Locked
benzinkopf wrote:Hi Ciclo, on the Rain closing, do you have Rain closing Option on your instrument cluster MFA+? I don't have MFA+ in mine, so I'm not sure whether the rain closing box is there or not. I believe, to activate the feature, we need to enable the code in BCM, in sub-code RLS, and in the Instrument Cluster setting.
Hi benzinkopf, thanks for trying to help. :wink:
MFA + for Polo 6R does not have convenience menu, the problem is in BCM and its firmware, reject coding.
Other 6R have active rain closing and not have MFA +.
Domjames
Post by Domjames »
Ciclo, yep the windows close while holding key turned in drivers door! So what does this mean?!
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
oh i see. Hurm. I really don't understand the logic there. It must be able to activate it right away.
There must be some Bits that hold the activation as currently, the labels inside VCDS for Polo 6R is mostly unknown.
too bad.
Domjames
Post by Domjames »
Ciclo, yes the windows do close when I turn the key in the drivers door, what does this mean!?
Your bcm supports folding mirrors function.
Domjames
Post by Domjames »
Ciclo, sorry mate think we have wires crossed, I was after having remote central locking!
benzinkopf
what do you guys mean with turn the key in the drivers door and supports folding mirror functions? it's supported but need to replace the mirrors that have motors inside right?
Domjames wrote:Ciclo, sorry mate think we have wires crossed, I was after having remote central locking!
Sorry for my mistake, I thought you meant the folding mirrors. :oops:
I can not help you with retrofitting remote central locking because I've never done it.
If I find interesting information I will let you know. :wink:
benzinkopf wrote:what do you guys mean with turn the key in the drivers door and supports folding mirror functions? it's supported but need to replace the mirrors that have motors inside right?
Exact, and more:
http://www.uk-polos.net/view ... 30#p481352
Domjames
Post by Domjames »
Ciclo, would really appreciate it thank you
benzinkopf
Hi Ciclo, need a favor from you, do you know which Fuse Number inside Fuse Holder B(drivers side) which is Duration+ 5A? Power source which is always Active while the car is locked.
+30 :wink:
benzinkopf
Oh. thank you very much.
So is that means all the Terminal 30 should be duration+?
yes,
+30 is permanent.
+15 only when ignition on.
-31 ground.
It is used in the diagrams. For example:
benzinkopf
thanks Ciclo
JayW
Post by JayW »
Hi Ciclo,
Can you tell me what I need for Bi-xenon conversion? I have the Halogen units in at the moment but wanting to upgrade to bi-xenon. Do I need a cable harness adapter and also do I need coding?
Thank you!
Jay
Locked
