Locked
JayW
Post by JayW »
Thnks!
So the 2 red 10amp fuses are the ones i need to replace correct?
JayW
Post by JayW »
Thanks! Brilliant stuff!
Can rely on you for just about anything lol.
jammydodger
Drives: 6R GTI
Post by jammydodger »
JayW wrote:Thanks! Brilliant stuff!
Let us know how you get on Jay, very interested in these!
JayW
Post by JayW »
Will do mate :)
JayW
Post by JayW »
Fitted my headlights yesterday and got them working perfectly! They look stunning! Can't tell the difference between these and the genuine ones from VW. They came with 6000K HIDS already wired up and ready to go, all I had to do was plug it in. Took a whole 20 mins to get them fitted.
Here's a few snaps of them on the car :)
For anyone who are thinking of getting a set, I would highly recommend it!
jammydodger
Drives: 6R GTI
Thank you so much JayW - you've made this decision a whole lot easier! Any coding needed?
JayW
Post by JayW »
Nope, no coding at all. Just plug and play. You can code it so that the LED's come on as your DRL's but I've left it for now.
They are sublime!
tommytse22
Drives: polo gti
Post by tommytse22 »
JayW wrote:Nope, no coding at all. Just plug and play. You can code it so that the LED's come on as your DRL's but I've left it for now.
They are sublime!
Jay they look great! Got link for them ? May get a pair depend on price!
JayW
Post by JayW »
Lovely look! :wink:
Before doing the following I need a vcds scan your BCM and info of the new harness (pictures connector 14-pin).
DRL:
If you have DRL beside the fog lights, you have to make some changes to the wiring.
Pin1 current drl... to ... Pin10 drl xenon (connector 14-pin)
And vcds coding.
Led DRL work with the light switch in position "0" and diminish its intensity while working as sidelights.
Static cornering lights:
Pin1 current fog lights .... to .... Pin14 xenon
Then pin1 both foglights vacant.
Now, you need to redo the wiring of the foglights and connect them directly to the light switch. (needed a new fuse 15amp in position 54)
Pin1 vacant both foglights ... to ... new fuse SB54 (15amp) and from SB54 to Pin8 light switch (attached to existing cable).
And vcds coding.
If you can not use position 54 by the shape of the fuse box, put the fuse in position 37 (for example)
Warning to other readers:
It is necessary to have the fuse SB57 to make these changes.(DRL and fog lights)
If you have the fuse SB56, your drl are not controlled by the BCM.
sheFs
Drives: Polo 6R
Post by sheFs »
Hi Ciclo,
Have you sourced the tail lights of the 6C Polo's already?
If so, I'd also be interested in getting them.
Thanks!
Hi sheFs
Not yet, soon I will put a tutorial (DIY) for making oneself the necessary wiring, here. I am waiting to receive the connectors.
Your polo, RHD or LHD?
If I buy taillights 6C will be here:
http://www.carparts-pros.com/index.php
Small update to RHD: http://www.uk-polos.net/view ... 88#p482188
sheFs
Drives: Polo 6R
Post by sheFs »
Thanks for the quick response!
It's a RHD, so was hoping could source one in the UK that wouldn't require too much wiring changes!
Looking forward to your DIY.
Locked
