sunilsoft wrote: Wed Dec 27, 2017 3:05 am Hi ciclo,
Is it possible to install vw alarm system 1K0951605C in indian polo.
It is available on https://goo.gl/MQm6Nx .
Yes.
A- Alarm horn H12
LIN = T73b/36 BCM
+ve = +30
-ve = ground (any point of car frame)
B- Interior ultrasonic sensors
LIN = T73b/24
+ve= +30
-ve= ground (any interior point of earth wiring)
You can install one (any, A or B) or both.
It's necessary to code the BCM.
federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
ciclo wrote: Sun Dec 24, 2017 12:09 pm If you want to install 6C LED headlights you need a new BCM Max 7E0 from T6 with PR-code 8IT.
Therefore, if you buy a new BCM 7E0 with PR-code 8IT you will not have any problem with any type of headlight.
Which is the price of a new 7E0937090C BCM? Is possible to "enable" the PR-code 8IT with VCP?
Contact firegrafik, he will tell you what you need to know, everyone always ended up happy with his help... 8)
sunilsoft
Drives: Polo 6R Tdi 2015
Post by sunilsoft »
ciclo wrote: Wed Dec 27, 2017 4:15 am
Yes.
A- Alarm horn H12
LIN = T73b/36 BCM
+ve = +30
LIN = T73b/24
+ve= +30
Please provide the coding and part no. for interior ultrasonic sensors
Please, open a new topic in 6R section and provide information about your 6R. Thank you.
Information to provide: pictures (interior, exterior), auto scan, etc.
viewtopic.php?f=10&t=42713#p466570
New static cornering lights bulbs
The static cornering light bulb on the right side of my 6R has blown, probably due to its intensive use. viewtopic.php?f=56&t=58703&p=517482#p517482
Image :)
FYI: in the center of image is the static cornering light with Bixenon (left side). Philips 2013, I don't remember the model.
I will test with the following ones (eBay),
... although I will probably have to install LED bulbs of latest technology ...and longer duration.
Info
Commercial images
:lol:
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Ive tested the H7 night breaker last time for my low beam, unfortunately it only last for 1year.
It's unusual if they are Original.
benzinkopf
you re right. but no doubt the performance is good. just the lifetime is not that great.
Which one did you buy, UNLIMITED or LASER?
benzinkopf
UNLIMITED Night Breaker. NBU. burned out after 67k km. particularly after driving straight all night for 4hrs nonstop. So maybe thats the reason as well🤣
federicodrdpro
Ciclo, which is the code of your last BCM 7E0937090C XXX? I am searching a BCM 7E0937090C with many PR code.
I found 7E0937090C ZU0:
A8Z - multivan Highline
IS0 - without interface for external use
F0A - standard equipement - vehicle spec like ambulance, police car etc
8T3 - Automatic distance control
3RC - Tailgate with window aperture
8IT - LED headlamps
K4H - closed body
5D1 - carier frequency 433,92-434,42 MHZ
7E0937090C Z0E Bixenon, climatronic, etc...
In Russia the 6R-Vento with LED headlights are not sold, but they are sold in India. :)
Best/Last model for 6R India with LED headlights (8IT). 7E0937090C ZVE
After almost three years I think, today I removed the auto light wiring you made for me. It's still in good condition but since bcm 7E0 it's not necessary anymore. I ran a new wire from the BCM T73b/37 to the auto light switch T10/2 and another wire for the DRL from T73b/29.
Both relays are not used in my car since the fog lights with cornering lights are powered by the bcm and T73b/7 is only an operating signal with low amps.
The BCM also powers the high beams and the steering column combination switch is now simply providing an operating signal with low amps.
What is left is a very simple wiring but it works very well. The beauty of simplicity.
iichel wrote: Mon Jan 01, 2018 4:11 pm After almost three years I think, today I removed the auto light wiring you made for me. It's still in good condition but since bcm 7E0 it's not necessary anymore. I ran a new wire from the BCM T73b/37 to the auto light switch T10/2 and another wire for the DRL from T73b/29.
Why do you tell me all this? What intentions do you have? :lol:
Everything you are telling here already happened two years ago in my 6R ...+1 day... "to be exact". The first of the world, also to be exact.
However, better late than never. Congrats... :lol: :lol: ur a fast guy. :lol: :lol:
The problem is that you did not understand anything at that time and it is obvious :lol: that you still have a lot to learn.
Locked
