Page 25 of 32
Posted: Mon Mar 08, 2021 12:27 pm
by Le_Combattant
I'm considering replacing the upper and lower part of the column trim steering.
I uninstall both parts and report the parts number:
-Lower (7): 6C0 858 599
-Upper (5): 6C0 858 560 / 6C0 858 560A
But on the ETKA those reference appears right under the part number I quote:
-Lower: 6C0 858 559 82V
-Upper: 6C0 858 560 A82 V
Parts are in titanium black
Are the new references compatible with the older one ?
Posted: Thu Mar 11, 2021 4:53 pm
by amer6R
Can someone explain this mode from @ciclo. Is it to prevent rust ? (drainage pipe)
Posted: Thu Mar 11, 2021 8:48 pm
by SRGTD
amer6R wrote: Thu Mar 11, 2021 4:53 pm Image
The drainage pipe drains the water that can collect in the recess behind the tailgate hatch handle - the water should drain to the outside of the car onto the rear bumper and then down onto the ground. This is the factory design used on the mk7 and mk7.5 Golf. However, be aware on the mk7 / mk7.5 Golf that over a period of time, the black rubber grommet can perish, resulting in the bottom of the drainage pipe draining water into the tailgate.
The modification by @ciclo in the picture shows the drainage pipe is long enough to protrude slightly beyond the rubber grommet, so the pipe should be long enough to continue draining the water out onto the bumper rather than into the tailgate if the rubber grommet fails in the future.
Posted: Fri Mar 12, 2021 5:48 am
by amer6R
Thanks it confirms my prediction. Thats why tailgates rust on VW cars, no drainage pipe, no wax on inside
Posted: Fri May 14, 2021 7:25 am
by mesh
Can you tell me what type of screw bit is required to remove the tailgate lock mechanism on a polo (6R) partnumber 6R0827505B, please?
Is it a M8 torx? Or XZN M6? or ?
Posted: Fri May 14, 2021 9:24 am
by peter_dk25
N90931602: M8x20
Posted: Fri May 14, 2021 11:19 am
by mesh
Thanks Peter,
The part I need guidance on is what screwdriver bit would open the tailgate lock screws?
From the schematic on https://www.lllparts.co.uk/en/interior/ ... -9b9-60646.
I'm ordering part 27 (the lock), but need to know how to get the screws out --> part 28. What is the bit I need, I do not have a bit for it in my toolbox.
I can't add images to the post ... maybe this shows it better
https://www.catalogparts.org/catalogs/v ... 827000.png
Posted: Fri May 14, 2021 11:44 am
by iichel
It's an 8mm XZN bolt (12-toothed head)
Posted: Fri May 14, 2021 2:42 pm
by mesh
Cool thanks,
Maybe this is a stupid question, is a spline bit the same as a XZN ?
I can find 8M spline bits but not XZN.
Any idea on where to buy one from.
Thanks again.
Posted: Sat May 15, 2021 7:38 am
by peter_dk25
Posted: Sun Jun 20, 2021 11:34 am
by amer6R
Yes its spline/ star. You could even use enought big torx bit also.
Posted: Mon Jun 28, 2021 8:45 am
by amer6R
Does someone know what size is the turbo end flange ( exhaust side - downpipe size) for the 1.6 tdi ? Would like to pre-order one
Need the flange for making a custom downpipe
Edit: 2.25" ID is the correct flange.
Posted: Wed Jul 14, 2021 9:20 pm
by Bigmick1981
Hello i have a 2015 16v 1.2tsi could you possibly supy the part numbers for the 3 orings for the charge pipe , i beleive there are two required on the turbo end and one at the front end
Thank you in advance 👍
Posted: Sun Aug 08, 2021 9:02 pm
by amer6R
Does someone know, do Polo cross roof rack fits on the normal polo?
Posted: Sun Aug 08, 2021 9:36 pm
by iichel
Yes but you need a good metal drill
