Page 24 of 333
Posted: Tue Jul 29, 2014 2:56 am
by ciclo
benzinkopf wrote:Hi Ciclo, on the Rain closing, do you have Rain closing Option on your instrument cluster MFA+? I don't have MFA+ in mine, so I'm not sure whether the rain closing box is there or not. I believe, to activate the feature, we need to enable the code in BCM, in sub-code RLS, and in the Instrument Cluster setting.
Hi benzinkopf, thanks for trying to help.
MFA + for Polo 6R does not have convenience menu, the problem is in BCM and its firmware, reject coding.
Other 6R have active rain closing and not have MFA +.
Posted: Tue Jul 29, 2014 6:51 am
by Domjames
Ciclo, yep the windows close while holding key turned in drivers door! So what does this mean?!
Posted: Tue Jul 29, 2014 12:05 pm
by benzinkopf
oh i see. Hurm. I really don't understand the logic there. It must be able to activate it right away.
There must be some Bits that hold the activation as currently, the labels inside VCDS for Polo 6R is mostly unknown.
too bad.
Posted: Tue Jul 29, 2014 4:12 pm
by Domjames
Ciclo, yes the windows do close when I turn the key in the drivers door, what does this mean!?
Posted: Tue Jul 29, 2014 4:53 pm
by ciclo
Your bcm supports folding mirrors function.
Posted: Tue Jul 29, 2014 4:55 pm
by Domjames
Ciclo, sorry mate think we have wires crossed, I was after having remote central locking!
Posted: Tue Jul 29, 2014 9:03 pm
by benzinkopf
what do you guys mean with turn the key in the drivers door and supports folding mirror functions? it's supported but need to replace the mirrors that have motors inside right?
Posted: Wed Jul 30, 2014 1:55 am
by ciclo
Domjames wrote:Ciclo, sorry mate think we have wires crossed, I was after having remote central locking!
Sorry for
my mistake, I thought you meant the folding mirrors.
I can not help you with retrofitting remote central locking because I've never done it.
If I find interesting information I will let you know.
benzinkopf wrote:what do you guys mean with turn the key in the drivers door and supports folding mirror functions? it's supported but need to replace the mirrors that have motors inside right?
Exact, and more:
http://www.uk-polos.net/view ... 30#p481352
Posted: Wed Jul 30, 2014 7:10 am
by Domjames
Ciclo, would really appreciate it thank you
Posted: Mon Aug 04, 2014 7:49 pm
by benzinkopf
Hi Ciclo, need a favor from you, do you know which Fuse Number inside Fuse Holder B(drivers side) which is Duration+ 5A? Power source which is always Active while the car is locked.
Posted: Mon Aug 04, 2014 7:54 pm
by ciclo
Posted: Tue Aug 05, 2014 3:32 am
by benzinkopf
Oh. thank you very much.
So is that means all the Terminal 30 should be duration+?
Posted: Tue Aug 05, 2014 11:02 am
by ciclo
yes,
+30 is permanent.
+15 only when ignition on.
-31 ground.
It is used in the diagrams. For example:
Posted: Tue Aug 05, 2014 6:31 pm
by benzinkopf
thanks Ciclo
Posted: Wed Aug 13, 2014 1:24 am
by JayW
Hi Ciclo,
Can you tell me what I need for Bi-xenon conversion? I have the Halogen units in at the moment but wanting to upgrade to bi-xenon. Do I need a cable harness adapter and also do I need coding?
Thank you!
Jay
