Polo 6R ABS CODING
Re: Polo 6R ABS CODING
Wow didnt know that, but still
HongJu1009
- Drives: Vento A05(6R)
so i just realized something, my car engine code is CLA and is a RHD model and i couldn't find any info with this specific variant, any idea on how the code will be? i don't want to purchase the pump just to throw it into the corner of my room and collect dust
i cannot guarantee anything but so far I've always managed to find a coding for ESP and ABS pumps.
hi ,
I have a problem with my 2 hand ABS 8.2
the ABS don't acept the original long coding
1.6 tdi 2010
engine CAYA
manual gearbox
ori 6R0 907 379 AC ABS 8.2 front H04 0001
long coding 200224E3017100B4042524E280D500000200
2 hand 6R0 907 379 AD ABS 8.2 front H03 0001
if someone have an idea ?
thank's
1.6 tdi 2010
engine CAYA
manual gearbox
thank's
What happened to the car? Did you install a different instrument cluster and/or engine control unit? Are you sure AD is a direct replacement for AC?
just swap the ABS because ABS ori have a problem
i am not sure AD is the replacement of AC
share full scan please of the car
I have the same abs unit and a 1.6 TDI engine, i will post my coding tomorrow so you could try it.
No it will not help Amer, coding is specific to one single car.
I will share full scan next week end
HongJu1009
i'm starting to source out some parts now
here's a list i've made
slip ring : 6r0 959 654
pump: not sure yet, saw one (6r0 907 379 AS) today
switch: 6rd 927 117a
will this combination works and which pump should i get
Hi
i have some news about my problem so the
6R0 907 379 AC can't be replace by 6R0 907 379 AD
i try coding online with Odis and the answer was Ref parts is wrong
vipperformance
- Drives: 2015 1.4tdi bluemotion comfortline LHD
Hi guys I`m new here and want to say hello
and of course I need your help
I replace abs pump and need coding help
Friday,16,July,2021,11:06:59:10708
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ6RZHY114445 License Plate: ABS PUMP
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP90.clb
Control Module Part Number: 6C0 907 379 G HW: 6R0 907 379 BA
Component and/or Version: ESP9.0i H03 0003
Software Coding: 0000000000000000000000000000000000000000000000000000
Work Shop Code: WSC 13765 031 00063
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018 (VW26)
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 333016271BB7F5D3421-8066
4 Faults Found:
0943 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
[IISOEMCalibrationError]
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 76242 km
Date: 2019.02.19
Time: 00:00:02
0887 - Control Module
C104A F0 [008] - Incorrect VIN
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 76242 km
Date: 2019.02.19
Time: 00:00:02
0896 - Control Module
C104A F0 [009] - Incorrect VIN
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 76243 km
Date: 2019.02.28
Time: 22:37:01
0883 - Control module not coded
U1013 00 [137] - -
[VehicleConfigUncoded]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
www.Ross-Tech.com
4 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 76242 km
Date: 2019.02.19
Time: 00:00:02
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 76242 km
Date: 2019.02.19
Time: 00:00:02
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Mileage: 76243 km
Date: 2019.02.28
Time: 22:37:01
U1013 00 [137] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 221
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
get code from the old pump?
vipperformance
OLD PUMP WAS SMASHED
CANNOT READ
