Page 26 of 333
Posted: Sat Aug 23, 2014 10:18 am
by JayW
Thnks!
So the 2 red 10amp fuses are the ones i need to replace correct?
Posted: Sat Aug 23, 2014 10:28 am
by ciclo
Posted: Sat Aug 23, 2014 12:33 pm
by JayW
Thanks! Brilliant stuff!
Can rely on you for just about anything lol.
Posted: Sat Aug 23, 2014 1:32 pm
by jammydodger
JayW wrote:Thanks! Brilliant stuff!
Let us know how you get on Jay, very interested in these!
Posted: Sat Aug 23, 2014 3:22 pm
by JayW
Will do mate :)
Posted: Sun Aug 24, 2014 4:14 pm
by JayW
Fitted my headlights yesterday and got them working perfectly! They look stunning! Can't tell the difference between these and the genuine ones from VW. They came with 6000K HIDS already wired up and ready to go, all I had to do was plug it in. Took a whole 20 mins to get them fitted.
Here's a few snaps of them on the car :)
For anyone who are thinking of getting a set, I would highly recommend it!
Posted: Sun Aug 24, 2014 5:13 pm
by jammydodger
Thank you so much JayW - you've made this decision a whole lot easier! Any coding needed?
Posted: Sun Aug 24, 2014 5:21 pm
by JayW
Nope, no coding at all. Just plug and play. You can code it so that the LED's come on as your DRL's but I've left it for now.
They are sublime!
Posted: Sun Aug 24, 2014 5:48 pm
by tommytse22
JayW wrote:Nope, no coding at all. Just plug and play. You can code it so that the LED's come on as your DRL's but I've left it for now.
They are sublime!
Jay they look great! Got link for them ? May get a pair depend on price!
Posted: Sun Aug 24, 2014 7:09 pm
by JayW
Posted: Mon Aug 25, 2014 6:55 am
by ciclo
Lovely look! :wink:
Before doing the following I need a vcds scan your BCM and info of the new harness (pictures connector 14-pin).
DRL:
If you have DRL beside the fog lights, you have to make some changes to the wiring.
Pin1 current drl... to ... Pin10 drl xenon (connector 14-pin)
And vcds coding.
Led DRL work with the light switch in position "0" and diminish its intensity while working as sidelights.
Static cornering lights:
Pin1 current fog lights .... to .... Pin14 xenon
Then pin1 both foglights vacant.
Now, you need to redo the wiring of the foglights and connect them directly to the light switch. (needed a new fuse 15amp in position 54)
Pin1 vacant both foglights ... to ... new fuse SB54 (15amp) and from SB54 to Pin8 light switch (attached to existing cable).
And vcds coding.
If you can not use position 54 by the shape of the fuse box, put the fuse in position 37 (for example)
Warning to other readers:
It is necessary to have the fuse SB57 to make these changes.(DRL and fog lights)
If you have the fuse SB56, your drl are not controlled by the BCM.
Posted: Tue Aug 26, 2014 3:17 pm
by sheFs
Hi Ciclo,
Have you sourced the tail lights of the 6C Polo's already?
If so, I'd also be interested in getting them.
Thanks!
Posted: Tue Aug 26, 2014 4:54 pm
by ciclo
Hi sheFs
Not yet, soon I will put a tutorial (DIY) for making oneself the necessary wiring, here. I am waiting to receive the connectors.
Your polo, RHD or LHD?
If I buy taillights 6C will be here:
http://www.carparts-pros.com/index.php
Small update to RHD: http://www.uk-polos.net/view ... 88#p482188
Posted: Tue Aug 26, 2014 5:51 pm
by sheFs
Thanks for the quick response!
It's a RHD, so was hoping could source one in the UK that wouldn't require too much wiring changes!
Looking forward to your DIY.
Posted: Wed Aug 27, 2014 7:16 am
by ciclo
