lukafoto wrote: Thu Aug 10, 2017 8:07 am A crazy project maybe!
Hi lukafoto ... in my humble opinion you should have bought a refurbished engine for your A2. :lol:
I think that at this point :arrow: viewtopic.php?f=56&t=69914&p=523551#p523550 ...
lukafoto wrote: Thu Aug 10, 2017 8:16 am Just need to find a way to fire up the engine - everything mechanical fits fine.
... you should take into account the ABS unit (full system) and its compatibility with the 6R engine unit (CGGB MM4HV 8994).
Since he already has the 6R wiring loom, I guess it's simply a matter of placing a compatible 6R ABS unit and code it.
The A2 is based on the (9N3) Polo platform but the electronics are all 6R. I guess a 6R ABS or ESP unit would be best, since it can communicate with the CAN network.
I have a 6R ESP 9.0i unit for sale, maybe it's something for you. I guess a ABS8.2 or ESP 8.2i would also work. R
emember that you'll need a vagcom/vcds to make it work, every abs or ESP pump needs a unique coding based on many parameters. We can aid you with this of course.
Passat B7. White instrument cluster. Software evolution.
Polo 6R
Oh, yes: http://nazya.com/product/datchik-public ... 53782.html :mrgreen:
With TPMS unit (F version):
Tuesday,25,July,2017,10:14:02:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate:
Mileage: 25540km-15869mi   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage: 25540km-15869miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6A57422C17E0178FDD-803E
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401500
   Shop #: WSC 40308 002 104857
   VCID: 02EF12E47BE887B71D-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7E631A684744AF1B3D-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3819AE8657E6432D4D-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 320160060
   Coding: 3CB02FBF48E32400B3380F916CEB9FDCDAC0672F600D30D0200000030800
   Shop #: WSC 12345 123 12345
   VCID: 2A17C26C1FA0974FDD-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E239AA847042FDB3D-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A3782CC9740D7AFDD-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00788 219 00200
   VCID: 351AA88F23E9511865-8060
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 14
                    Reset counter: 97
                    Mileage: 25536 km
                    Date: 2017.07.25
                    Time: 09:28:06
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002200
   VCID: 68494E1617F623FDCD-803C
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E13BA7807D48F6BBD-807A
   Component: IMMO          H05 0607
   Shop #: WSC 00000 000 00000
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   VCID: 3718AC8553E3452A75-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2F10BC7DA7CB7572B5-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77582C455B23C56A75-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_VW51.rod
   VCID: 3718AC855BE3452A75-8062
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B24A4914B173DC655-806E
End-------------------------(Elapsed Time: 04:25)--------------------------
With TPMS unit (H version): This version was installed because the vendor sent me a wrong TPMS unit, but I could not pass up this opportunity to try. :twisted:
Friday,11,August,2017,21:51:02:06516
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
Mileage: 25670km-15950mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
VIN: WVWZZZ6RZDY0CICLO   Mileage: 25670km-15950miles
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   VCID: 6A77224C3700F7A8DE-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Revision: --------
   VCID: 020FF2049B0867509E-8056
   Coding: 01
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7E83FA8867648F3C7E-802A
   Revision: V0000000
   VCID: 38398EA6770623CA4E-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 122170091
   VCID: 2B34A48123C77D71D6-807E
   Coding: 0728DD
   Coding: 0200A3
   Coding: 1000AB
   Coding: A4FFFF
   Coding: 18BC32
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Coding: 308001
   VCID: 3E437AC867240FFC7E-806A
   Coding: 00314D
   VCID: 4A5762ECB760B748DE-801E
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Coding: 140E01
   VCID: 353A88AF4309313F26-8060
1 Fault Found:
          U1111 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 45
                    Mileage: 25673 km
                    Date: 2017.08.11
                    Time: 21:45:52
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 68692E363716039ACE-803C
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Revision: AA001001
   ROD: N/A
   VCID: 2E339A9827F46F0CFE-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
   Coding: 010100
   VCID: 2A37A28C3FC07768DE-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   VCID: 37388CA5730325CD36-8062
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2F309C9DC7EB5515F6-807A
   VCID: 77780C657B43A50D36-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 3AA 907 273 H    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0012
   Serial number: 30000000034843
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_003.rod
   VCID: 394680BB733D29D346-806C
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   VCID: 3B4484B16B371DE156-806E
End-------------------------(Elapsed Time: 04:24)--------------------------
Coding: 140E01
1 Fault Found:
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 45
Mileage: 25673 km
Date: 2017.08.11
Time: 21:45:52
I will have to test D version for my IC, but I'm not sure it will work. :|
Why is it always so difficult to do something on the Polo 6R (PQ25)? this is a hell... :lol:
I'm going to have to buy a Golf VII, infinitely easier to make modifications with all the information that is in the main diagnostic tools.
n4s
Drives: 1.2 TSI Alive
Post by n4s »
I believe the tpms receiver D and F use different sensors. The H I believe already has Component Protection, so only works with clusters with CP.
Golf 7 has many upgrades with CP. dont know if will be easier...
n4s wrote: Sun Aug 13, 2017 11:18 am I believe the tpms receiver D and F use different sensors.
B is for D unit and F is for F unit.
Currently B has been replaced by F for D units. (please use as replacement F)
n4s wrote: Sun Aug 13, 2017 11:18 am Golf 7 has many upgrades with CP. dont know if will be easier...
http://www.vwroc.com/forums/topic/12517 ... olf-mkvii/
https://docs.google.com/uc?id=0B6pihEce ... t=download Awesome!!!
:lol:
n4s
Post by n4s »
I understand but you have to pay for many things:
like
https://shops.volkswagen.com/de_DE/web/ ... Z:Category
Component Protection removal
https://shops.volkswagen.com/de_DE/web/ ... g0054830-9
etc.
Very good document, good thing I understand some spanish :)
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
sorry to write this here.
but some of the words and lettering/numbering used is greek and roman to me. :(
mattblr
Drives: 6N India
Post by mattblr »
Hi Ciclo!
My ride is a Polo GT TSi (India, 2015 June) and would like to do a DIY auto folding heated outside rear view mirror install using OEM parts. My Google searches brings me here and I find that you are an extremely knowledgeable person with a helping mentality. Hope you can help me with this.
First of all, do you think it is a feasible and worthwhile effort using OEM parts or shall I stick to OEM mirrors and the K418 third-party controllers? If OEM route is doable, then could you please let me know the list of the part numbers that I need to procure (like LH & RH mirrors, controllers, wiring loom/pins, etc) and if possible reliable sources as well?
I have the VCDS cable and software which maybe used to enable desired function. Hope you will be able to help me with this. Please let me know if you need a VCDS scan to check the installed modules.
Thanks,
Matt
n4s wrote: Mon Aug 14, 2017 5:40 pm I understand but you have to pay for many things:
like
etc.
I agree with you, however, the money is not always the problem to overcome ...
n4s wrote: Mon Aug 14, 2017 5:40 pm Very good document, good thing I understand some spanish :)
That's fine. :wink:
ag69 wrote: Mon Aug 14, 2017 5:43 pm sorry to write this here.
Hahaha ... You're right, I totally agree with you, currently some of us look like Martians.
It also depends on who I am talking to ... (due to his extensive knowledges)
Do not worry, if I succeed in what I am doing all of you will have all the information about it. :wink:
I'll try to do better next time.
mattblr wrote: Tue Aug 15, 2017 7:54 am Hi Ciclo!
Thanks,
Matt
Hello, welcome.
Please search the information in this topic.The information is for 6R 2009-2014, it's the only information I know.
I do not think it will be useful for your 6R GT IND in its entirety if you already have folding mirrors without automatic function.
In this case, all you have to do is find (on ETKA) the correct window regulator motors for both front doors, but I'm afraid they are not manufactured.
There are other electronic alternatives, but I'm afraid no one has yet.
I recomend original parts in any case.
Folding mirrors with automatic function can be really dangerous in the 6R if the fingers are caught by them.
:wink:
mattblr
Drives: 6N India
Post by mattblr »
Hello, welcome.
Thank you sir for the detailed reply. There maybe some confusion created the way I asked the question. My ride doesn't have the electrically foldable mirrors. They can be folded only manually (by physically pushing on them). I believe the newer Polo manufactured after September 2015 have the electrically foldable mirrors. All I want is to have the OEM functionality of those mirrors; nothing extra. By stating automatic folding I might have confused you to think that I am looking for some functionality not offered by the electrically foldable mirrors offered by the newer Polo.
I found a set of electrically foldable mirror mechanisms online, but not sure if they are the right parts. Also, there are some sites mentioning about having to change door controllers. So, I just wanted your valuable opinion as to what parts are needed in addition to the mirrors themselves and the newer switch.
Hope I am being clear this time and you might have an answer for me.
Thanks!
Totally clear.
Without the automatic function are totally possible for your 6R GT IND with original parts.
You need the same original parts as the 6R GT IND that are currently sold in your country.
The mirrors assembly, with folding function (motor).
Doors modules (window regulator motors) with the necessary pins.
The switch with the functions you want to add (folded, heated ??)
And some additional wires for these new functions.
For heated function I am not sure that it is possible in the 6R IND.
Please open a new topic in the forum and provide all the information there. Autoscan (mandatory), images from your current side mirrors, images from your 6R.
VCDS Autoscan is the base with which to begin to look for what you need.
In this way it is easier to help with diagrams, part numbers, coding, etc ...
Thanks.
Important note (for some of you)
Where it says August 16, 2017 :arrow: viewtopic.php?f=62&t=69223&p=516196#p516196
Locked
