FB650285-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77681C554B53B57A45-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B3494A17B072DD625-806E
End-------------------------(Elapsed Time: 04:17)--------------------------
It will be updated to the first page of this topic.
Pave
Drives: 1.2 Tsi Highline 2011
Post by Pave »
Hi ciclo!
First greetings from Finland!!
I´m planning to install oem xenon lights to my Polo. I´ve read most of the topics about those procedures, but as you said, each car is individual depending many variations and so on.
So I´m asking is it possible to get your help installing those. I have to say that at this moment I can´t istall those full oem way (New bcm max, auto levelling system etc.)
Cars with xenon lights are needed that auto levelling and headlight washers here in Finland, so I have to remove those xenons once a year because MOT... that´s why I´m asking can I get those working in any way.
This time I want to install those just to get the lights working someway... don´t need dimming leds or so on...
Just asking is there any way to get those work in any way??
I will open new topic or whatever way you like if you want to help. But if you don´t have time or don´t be interesting because that partly installation, I understand.
Of course I will post vcds scan and needed pictures when necessary, but as I said this is first and humble inquiry :)
Not to be rude, but who are you fooling with changing the lights for mot... The rules are for a reason ;-)
Pave
Post by Pave »
I think fooling myself only :)
But there are many more who uses for example xenon kits in their normal headlights...
In my opinion, those produce more harmful reflections
Locked
