Page 261 of 333
Posted: Thu Dec 14, 2017 8:35 am
by ciclo
The manufacture place it's not related, depends on the PR codes.
Example: 8IT = LED headlamps.
It's difficult (but not impossible) to know the PR codes if you buy a used BCM and you do not know the extras (optional equipment) of the donor car.
Posted: Thu Dec 14, 2017 9:45 am
by ciclo
Polo 2018 TSI Evo :?:
Posted: Thu Dec 14, 2017 11:38 am
by alexperkins
Interesting technology that. Itll be interesting to see if they put it into the polo
Posted: Thu Dec 14, 2017 12:15 pm
by iichel
From what I've heard the 1.5TSI engine is following a miller cycle (a bit like the Atkinson cycle on the Prius) to allow for better expansion during the work stroke.
Posted: Thu Dec 14, 2017 1:23 pm
by ORiOn
They will surely make a Polo with the EVO engine, like they did with the ACT engine.
Posted: Thu Dec 14, 2017 6:13 pm
by ciclo
Well, this engine is already available in le petit LEON, the new SEAT Ibiza 2017 (FR).
My problem is that I'm an impatient :lol: ... and I want it in le petit GOLF...
Posted: Sat Dec 16, 2017 8:03 am
by ciclo
Updating Maps and Personal POIs (speed cameras/radars, etc...)
While I try to find time to continue with my tests ...
Image Image :( :lol:
... I have updated the maps of my RNS510, also the Personal POIs with date 11/27/2017 (MM/DD/YY).
Info
Maps V15 West Europe:
viewtopic.php?f=56&t=70545&p=527739#p527739 :arrow: https://drive.google.com/file/d/1WKjs17 ... 9VFO7/view
or
http://gpsunderground.com/forum/ :arrow: http://gpsunderground.com/forum/forum/c ... ost1328723
Personal POIs 11/27/2017 West Europe:
https://drive.google.com/drive/folders/ ... sp=sharing
Maps
Open the car, ignition OFF, turn on RNS and insert the DVD, follow the instructions on screen... once the update starts you can start the engine to ensure the battery voltage during the process (it will take about half an hour).
Updating ...
Once the data load is finished...
Eject DVD...
(Guttenberg street... :mrgreen:)
Check the version (push SETUP button 20 sec)
POIs
You must copy the folder of the previous link into the root of a formatted and data-free SD card. Therefore, the only information inside the card must be the folder (PersonalPOI) and inside the db3 file.
SETUP---Navigation---Personal POIs---Insert SD card---Import---follow the instructions on screen.
Importing data ...
Remove SD card and check (details menu)...
Note: The UltraISO program did not work for me when burning the data on the DVD, I used ImgBurn and it worked perfectly. 8)
(same conditions)
Posted: Sat Dec 16, 2017 9:20 am
by iichel
CDBurnerXP also works well, it's important to keep the burning speed to 1x, it will take about 25 minutes.
Posted: Sat Dec 16, 2017 9:57 am
by alexperkins
5124 is a rather old FW version. I just updated mine to 5274
http://www.my-gti.com/3868/volkswagen-r ... repository
Posted: Sat Dec 16, 2017 5:32 pm
by ciclo
Thanks to both Image, yes, burn speed 1x (25 min roughly).
Downloading the location 1 for:
RNS_510_FW_5274_update.rar - 492.14MB (RNS_510_FW_5274_update.iso - 697,820KB)
...(downloaded - 43min, when possible the picture)
... sometimes I forget the most important thing ..., however and even though the SW/FW-5218 always worked correctly for me the SW 5274 will be a good update. :wink:
I guess it will be the last SW for my RNS510 HW, ...from SW 3218 I think I had almost all of them.
I was very close to installing the Discover Media radionavigator, but since the RNS510 is so good it's difficult to make this decision for the 6R due to changing the RVC and other devices.
Our following POLO (TSI Evo :)) will have the Discover Media or similar ...
Posted: Sat Dec 16, 2017 6:52 pm
by Ugabista
Hello,
this is the RNS510 of a friend of mine, he has no unlocked motion video? Will need to update or read a file to unlock the video?
Posted: Sat Dec 16, 2017 9:02 pm
by ciclo
You can try this patch (download the three files) for VIM, but I do not think it works with SW 6270.
Posted: Sat Dec 16, 2017 9:05 pm
by alexperkins
I think VIM on the later models is more than a patch as you say ciclo. I think it requires some reprogramming which only a specialist tool can do
Posted: Sat Dec 16, 2017 9:11 pm
by Ugabista
Hmmm ok.
Exist alternative? Put a firmware up that already brings the patch to unlock the VIM?
Posted: Sun Dec 17, 2017 8:00 pm
by ciclo
alexperkins wrote: Sat Dec 16, 2017 9:57 am 5124 is a rather old FW version. I just updated mine to 5274
Updated to 5274 Thanks Alex.
A couple of pictures and a video (VIM). :lol:
Open the car, turn on the RNS, insert the DVD with ignition OFF and ...
Time remaining 37 mins
So right now I can start the car ... and take a walk on this "cold" morning. :)
Waiting... (18 mins)
Success... auto eject
Welcome
Version. Press and hold the SETUP button, then version info menu.
e voilà
Checking the functions
Bip bip bip... :lol:
NO = NW
Video in motion (VIM)
1>2... :lol:
In short, works like a charm!
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5274
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 37C8FC35E3B3955DC6-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V15 8515
Sunday,17,December,2017,13:08:19:06516
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: RNS510 NFW - NMaps - NPOIs
Mileage: 28770km-17876mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage: 28770km-17876miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   VCID: 6A0792DCA7B067386E-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 029F62940BB8D7E02E-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X_VW25.rod
   VCID: 7E136A181714FF4C0E-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38C9FE36E7B6935ADE-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 122170091
   Coding: 3CB02FBF48E32400B3380F916CEB9FDCDAC0672F600D30D0200000030800
   VCID: 2BC41411D377ED8166-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3ED3EA5817D47F0C0E-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4AE7D27C271027D86E-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00000
   VCID: 47D8DC652BE335CD46-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 68F99EC6A786732A5E-803C
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   Shop #: WSC 03607 002 104857
   ROD: N/A
   VCID: 2EC30A28D764DF9C8E-807A
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
   Component: IMMO          H04 0805
   Shop #: WSC 00000 000 00000
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2AC7121CAF70E7F86E-807E
   Part No: 6R0 423 156 B
   Coding: 11221
   Shop #: WSC 00788
   VCID: 2FC00C2D579BC5A586-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77087CF5EBF3159DC6-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30.rod
   VCID: 37C8FC35EBB3955DC6-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3BD4F4411BA78D71E6-806E
End-------------------------(Elapsed Time: 04:27)--------------------------
Adam87 wrote: Sat Nov 25, 2017 3:16 pm Not sure if anyone has mentioned it before as I haven’t seen it posted, comfort closing is possible via drivers door switch, it is good for me when parking up to fold mirrors in without having to lock the van because I need to get tools etc out the back.
(See attached video)
https://www.dropbox.com/s/0tp79gglognrq ... h.MOV?dl=0
Confirmed, it works perfectly in my 6R :D . A great discovery! :wink:
