Polo 6R - Useful Part Numbers
Thats a bit to much just for a roof rack and possible rust issues :(
ELSA WIN online, repair manuals, service procedures ... free
https://en.kolhosniki.ru/elsaonline
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Thanks amer6R
But "Transmission" has drop down as:
  • PCC
  • PLB
  • PMX
  • PWJ
  • QHX
  • QRG
  • RCY
  • RQV
My car is 2015 Model Year 1.2 TSi 77kw 7 DSG
I choose 603 GP as Model and CBZB Engine
So any idea what to choose?
Here is part of my VCDS scan :
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6561
   Revision: 00043014    Serial number: CU501407085037
   Coding: 0000020
   Shop #: WSC 63002 002 1048576
   VCID: 3A2E3B83D054E5DB5C7-806E
That will be a RCY
ag69
Post by ag69 »
Thanks iichel.
Is there anyway to find mapping or it is because of your sheer amount of work done on 6Rs ;)
It should also be on the sticker in the boot with all equipment codes
Can someone confirm that polo 6r shares the same wishbone bushings as mk4 golf ?
Yes same as MK1 Audi tt
Thank you
6Q0199851AP - Lemforder
The dimension are the large bush 80 mm, the smaller bush is 36 mm
the height( of 80 mm bushing) is 40 mm, the width of smaller bushing is 32 mm
the height of the smaller bushing is 50 mm
Bushing screw to screw is ~181-182 mm
Large bushing bolt opening is fi 11 mm
Will post the dimension of OEM doge bone mount. If you can source the large bushing that is 80x40 mm you can rebuild the doge bone mount or atleast the lemforder one.
Edit: I have just replaced mine OEM mount ( its also produced by Lemforder but it has Vw stamps )
- No engine diving under hard acceleration
- No jerking feeling that car is giving self throttle dow a hill or in stop go traffic.
Just want to add if someone ever needs.
GSP outer cv joint is great quality.
Disassembled mine today, tohough it was pita. It wasnt 0 play, felt like new. After one year. ( Note add extra 90g of grease into it)
And the price is 1/2 of SKF
Anyone familair with part numbers for the brackets in yellow?
If i can remember correctly they can flip open, maybe the part number is hidden...
Try taking a pic of the part, and scan it with google lens maybe something comes back
If anyone needs, SNR is OEM bearing in polo 6R
amer6R wrote: Wed Oct 20, 2021 6:27 pm If anyone needs, SNR is OEM bearing in polo 6R
Are you sure it is not SKF?
