patil
Post by patil »
Master Ciclo... I have a question regarding trunk light wiring.
Actually Indian Polo 6R does not come fitted with trunk light. I have retrofitted the trunk light and tapped the wiring from front dome light. So whenever any of the doors are opened trunk light will turn on, same way as footwell lights. I want to wire it like oem, so that light should lit only when trunk is opened and go off when trunk is closed. Is it possible?
I looked into wiring diagram, mentioned during your 2nd trunk light installation.
Pin 1 tapped from Pin1 T5h(Rear lid lock) RED/BLUE color wire.
Pin 2 from +30
Now the problem.. The RED/BLUE color wire in my car is in pin4, and a white wire is on pin1... please see picture.
How to proceed from here? :roll:
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
I believe you can tap and use any usable 30+ power line for the trunk light but to make it work like oem, all you need is the right Ground wire, in this case either Ground wire of the rear lid locking motor or directly to T73a/35 bcm.
graaja
Drives: Polo GT TSi
Post by graaja »
iichel wrote: Sat Jun 10, 2017 5:07 pm This is the cluster from a T6 with custom firmware for Polo (vehicle picture, wheel circumference, tank level) and Kessy. No dealer will do this for you.
I will stop thinking about it even in my dreams then :mrgreen:
Adam87
Drives: T5.2
Post by Adam87 »
iichel wrote:This is the cluster from a T6 with custom firmware for Polo (vehicle picture, wheel circumference, tank level) and Kessy. No dealer will do this for you.
I though T6 only came with 3D in colour not 2D, or is it because it's 2D FW on there?
favi
Drives: 6R
Post by favi »
Hiho ;>
Today I wanted to encode "Cornering Light With Reverse Gear". Unfortunately, but failure. Has anyone coded in Polo6R such a function?
benzinkopf
Yes. Byte 21 Bit 3. Its not "Cornering light" but "Foglight" instead.
favi wrote: Sun Jun 11, 2017 4:10 pm Hiho ;>
viewtopic.php?f=56&t=58703&start=765#p491577
For front fog lights or bixenon, the cornering lights function can work on one or in the other. (depending on equipment)
patil wrote: Sat Jun 10, 2017 8:15 pm Master Ciclo... I have a question regarding trunk light wiring.
Pin 2 from +30
... in your case (6R IND), the winner ('ground wire') for trunk light is purple/violet wire. You can check with a diagnostic lamp/multimeter before splice or damage this wire.
Power supply is right (from the dome light).
favi
Drives: 6R
Post by favi »
ciclo wrote: Sun Jun 11, 2017 5:43 pm
Thank you very much ;)
benzinkopf wrote: Sat Jun 10, 2017 10:50 pm I believe you can tap and use any usable 30+ power line for the trunk light but to make it work like oem, all you need is the right Ground wire, in this case either Ground wire of the rear lid locking motor or directly to T73a/35 bcm.
No,... hmm ... and no. :lol:
Any power wire/line has its own fuse due to many reasons. Hmm, maybe, the electrical installation of the interior lights is one of the most manipulated by everyone.
T73a/35 = sunroof output
Adam87 wrote: Sun Jun 11, 2017 1:55 pm Sent from my iPhone using Tapatalk
Hi there :D
read here
viewtopic.php?f=56&t=58703&p=520980#p520937
:wink:
:lol: I thought so. 8)
benzinkopf
Sure master. Connecting to any power line will not go through the exact fuse as intended. Btw, the T73a/35 is wrong? I may have overlooked the original my 6R diagram which is different from IND production or Bcm max? Thanks for the correction.
benzinkopf
ok. Sorry. Totally my fault or typo. It should be T73a/31. [emoji23]
No worries, I am the first to make mistakes.
With the errors/tests, wisdom is attained (sometimes :lol:).
favi
Drives: 6R
Post by favi »
Little problem with The two static cornering lights turn on with reverse
Don't have BIT3 :(
Locked
