Tyre_Pressure_Monitoring_Systems_2014.
:arrow: Self-study Programme 541
Midline TPMS with auto-location function
System configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31
How the Midline TPMS works . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34
(Self-Study Program 861603)
U :lol:
patil
Post by patil »
Hello Master need your help again :wink:
I am trying to complete the installation of autofolding mirrors with module K418 and 5 pin relay.
I did the wiring exactly same as you did previously. After completing installation, only Rt side mirror folds and unfolds with remote. :(
I checked the wiring two three times and everything seems to be correct. Am I missing something??? :roll:
Will the wiring be different on my RHD 6r? Your suggestions will be able to help me :D
On another note, I installed OEM passenger side central door lock switch and it works perfectly :lol: Thanks a lot Master :D :D
gtsportms
Drives: Polo 6R
Post by gtsportms »
Hey ciclo,
do you know how i get this cruise controll Symbol ?
This Screen is from a WRC, i have a BlueGT speedometer in my 1.2 TSI. I have only this Blue Symbol on the Speed Display.
We tried and tried and tried. But it appears to be a software in the cluster.
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
iichel wrote: Fri Jul 07, 2017 6:33 am We tried and tried and tried. But it appears to be a software in the cluster.
I suppose it is the engine's control unit software issue. In Russia several Polo sedan owners had installed WRC's cluster but they don't have cruise icon on display, only green icon.
Ah yes. ciclo showed some movies of WRC clusters in the 1.2 TSI with cc high. There is an adaptation channel in the Polo WRC cluster for GRA high but not available. Maybe it's unlocked by the engine ECU.
dinoslmn
Drives: Polo 6C, 2016, 5D, 1.2TSI 90HP DSG
Post by dinoslmn »
Hello All,
How know if this connector 4D0971636 ( for dash switch) have also a male plug.
Want make an adapter with one end this 4D971636 and second one a male plug for same conn.
Or which male terminals can be used with above connector.
I have a little PCB for disabling the START/STOP function.
Put the ST/STP button contact to ground after 4 sec from key switch is ON
Not need to push the button every car start....especially in the morning....
Polo 6C BM not have a smooth start/stop....
Thank
Dino
dinoslmn wrote: Sun Jul 09, 2017 7:01 am Hello All,
Thank
Dino
For example,... search here :arrow: http://www.servotechnica.spb.ru/library ... ther_parts
Check out the five pdfs for 6-pin connectors.
firegrafik wrote: Fri Jul 07, 2017 6:51 am
iichel wrote: Fri Jul 07, 2017 8:23 am Ah yes. ciclo showed some movies of WRC clusters in the 1.2 TSI with cc high. There is an adaptation channel in the Polo WRC cluster for GRA high but not available. Maybe it's unlocked by the engine ECU.
Maybe.
I think this feature will never be possible to activate it in our 6R ... it is extremely suspicious that the new Polo Sedan GT or the new Polo 6R IND,etc... (2016) do not have this feature from the factory ... when this feature is present in other VW models much cheapers (FOX, GOL...)
VWelcome to the:
:lol:
Btw, I have a lot of info for the direct TPMS, but I still have to try out a new TPMS unit ... :roll:
for example: https://www.drive2.ru/l/459902900106204 ... 3372786266
lukafoto
Drives: A2 Polo 6R conversion !
Post by lukafoto »
Hi Ciclo
Trying to work out pins on the BCM / J519 with the T73 connectors and the dash wiring and ECM for Polo 6R 1.4 CGGB rerto fit into Audi A2.
Any ideas? https://goo.gl/photos/nHzXvUpbuvV9S7MA9
lukafoto wrote: Sat Jul 15, 2017 4:13 pm Hi Ciclo
For the T73a and T73b of the BCM: https://drive.google.com/open?id=0BxYPV ... 3VwWjhvbVU
Apart from that, it's maybe best to open a new topic (IIRC you already have one) and ask more specific questions there.
Hi lukafoto
1. Look at your inbox. Download the documents (mainly 6R and Amarok - at the end of the documents are the definitions you need). Forget the 6C, is not related with your project.
2. Follow iichel's recommendation. Open a new topic in the forum, to encapsulate all the information there (every step you take).
3. I recommend you (without a doubt) the Elsawin, it is easier to handle than the documents you have downloaded. Also to compare with your A2.
Wow! This wiring adaptation is a huge project. I think you're going to need a lot of help (expert help) to make everything work properly.
I think you should reconsider if this project is worth it.
7E0937090C Z0E
Clarifications:
Thanks to firegrafik (and our friends from drive2.ru/com) and, on the other hand, thanks also to ETKA we can already assure that this new BCM is 434 MHz and can be installed in POLO 6R and many models of its extensive family. 8)
Previous comments and important information:
- viewtopic.php?f=56&t=58703&start=3435#p522135
- viewtopic.php?f=56&t=58703&start=3045#p517670
What's new in this BCM:
Still to be discovered ... :lol:
A new hot day in Spain ... I'm afraid today will be another pool/beach day without doing anything at all :) ... by the shade, baths, refreshing drinks and food for crickets (salads), etc :mrgreen: ...
Tough days Fernando haha...! Enjoy!!
Hahaha ... thanks, same to everyone.
The same forecast for today !! :lol:
Locked
