patil wrote: Fri Jun 30, 2017 2:55 pm Hello Master need your help again :wink:
I am trying to complete the installation of autofolding mirrors with module K418 and 5 pin relay.
I did the wiring exactly same as you did previously. After completing installation, only Rt side mirror folds and unfolds with remote. :(
I checked the wiring two three times and everything seems to be correct. Am I missing something??? :roll:
Will the wiring be different on my RHD 6r? Your suggestions will be able to help me :D
On another note, I installed OEM passenger side central door lock switch and it works perfectly :lol: Thanks a lot Master :D :D
Surely. Your 6R has folding mirrors (WRMs) from the factory (WRMs without automatic function). While the installation with the module K418 and 5 pin relay is for Polo 6R Europe with WRMs without function for folding mirrors.
:? I would never have done this electrical installation on your 6R IND with electrical installation for folding mirrors from factory. I would have searched for the right WRMs.
The WRMs software should be like mine or higher:
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU003041440937042
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU006031440656541
Coding: 1000AB
Remember, this WRMs references/part numbers are for LHD. Your 6R is RHD.
When I did the NO OEM installation there were no WRMs with automatic function for LHD, as soon as it was possible (my WRMs coming from the firsts Polo 6C manufactured) I did the OEM electrical installation.
OEM
NO OEM
:lol:
Meanwhile, separate theme:
Waiting to receive the new TPMS module to test, or also I waiting for a zdc file :) for the current TPMS module. (direct TPMS)
patil
Post by patil »
Thanks a lot Master for the reply.
I should have consulted you before only... my bad :(
I have to undo all the wiring now... painful :(
But then here you go... a lesson learnt.
I will keep in mind whatever you have said about folding mirrors, before venturing again :D
Happy Vacation Master... enjoy 8) :wink:
Rojofuego
Drives: 1.2 tsi 90 r line
Post by Rojofuego »
Hi Ciclo
I have a doubt.
I have a Vw Polo1.2 tsi 90 (2017) with standart suspension
I wanted to install oem sport springs and shock absorbers
How can I know the references?
Por cierto soy de España.
Podemos hablar por mail o WhatsApp?
You can find the correct part numbers in etka.
The OEM lowering kit is a rebranded H&R kit if I'm not mistaken.
The OEM sport suspension has either the sport select adaptive dampers, or the normal dampers that you'll also have in the normal kit. The springs are different and you can find the part numbers in etka.
When buying new springs, always keep in mind the correct axle loads at the front and the back.
Rojofuego
Post by Rojofuego »
The rear parts, I think I have localized references.
The problem is with the front of the suspension.
I do not differentiate between the pr codes of normal and sport suspension
My front spring has 3 green dots and 3 white dots.
BVS-
Drives: 6R 1.2 TDI BM
Post by BVS- »
ciclo wrote:New Mod. Auto folding mirrors OEM.
This tutorial is especially dedicated to Holger44805 (GE) and peter_dk25 (DK).
I hope it's very useful for romingo (FR) and Israel (SP), of course is available to everyone.
Hola Ciclo,
I am
Trying to do the same mod as you because i love it!
But i am stuck at making the extra wiring because the link to the contacts is broken. Do you have a working link to the contacts which have the correct measurements to make the wiring? Also with what kind of tool do you connect the wires to the contacts?
Muchas gracias!
PS. Here is the link to my topic. It is in dutch but you could have a look and see which part numbers i have for the mirrors and motors etc.
Polo 6r - bvs
https://r.tapatalk.com/shareLink?share_ ... are_type=t
Verzonden vanaf mijn iPhone met Tapatalk
All the new contacts are micro quadlock system connectors.
https://www.a4-freunde.com/showwiki.php ... note_ident
I had a quick look and all the info you need is still there :-)
4StringBass
Drives: 2017 Polo GTi
Re: New Member. R-line 1.2 TSI 90hp 119gr.
Post by 4StringBass »
ciclo wrote: Tue Apr 09, 2013 11:35 am New mod:
Garage door opener button.
Image Image Image Image Image
Could this be done using the 'Sport' button instead of the traction control button?
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
Marjacic wrote:
gpeixoto109 wrote:
Marjacic wrote:[url]https://www.youtube*.com/watch?v=WZSKZsTZ8JU&feature=youtu.be[/url]
Did it :!: :g :mrgreen:
It would be nice if it was possible to have the navigation futures in it to, to show the road when navigation is on, compass and that stuff.. :cry: :roll:
happy holidays :lol:
Hello Marjacic what is the reference of your tacho? Did you used the amarok tacho or you found a reference for the polo?
If the amarok one how did you changed the circumference of the wheel, the volume of the deposit tank and how did you changed the pictogram for the image of the polo?
Thank you! :D
Hello gpeixoto109
i used the tacho from an Amarok part no. 2H0920871 without any letter at the end, if you buy ex: 2H0920871"A" then it is not possible to fit because of the software is to new.
But you have to find a guy in the German forum called potatodog, he have the tools to fix the tachos and do som Eeprom and change the pictogram :lol:
If ending of vw amarok cluster is with Letter B it won't work with Polo 6R?
@4String2Bass: Yes but be sure to check the wiring diagram for the correct pins.
smg_shardul
Drives: Polo 6R
iichel wrote:@4String2Bass: Yes but be sure to check the wiring diagram for the correct pins.
I have already purchased this cluster ..
smg_shardul wrote: Fri Jul 21, 2017 11:59 am
You'll need to adapt software for Polo (icon, speed, tank volume) and immobiliser. I can only do the first for you. Not the second.
smg_shardul
Drives: Polo 6R
First for u not second I dint get you..?
I can adjust the parameters for speed, distance, tank volume and icons (Amarok parameters to Polo) but I cannot adjust the immobiliser.
smg_shardul
Drives: Polo 6R
iichel wrote:I can adjust the parameters for speed, distance, tank volume and icons (Amarok parameters to Polo) but I cannot adjust the immobiliser.
It's in transit I will tell you once it's in my hand .
Locked
