My current project: Rosa Line Bike.
The paint code is in fact L041 from my Polo. :mrgreen:
28 inch wheels, how sporty is this!
Shimano 11 speed gearbox with overdrive in all gears.
It will have LED front and tail lights, emissions wise it's very green, runs on pasta, pizza, hamburger...
No cruise control or lane change assist unfortunately.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
iichel wrote:My current project: Rosa Line Bike.
I give u one idea:
take one radar (master) for side assist and make it wearable somewhere behind your back/inside backpack! install the wiring loom with waterproof connector to the led on both sides of the handle!! cool [emoji41]
But there is no electrical power :|
benzinkopf
im sure u can get the 12V power from something called dynamo. 🤣
:idea:
Hub motors
Pedal Assist.
Meanwhile I bought another diagnostic tool, etc ...
lo7ro
Drives: polo BlueGT
Post by lo7ro »
ciclo wrote: Mon Oct 16, 2017 8:33 pm
Hi lo7ro, welcome.
In English please, this is an English forum for everyone in this world.
I am sure that all your doubts / questions will be solved.
Thank you very much.
Best regards
Sorry ciclo
Hello, I'm from Spain. A long time ago we talked.
I have a bluegt pole and I would like to play something with the vagom.
To set the star / stop by default my number is 00250012242411000000
Why is it disabled by default as the number should be?
What do you find most interesting about vagcom?
I lost your mail and he had to come back here to get you jajaj and I cannot send a private..
I'm afraid it's not possible to disable the start/stop system with the VCDS system.
benzinkopf
anybody knows what adaptation channel 73 bcm does?
Ive accidentally changed adapt channel 69 from 0 to 1. Turned out its switching off the dimmer switch for interior buttons and make the cluster full brightness. 🤣
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
iichel wrote: Thu Oct 19, 2017 4:10 pm I'm afraid it's not possible to disable the start/stop system with the VCDS system.
No - that's true.
But if you can live with a malfunction notice in address 61 - you simply disconnect the small plug on the earth connection of the battery terminal.....
I hope I may ask a question for help in between.
I made someone the autolight wiring, but T73a/1 will not give power to the headlight/high beam relay.
The VCDS coding of the 7H0937090B is changed
7AB02B3F08FB0F00B3380FF03FAB9ED05FC0412F7E842008200000020000
to:
7AB02B3F08F30F00B3380FF03FAB9ED05FC0412F7E842008200000020000
The guy says the headlight relay (permanent high beam) worked before the coding but not after. I'm a bit puzzled.
maybe byte 23 bit 0?
7AB02B3F08F30F00B3380FF03DAB9ED05FC0612F7E842009200000020000
Be careful, maybe it will explode... :lol:
Remember, I never correct the bytes that are not related to the question asked. :mrgreen:
Thanks Fernando, I'll advise this coding.
lo7ro wrote: Thu Oct 19, 2017 3:14 pm
Many things, are too many things. Most of them have been shared in this topic.
Your question is too generic. :wink:
iichel wrote: Thu Oct 19, 2017 8:26 pm Thanks Fernando, I'll advise this coding.
will work... :wink:
Locked
